Closed Thread
Old 02-04-2016, 02:08 PM   #197
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
There is a clear picture of a Michelin tire posted in post 135. It says
Max load 2183
Max pressure 50 psi.
So the tire (when mounted on a SUV) will support 2183 lbs at 50 psi. True or False?
It will also support 2183 at 44 psi if it meets the tire association guidelines?
Or is the max load at 50 psi pressure lower than the max load at some lower pressure?
OP- Sorry, this does not deal directly with the Defender but it does with a likely very similar tire that is currently being used and that works well on Airstreams.
Bill M. is offline
Old 02-05-2016, 03:52 AM   #198
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Just to clarify what is our practice over a couple of thousand of these tires over the last 12 years.
When we are running them at or near max load, 19' or 22 Single axle, older 30' Classics, 30 Internationals with upgrades we run them at 50 PSI. They never run warm, flats are extremely rare and I have never seen a shifted belt.
On lighter trailers where they are running well below maximum load such as 23's and 25's we run them 40-45 PSI just to smooth out the ride in the trailer. On a vintage trailer that we are trying to preserve we will weigh the trailer and run them at the load capacity chart pressure. The theory is we would rather compromise the tire life than the trailer structure. On these we are often 30-35 PSI. We don't have a large volume of these out there.
Last summer I used a 27FB for my demo and since we were driving some rough roads at higher speeds I ran the Michelins at 40 PSI. They ran cool as cucumber even at that pressure, I may have given up a touch of fuel mileage though.
I am sure there are other 235 LT tires out there that will work well also I just am reluctant to change when we have such a great track record with these.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline
Old 02-05-2016, 05:50 AM   #199
Gainesville , Florida
Thanks for the clarification. Experience counts, on the road use counts. Thanks again.
xrvr is offline
Old 02-05-2016, 06:00 AM   #200
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by Bill M. View Post
...... So the tire (when mounted on a SUV) will support 2183 lbs at 50 psi. True or False? ........
False, but not for the reason you think. On an SUV, the tire has to be derated by a factor of 1.1, so the max load would be 1985#.
But to try to answer the question as you intended: In one sense it is true. The tire will support that load at 41 through 50 psi.
...... It will also support 2183 at 44 psi if it meets the tire association guidelines? .........
Yes.
...... Or is the max load at 50 psi pressure lower than the max load at some lower pressure? .........
No, but to be clear, if you use a pressure lower than 41 psi, the max load is lower, but between 41 psi and 50 psi, the max load is 2183# (or 1985# depending on what vehicle it is on).
On a personal note: I'm glad Michelin stated it the way they did. To state it like a relationship is somewhat misleading.
CapriRacer is offline
Old 02-05-2016, 06:09 AM   #201
CapriRacer
CapriRacer's Avatar
I'm in the , US
And on a side note:
I think it is best if everyone weighs their trailer - tire by tire if at all possible.
I also think everyone should pay attention to pressure buildup. No more than 10%!
When I was actively racing, part of my "Before Leaving" checklist was to do tire pressures on the tow vehicle, the race car, and the trailer. If I stopped along the way, I did a quick check of the tow vehicle and the trailer. I think everyone should have a checklist and tire pressures ought to be on it!
Old 02-05-2016, 06:19 AM   #202
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
So what then - if anything - happens to factors other than load when at 42-50 PSI?
SteveSueMac is offline
Old 02-05-2016, 01:39 PM   #203
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
My guess would be it is limited to tire wear & fuel economy.
>>>>>>>>Action
Action is offline
Old 02-06-2016, 05:35 AM   #204
Seems this is getting confusing, wasn't this thread about the new defender tire!
xrvr is offline
Old 02-06-2016, 06:57 AM   #205
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Yes, but the new Defender is also an Extra Load (XL) tire, so this discussion of pressure is relevant.
Lance
Top is offline
Old 02-06-2016, 07:06 AM   #206
CapriRacer
CapriRacer's Avatar
I'm in the , US
If by "factors" you mean "performance properties", then:
a) The tire will tend to wear in the center more, but trailers hardly wear tires at all, so this shouldn't be a concern.
b) The tire will have a higher spring rate, which means more impact force will be transmitted through the suspension.
c) The tire will tend to more follow the ruts and grooves in the road.
d) The tire will tend to be more resistant to cross winds.
e) The tire will run cooler - which I don't think is such a big deal unless the heat generation was a problem to begin with
f) The tire will have more speed capability - and that translates into more resistance to failure.
I think that about covers it.
Edit: I forgot to say that fuel economy will be better, but only marginally so.
It was (is?), and this part is discussing what it means when a P type tire states a load and inflation pressure on the sidewall - and the Michelin Defender is such a tire - especially considering this tire is being used to replace an ST tire, where things are stated differently.
Old 02-06-2016, 09:10 AM   #207
W , New England
Thanks. Very helpful. I see you didn't mention anything about "interplay shear" we hear a lot about with double (or triple) axle trailers. In your view - does max pressure (50 psi in this case) offer an advantage there?
I may try mine at 45 PSI this season and see what differences that makes.
Thanks again!
Old 02-06-2016, 11:36 AM   #208
2014 28' International
San Jose , California
SUV or Trailer
[QUOTE=CapriRacer;1745307]False, but not for the reason you think. On an SUV, the tire has to be derated by a factor of 1.1, so the max load would be 1985#.
Yes.
Greetings,,
I have been reading this thread from the begining, over and over and I have to admit that the longest this thread goes the more confused It gets. I thought it has been mentioned before in a previous posting that this thread was exclusively about the performance of these tires on a trailer, air presuure, loads, derating the max load , and so on. But here, quote, " the max load is 2183# (or 1985# depending on what vehicle is on)
So this tire gets derated on a SUV use? or a trailer use?, please explain
Flyingsilver is offline
Old 02-06-2016, 11:43 AM   #209
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Tires not designed for the application should be derated as they are being used on a different application than what was designed.
A passenger tire (The size starts with a P) is designed for a passenger car or some light truck. If the user installs on a non-passenger car the rating was not created for that application. derate it
LT is for light truck application
ST is for trailer application
The tire in question is a P tire.
This is the issue with off topic threads and long threads. Instead of creating a new thread posts are made that are related to the main topic just not the thread topic. In this case the thread topic is Michelin Defender LTX M/S 235/75-15 109T XL. However the answer was made to the tire pictured in post 135. That picture is of a P rated tire, which on a SUV is an application of a tire to a vehicle it was not designed for. A LT tire is designed for a SUV. A "P" tire is not designed for a SUV or light truck application.
>>>>>>>>>Action
Action is offline
Old 02-06-2016, 11:48 AM   #210
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Meaning it's load capacity should be de-rated by 10%. I'm pretty sure we've already established that at least 3 times in this FrankenThread I started .
There's really little more to say on this topic until the tires are available, hopefully in March. Thanks for playing, everybody!
Rocinante is our 2014 International Signature 27FB
Rocinante is offline
Closed Thread
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Michelin LTX MS2 235/75/15 XL Top Tires 64 07-20-2016 07:32 PM
Michelin LTX LT 235/75-15 JakeSpoon Tires 63 07-03-2015 04:18 PM
Michelin LTX 235/75R15 XL Upgrade? switz Tires 234 06-28-2014 03:46 PM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
