Old 11-21-2015, 05:27 PM   #1
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Question Michelin LTX M/S2 - Inflation Preferences
Please don't chop off my head. I know this has been discussed here and there with a lot of debates.
I am running the Michelin LTX M/S2 LT225/75R16 like many others, and for some time I was inflating to 70psi cold. And usually they'd heat up to 75psi.
I'm not sure how I arrived at 70psi, perhaps something I saw here on Airforums. I was reviewing the Inflation Tables (which I've attached here to this post) and decided to lower the pressure to 60psi. Which is still over the weight rating for my axles at 4380lbs. I wanted to experiment with getting a softer ride for the Airstream.
We drove 163 miles today from the middle of the Mojave Preserve in CA to Parker, Arizona. The tires warm all went to 67psi and maintained that pressure, I checked at several intervals.
The load table would seem to suggest I can run 50 psi. And the original Goodyears are suppose to be inflated to 50psi, as printed on the placecard on the side of my Airstream.
I just thought I'd throw this out there to get some opinions, negative or positive, doesn't matter. Do you run these tires based on the load tables, or do you just inflate to maximum? Share your thoughts.
I'm thinking about experimenting further, but I also want to minimize risk.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-21-2015, 05:44 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I inflate to manufactures recommendation.
MICHAEL
Old 11-21-2015, 05:55 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I have been running mine at 75 psi because at about 74 psi they have the same load carrying capacity as the original ST225/75-15s. Several on here have expressed the opinion that using the load tables that were intended for the standard use of the tire (light trucks) may not be appropriate on tandem axle trailers due to the twisting stresses placed on tires on tandem axle trailers when turning. That is why I have not gone below the pressure that results in the same load carrying capacity as the original tires.
By the way, the original tires were WAY overkill for my GVW (6300#). I don't know why Airstream used them instead of lower load range or smaller tires, but I chose tires with the same load capacity.
Your experience would seem to say that there is more pressure buildup and therefore more heating at 60 than at 70. If that pressure rise is typical, I'd be tempted to stay at 70.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-21-2015, 06:06 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I like 65-70 psi because many Airstreamers here are using it with no issues. My concern is also a soft ride for our Airstream balanced against any risk. I don't see any risk at these pressures, based on other and our own experience. I would like to run them a little less, but I don't see the experience here to back it up yet.
Doug and Cheryl
Old 11-21-2015, 06:12 PM   #5
2015 30' FB FC Bunk
Ayer , Massachusetts
Which is what? I never understood that, looks like he has a whole chart of psi options. Are you saying to inflate until the tires are at your load capacity? Any saftey factor?
When I go to Michelins next year, I'm going with 80 psi...
Ted S. is offline   Reply With Quote
Old 11-21-2015, 06:40 PM   #6
2007 25' Classic
Hutto , Texas
I run the same tires on my 07 25' Classic at 65 psi cold.
Wanderer2604 is offline   Reply With Quote
Old 11-21-2015, 06:51 PM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Never mind..... these are on the Burb.
AS at 70psi
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-21-2015, 06:53 PM   #8
dkottum's Avatar
Ted, I started with 80 psi as well, then began to be concerned about roughing up the Airstream. I noticed some people have loose hinges and cabinets, things getting knocked around and broken while some people do not.
Thinking of how much rougher our truck rides at maximum rather than normal reduced pressures, I decided to start looking at lower pressures for the Airstream's 16" Michelins.
Doug and Cheryl
Old 11-21-2015, 06:53 PM   #9
2014 27' FB Eddie Bauer
Orleans , Ontario
From a dkottum reference on 10-09-2014 to a 2013 discussion on the same topic. We run at 55psi with a 2014 EB 28 foot.
Originally Posted by dkottum View Post
On 11-03-13 Andrew T. wrote:
We have the best results carrying the correct tire pressure for the load the tire is carrying. The attachment is the RV load inflation table from Goodyear's website.
Here are the pressures for a 225/75R x 16 LT:
80psi 2680 pounds,
65psi 2335 pounds,
50psi 1940 pounds,
45psi 1790 pounds,
40psi 1650 pounds,
35psi 1500 pounds.
To use this chart you really should weigh your combination connected & loaded for travel on a sectioned scale.
For example the last Eddie Bauer I weighed with a customer was 6700 pounds on the axles (motor cycle inside) or 1675 pounds per tire. Generally I will add 10% to that number for variences in side to side load and the possibility that the scale is out a little so 1850 pounds per tire. Using the chart you could call it at 47 PSI but we went with 50 psi. 50 PSI has several advantages over 80 PSI; a smoother ride for the Airstream, shorter stopping distances espessially when wet and more even tread wear.
Some trailers & fifthwheels with corners are built with 225 Marathons right at their limit just over 10,000 pounds on tandem axles. In those cases we use the 225/75R x 16" LT with 80 psi.
From 1971 - 1984 a factory option on a new Airstream was Michelin 7:00 x 15" load range "C" tires. There were thousands of Airstreams built with these and tire trouble was very rare. I know many would say those trailers were lighter but actually many were not. The brochure weights in those days did not include options and everything was an option. By the time you added awnings, ac, double pane windows 2 door fridge etc. they weighed about the same as the new ones. Generaly 70's units tow a little easier because they are narrower and little more aerodynamic.
Years ago we could buy 225/75 x 16 Michelins in load range C which was a better match for most Airstream's but they are no longer available.
I know this is confusing and it is always easier to assume that bigger and heavier and more pressure has to be better but everthing has its compromizes.
Andrew T
Andrew Thomson
Can-Am RV Centre | #1 Airstream Dealer in Customer Satisfaction Worldwide | Your Full-Service RV Dealer
London, Ontario
S&K
Shawn & Kara
Hamish is offline   Reply With Quote
Old 11-21-2015, 07:04 PM   #10
Nomadic , USA
Al
Yes, these are some of the thoughts I had too about the intended use in relation.
As for pressure buildup; does anyone know what is the proper "cold" temperature. It was in the mid 50's this morning when I set this pressure, and then by the time we got here it's 80.
70 has certainly worked out, just been curious about this topic for reasons stated above. Good discussion so far. Lots to ponder.
Old 11-21-2015, 07:11 PM   #11
Good point. The 30 degree rise in ambient will change the "cold" temperature. When did the rise from 60 to 67 occur, and what was the outside temp at that point? If you dont have a TPMS you may not know that. I typically see about 79-80 from 75 when driving but I havent had much ambient change.
Al
S/OS #004
Old 11-21-2015, 07:15 PM   #12
dkottum's Avatar
We have often left home in Minnesota in freezing temps, heading south and encounter much warmer weather in a few days. This affects tire pressures but I quit worrying about it until I am in more stable day-to-day travel weather, then I may adjust pressures accordingly. But I often wonder if too much is made of a few pounds one way or the other.
Doug and Cheryl
Old 11-21-2015, 07:35 PM   #13
1994 28' Excella
Burkburnett , Texas
I have had my tires almost 2 years and for the last year and half I have been running 60 psi. I have not checked the psi. when warm, I usually check the temp at the hub and tire. With 6000 miles I have not seen any wear problems on the tires.
From what I am reading here I could drop down to 55 psi without any worry.
paulken is offline   Reply With Quote
Old 11-21-2015, 07:40 PM   #14
Nomadic , USA
I thought I read somewhere from Tireman6 or whatever his name is, that a tire's PSI shouldn't increase more than 5-8psi. If it's increasing by 10 or more psi then it's underinflated, overinflated or overloaded. At least, this has been the measure I've been using in my head all this time. I could be totally wrong.
Kind of the reason for this thread.
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Michelin LTX LT 235/75-15 JakeSpoon Tires 63 07-03-2015 04:18 PM
Michelin P235/75R15 LTX for use as a trailer tire?? Streamside Tires 50 03-28-2014 06:41 AM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
