Old 08-02-2010, 09:50 PM   #1
Dallas , Texas
Michelin LTX LT 235/75-15
Anyone running the Michelin LTX LT 235/75-15 Load Range C tires with good results?
JakeSpoon is offline   Reply With Quote
Old 08-03-2010, 08:02 AM   #2
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
This is for a 2000 30ft Excella.
Load range C tires max out at 50psi - load range D tires at 65psi, and for any kind of proper handling on that Airstream, you'd want load range D.
imvvho.
TX-16
Dave Park is offline   Reply With Quote
Old 08-03-2010, 09:18 AM   #3
dstalzer's Avatar
2005 25' Classic
I checked with Discount Tire and they told me that load range C was not heavy enough for my Classic. Since I have just had a blowout on a Marathon that has about 6000 miles on it I was hoping to be able to put the Michelin LTX tires on but for 15" wheels they are only load range C. The manager said the problem with all ST tires is that they do not dissipate heat very well and none of the ST tires do well in temperatures around 100 degrees when the trailer is pulled for long periods of time. The only option is to change out the wheels, which are quite pricey, or go with Maxxis load range E tires that are supposed to provide more safety for the load and in the heat. I have read that others have used these tires and they seem to work well. They are stiffer and it may not be best to inflate them to the maximum like the Marathons. There have been some reports of rivets popping if the max pressure is used. I am still trying to figure it out myself.
That is my 2 cents worth.
Dennis
dstalzer is offline   Reply With Quote
Old 08-03-2010, 12:54 PM   #4
Dave Park's Avatar
2005 22' Safari
Also, load range C tires are being used far outside their safety envelope of you put anything in your AS to get it near that 8300 lbs GVRW - 2075 lbs/tire...
TX-16
Old 08-03-2010, 02:31 PM   #5
2005 19' Safari
GLENDALE , AZ
FYI, I have been running Maxxis, 225/75x15, Load Range E tires at 80 psi, on our 19-foot Bambi, for the past year and a half (approximately 10,000 miles), with absolutely no problems.
Old 08-03-2010, 03:10 PM   #6
Dave Park's Avatar
2005 22' Safari
Maxxis keeps coming up and keeps getting excellent recommendations. I think I will put a set on my lifetime trailer, when I find her!
TX-16
Old 08-03-2010, 03:21 PM   #7
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
My 2 cents
As you can see, my 2010 FC30' has Michelin LTX M/S 235/75-15's (load C).
I think they're great for this basic reason; the higher load ratings run at higher PSI's; 60 and above. Mine run at 50 PSI. This gives my TT a softer ride which IMHO is very important to me.......
Here's the TireRack link: Michelin LTX M/S
So far, I've put about 10k miles on them with excellent wear.
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
Rawn77 is offline   Reply With Quote
Old 08-03-2010, 04:02 PM   #8
_
sorry ron,
but that's an OVERLY clever (not smart) tire choice...
especially for modern 30 footer with 4 batteries and an assortment of modern addONz.
mehbe the ratings are different when converted to metric...
you've got a NEW trailer.
the axles determine ride quality not the tires.
if u don't buy that notion,
fire off a note to the PREZ of a/s and ask.
the reference is a direct quote from the boss man.
not only will they HEAT UP and suck down fuel economy...
but the softness makes 4 totally vague control and stability.
especially in a 75 series tire that's TALL baby, tall.
u might NOT notice the POOR stream wobblin,
because of the hitch selection,
but behind that hitch yer trailer be squirrelly...
________
to the op...
there is simply NO GOOD REASON to put c rated (or the equivalent) tires on a MODERN 28/30/31 footer.
one MIGHT make a case (lame as it is...) 4 C rated tires on a 34,
but have a flat and forget that trick too.
a/s specs D rated or higher on these trailers for a reason.
cheers
2air'
Old 08-03-2010, 04:07 PM   #9
Dave Park's Avatar
2005 22' Safari
Ron, I would point out that you're in Quebec, and JakeSpoon is in Texas, there summer temps are easily 105F in the shade, and were road temperatures can easily reach 170F. This means tires on Texas trailers face a different set of harsh conditions to those in your part of the country.
Higher PSIs equal stiffer sidewalls which generate less heat.
TX-16
Old 08-03-2010, 06:29 PM   #10
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
4 LTX M/S 235/75-15's (load C) = 7,940 lbs. max. load. I would of thought the 2010 FC30' trailer weighed more, loaded up for camping.
If you want to keep the stock wheels, and want something else besides the ST trailer tire, you can go to a 225/70/r15 size. I believe TireRack shows 2 tires in that size that are D rated. You will lose 1/2" in height using that size.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 08-03-2010, 06:34 PM   #11
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
I'm not advocating for any particular tire, but to answer the original poster's question: like Ron, I am running a 30 footer (Safari), weighing about 7,500 loaded, with Hensley and the Michelin LTX 235-75/R15 Load Range C.
6,000 miles so far and no problems. Wear is negligible. If I'd been running the ST tires I used to use, I would have had at least one tread separation by now. I plan to report further at 10k and 20k miles.
2air: Your theoretical objections are not borne out by my empirical evidence so far. My trailer is not squirrely. The tires are not running hotter than the ST's they replaced (measured with infrared). Fuel economy is not less.
What I have noticed is that I'm not spending time at the side of the road replacing tires any more. I'm hopeful that things continue along the same way.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 08-03-2010, 07:09 PM   #12
_
HI RICH!
the mich' is a fine tire and IF it were properly rated for this application...
the 16 inch version is available with MUCH MORE capacity and higher pressure ratings...
and as u know using the 15 is a compromise to keep down the expense of new 16 inch wheels.
_________
but how can u compare mpg, the tv is NEW/different.
and infrared SURFACE temps aren't tire temps, not really....
what is a GOOD tire TEMP anyway? or how high is TOO HIGH, can u tell us?
the hensley means most/any trailer instability is NOT obvious to the driver.
_________
basically ONE RV SHOP is advocating this tire alternative...
the same shop that TOTALLY IGNORES vehicle ratings.
and sends folks out on UNDER RATED grossly INadequate rigs as a matter of routine.
_________
and as suggested it's "too clever" but not necessarily a wise choice in tires.
take ONE SIMPLE CONCEPT like the LOAD numbers ...
these tires have a 'load index' which is not the same as the load rating/capacity for st tires...
in fact the 2 things and LOADing types/values are very different.
but that basic stuff gets TOSSED OUT, just like tv ratings, axle ratings and so on...
it's comical logic and the approach is FULL of false assumptions.
support that is basically "i tried it and everything is OK" only adds to the false security and ILLogical path.
__________
sorta like INCREASING axle rating but going DOWN in tire carry capacity?
the extra axle rating is USELESS when limited by tires and it's the tires that can fail in use.
IF i were to draw/make assumptions based on the horrible tire misadventures u have experienced...
the conclusion would be a FULLY LOADED 30 bunkhouse that gets USED much...
needs MORE than a D rated st tire...
and that's why E rated st tires exist.
__________
additionally 6,ooo miles towing and an N of 1 is meaningless.
tire companies have 100s of thousands of miles of data SPECIFIC to a given model ...
____________
lets make this REAL SIMPLE...
contact a MICHELIN tire engineer or company rep and describe the intended application AND loads ...
then see if THEY give approval for this underrated tire for use on these trailers...
i know, i know... ONE SHOP is smarter than the folks who make the tires AND the trailers...
___________
i've spent ZERO TIME on roadways dealing with properly rated ST tires in ANY failure mode over 5 years...
and with mileage equal to MOST heavy users.
again its JUST an N of 1 but equally as valid for empirical use...right?
cheers
2air'
Old 08-03-2010, 07:23 PM   #13
Dallas , Texas
I'm really tempted to replace the wheels with 16", so I can run 225/75-16 Load Range E Michelin LTX's. I want Michelins, damn it!
Having spent many years working for a major tire company, I'm not convinced Maxxis tires are the answer. Maxxis is a relatively small manufacturer compared to Goodyear or any of the other majors. And, while I agree Marathons are terrible tires, I'm not ready to anoint Maxxis due to the relatively small sample size.
Should the 225/75-16, at 29.4" tall, work on the 30' Airstream?
Old 08-03-2010, 07:33 PM   #14
_
jake...
YES the 16s fit, there are several LONG threads here on this,
including photos and install pics.
((some older trailers need TINY modifications at the wheel well molding lips...it's a minor thing))
and clearance ABOVE and between the tires goes down some, again considered a minor issue.
crawfordgene, artstream, fr8shaker and some other texas folks have gone to 16s without FIT problems...
and i fully agree that the maxxis data is skimpy on this, especially with so FEW of them in use ...
and while the trailer IS currently rollin' on the max' E tires, i've yet to hit the 10 or 20k milage meter for reporting.
but since the gyms have been GREAT on my unit and performed exactly as expected...
it's not clear 2me how the Mz will be better...
cheers
2air'
Michelin XPS Ribs (225/75x16) on our 19-foot Bambi Phoenix Tires 16 01-29-2011 11:32 AM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Any Michelin Tire Experts Out There? Double D Tires 13 03-05-2006 05:14 AM
