Closed Thread
Old 01-25-2016, 06:17 AM   #169
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Originally Posted by Mrjkq View Post
After a couple migraines from this thread, like I stated earlier I'm going with Maxxis 225/75 15R E rated ST tires. Michelin are without a doubt excellent tires & the 15" application will probably do well but yet to be proven unlike the 16" application which are available in LT E rated tires. Maybe Michelins next time when they have a real track record.
Joe,
I have kept up with most of the tire threads on this forum for the past few years and the previous Michelin tire (LTX MS2)with less weight rating has a large fan base with no reported problems except for typical nails or other road debris. If past history is any indicator the newer tire (Defender) should be just as good if not better with the slightly better weight rating. The track record for using a quality passenger car tire is there......
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline
Old 01-25-2016, 07:43 AM   #170
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Originally Posted by CapriRacer View Post
Just an FYI:
I was dealing with a local Discount Tire store when I needed to replace tires on my trailer. They insisted that trailers needed ST tires and refused to sell me P type tires for my trailer. This in spite of the fact that they knew my background and I pointed out that I could show them notes in the Tire and Rim Yearbook where TRA says it is permissible.
HOWEVER, when I brought them new tires I bought from Tire Rack and mounted tires on wheels, they did the exchange without asking questions.
LOL! Arguing with a tire engineer. This post shows you how "smart" the employees of the nation tire stores are.
Lance
Top is offline
Old 01-25-2016, 11:12 AM   #171
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Most sales personnel at the tire stores earn commissions on what they sell. That often colors their suggestions. Personnel staffing the store can experience high turnover rates so their knowledge base can be quite shallow.
The informed consumer who comes in and states exactly what he/she wants based upon his/her experience with the vehicle in question trumps the salesman chatter.
The parting comment os the customer walks out the door:
"Since your store does not wish to sell me what I want to purchase, Adios. I will acquire what I need elsewhere and will not ever be back."
switz is offline
Old 01-31-2016, 02:29 PM   #172
floridalarry's Avatar
1966 20' Globetrotter
Ormond Beach , Florida
Just bought a 1966 20' Globetrotter and it has ST225/75R15 tires. Not necessarily want to upgrade to 16". What LT Michelin would be recommended?
Larry & Linda Scovotto
WBAC #1021
Ormond Beach, FL
1966 20' Globe Trotter
2015 Nissan Frontier SL
floridalarry is offline
Old 01-31-2016, 03:45 PM   #173
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Is that a single or double axle? If single - the Michelin you're talking about has to be de-rated 10% for use on a trailer so it basically carries 1985# per tire. If a single axle, you have 3970# of load carrying capacity though most would suggest you want to leave about 10% "headroom" meaning your trailer (if single axle) shouldn't weigh more than about 3600# loaded for camping. If a double axle, you'd have 7840# of carrying capacity or with some headroom, 7200# loaded for camping.
Given that and the weight of your trailer, you should be able to decide whether those Michelins will work for you or not. As an FYI - my double axle 27FB weighs in at about 6000# on the scales and I use the Michelin 15" tires. I'll be starting my 4th year of camping this spring - only trouble was when I scuffed them on a curb and replaced them out of an abundance of caution (with very few miles on them and an assurance they'd be ok...).
Good luck!
SteveSueMac is offline
Old 01-31-2016, 04:59 PM   #174
AlanMcD's Avatar
Cincinnati , Ohio
I just replaced my LTX M/S tires at only 35k miles. Hated them! Extremely dangerous on wet pavement. I bought them originally because they were so highly consumer rated but man, what a major disappointment they turned out to be. Didn't expect to have to replace them for at least another two years. Put them on new in August of 2013. They had zero traction on wet roads.
-Alan
AlanMcD is offline
Old 01-31-2016, 05:22 PM   #175
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
-Alan
What did you replace them with?
SeaLevel is offline
Old 01-31-2016, 06:00 PM   #176
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
-Alan
You had them on what? This is a discussion about tires on a travel trailer.
Lance
Top is offline
Old 02-01-2016, 06:10 PM   #177
Llando88's Avatar
2016 30' Flying Cloud
Michelin Defender LTX M/S 235/75-15 109T XL
Well shucks, I was going to come back to this thread in March...
So, moving storage spots a couple days ago, I filled up my GYMs on my '16 27FB FC to 65 psi with my inflator.
I ran my hand across the carcass on the rear right tire, and found an odd discontinuity or depression in the sidewall rubber. It was maybe 1/4" in depth, and extended about 1" of the sidewall.
I found a similar depression in one of the other tires.
We've only towed the Airstream from Colonial to Tampa, then one three day trip to Cedar Key FL. No bumps I'm aware of, and kept to 65 mph.
Just asking the experts here (I am not one) how soon do I need to replace the GYMs?
Immediately?
Before our big trip out west this summer?
Sometime later this year?
Thanks!
Rich
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline
Old 02-01-2016, 06:49 PM   #178
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Don't freak out and jump to conclusions based upon some opinions on the forum...but make an educated analysis.
http://www.tirerack.com/tires/tirete....jsp?techid=32
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is online now
Old 02-01-2016, 07:01 PM   #179
SeaLevel's Avatar
Jupiter , Florida
Very timely post. I have noticed the same indentations in the sidewalls of my still new GYM tires, and it's good to know that it's normal for a radial tire.
SeaLevel is offline
Old 02-02-2016, 06:32 AM   #180
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by Llando88 View Post
........I ran my hand across the carcass on the rear right tire, and found an odd discontinuity or depression in the sidewall rubber. It was maybe 1/4" in depth, and extended about 1" of the sidewall.
I found a similar depression in one of the other tires. .......
Just asking the experts here (I am not one) how soon do I need to replace the GYMs? ......
Rich
Those depressions are nothing to worry about. They are called indentations and you can find at least one in EVERY tire, if you look hard enough. They are the overlap of the ply cords, It's actually stronger there than in the other spots.
But to answer your question about age, there is some disagreement, but most folks say that tires on trailers need to be replaced every 5 years. You car and truck are different and that range is 6 to 10 years.
CapriRacer is offline
Old 02-03-2016, 10:27 AM   #181
Llando88's Avatar
^^^ Got it. Thanks. Rich
Llando88 is offline
Old 02-03-2016, 10:59 AM   #182
interstateflyer's Avatar
2017 25' International
Los Osos , California
Originally Posted by switz View Post
Andy at CanAm suggested I run 44 psi in the 15" Michelin LTX (P) 235/75R15 XL tires on the 2013 25FB. I use 44 psi now on our 2015 23D (which has a 1,300 pound lower GVW than the 25FB) with the same sized 15" Michelin tires .
I have the same tires on my 2014 23D. The side walls say 50 PSI for 2185 max load. I'm wondering why Andy suggests 44 PSI.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline
Closed Thread
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Michelin LTX MS2 235/75/15 XL Top Tires 64 07-20-2016 07:32 PM
Michelin LTX LT 235/75-15 JakeSpoon Tires 63 07-03-2015 04:18 PM
Michelin LTX 235/75R15 XL Upgrade? switz Tires 234 06-28-2014 03:46 PM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
