Old 06-22-2018, 05:45 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Michelin LT225/75R16
Where do I find date manufactured? I see DOT CODES but see OOYX where week/year should be. Thoughts? This is a new 2018 Classic 33
DeltaRon is offline   Reply With Quote
Old 06-22-2018, 05:48 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Looks on the back side of the tires, near the bead.
Old 06-22-2018, 05:54 PM   #3
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
It is close to the rim of the tire just above the bead. Just follow the tire bead around and you will see it. On the photo it is the numbers on the right.
thewarden is offline   Reply With Quote
Old 06-22-2018, 06:25 PM   #4
DeltaRon's Avatar
Cumming , Georgia
I was hoping NOT to have to crawl under the rig.
Old 06-22-2018, 06:32 PM   #5
Well Preserved
1993 21' Sovereign
The DOT date code is only on one side of the tire. If you don't see the code on the outside sidewall, the code should be on the inside sidewall.
Inflation PSI - Michelin LT225/75R16/E LTX M/S2 PSU1981 Tires 52 07-24-2018 12:52 PM
Michelin LT225/75R16 M/S2 vs. the new LT225/75R16 M/S Defenders. jamieb1086 Tires 4 05-22-2017 04:48 AM
4 Michelin LT225/75R16 Tires and Chrome Wheels warfieju Airstream Classifieds 1 02-24-2016 08:38 PM
Bridgestone BLIZZAK LT225/75R16 tires WheelnStones Tires 10 02-07-2016 09:02 AM
16" Michelin LT245/75R16, Clearance? GCinSC2 Tires 49 03-02-2014 08:46 AM
