Closed Thread
Old 02-15-2016, 04:17 AM   #267
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
One other interesting tidbit. The standard tire in the 70's was a Goodyear Travel Trailer bias ply tire. Rims were steel with wheel discs. The Michelins had enough traction that they would flex the rims when turning sharp and the wheel discs would fall off. Eventually Airstream made aluminum wheels available to correct the problem.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline
Old 02-15-2016, 05:22 AM   #268
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Thanks for the history correction, Andy. The information I posted was what I could find from Airstream's literature archive. I sure helps to have your experience here. Much appreciated.
Lance
Top is offline
Old 02-15-2016, 07:56 AM   #269
Ravenna , Ohio
Originally Posted by Dingo Girl View Post
Page after page of tire speak and I still can't find out why a few years ago on this forum no one ran LT tires.
The hot rubber was the bias ply trailer tire.
What changed? How did LT tires become trailer tires?
IMO there were a few things that changed that accumulated with result being more tire failures on tires as supplied and when looking for alternatives LT are the obvious improvement is many cases.
We have seen highway speeds increase over the past few years but ST tires have a rating (with a few exceptions) of 65 mph max so more people were exceeding the speed capability of the tires.
More features and "stuff" has been added to the load on tires and higher load can result n increased failure rate.
Continued pressure to lower the price (Walmart mentality) has resulted in low cost to the RV company being the primary characteristic of interest not best quality.
The above and similar changes which all negatively affect tire life do add up.
Tireman9 is offline
Old 02-15-2016, 09:23 AM   #270
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Andrew,
Is there a problem with using the Michelins with modern steel wheels. Is there any advantage to aluminum wheels over steel wheels other than appearance?
Grant
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is online now
Old 02-15-2016, 10:30 AM   #271
Gainesville , Florida
Wheel discs equal wheel covers?
xrvr is offline
Old 02-15-2016, 12:38 PM   #272
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
You mean hubcaps?
Rocinante is our 2014 International Signature 27FB
Rocinante is offline
Old 02-15-2016, 12:50 PM   #273
Hubcaps only cover the hub, covers cover the whole wheel. Wheel covers are prone to jettison on sharp corners.
xrvr is offline
Old 02-15-2016, 01:01 PM   #274
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Weight would be my guess?
subfan1 is offline
Old 02-16-2016, 06:45 AM   #275
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Another reason the 700-15 went away is that they were tube type not tubeless and who wants a tube type tire....my 23' avion came with steel wheels and G-78-15....-and steel wheels..
tjdonahoe is offline
Old 02-16-2016, 07:54 AM   #276
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The four Michelin LTX (P) 235/75R15 XL tire's on our 23D are not carrying the same weight on the 3,000 pound rated axles:
Front….1,280……1,246 - total front axle 2,526
Rear…..1,376……1,233 - total rear axle 2,609
Total Axles………………………………….5,135
Thus unless one knows each tire's load, the conservative approach is to use a 15% safety margin in addition to derating these tires to 1,985 pounds from the sidewall 2,183.
The left rear gets the 18 gallon black tank load. Also all the shower and toilet weight is concentrated in that area. The right rear load was decreased about 50 pounds by removing the six gallons of water weight in a tank style water heater and installing an instant on Truma custom water heater and then increased slightly by a better quality 10" Rocky Mountain mattress.
The left side has more load due to the complete solar system controllers and lithium battery system being installed under the street side (left) sofa and dinette seat.
switz is offline
Old 02-16-2016, 08:14 AM   #277
My 84 30 foot Avion also came with either those tires or 700/15 with steel wheels.
xrvr is offline
Old 02-16-2016, 08:16 AM   #278
My 84 30 foot Avion also came with those tires and steel wheels.
xrvr is offline
Old 02-16-2016, 09:29 AM   #279
Ravenna , Ohio
The comments about early (1970's) wheels flexing enough to eject wheel covers when radials were used is an example of why it is important to know if your steel wheels are rated (designed) for radial tire use.
Excess flexing can result in steel fatigue which can result in wheel failure.
As far as I know most cast aluminum wheels made since the 80's are probably OK for use with radial tires.
A side note on wheel failure. I have experienced wheel failure on my race car after about 3,000 miles usage but these were light weight multi 3 piece wheels with cast center and spun flanges that bolted together. Application on a relatively heavy car resulted in fatigue failure. Luckily we were doing magnaflux dye penetrant inspection and discovered the cracks when doing off-season re-build and not during a race.
Tireman9 is offline
Old 02-16-2016, 10:43 AM   #280
The wheel covers will come off in sharp corners because the tire flexes on the edge ofthe rim. That's one reason you see so many older AS and Avions with covers missing.
xrvr is offline
Closed Thread
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Michelin LTX MS2 235/75/15 XL Top Tires 64 07-20-2016 07:32 PM
Michelin LTX LT 235/75-15 JakeSpoon Tires 63 07-03-2015 04:18 PM
Michelin LTX 235/75R15 XL Upgrade? switz Tires 234 06-28-2014 03:46 PM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
