Old 09-01-2012, 09:06 PM   #29
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Michelin says load index 108 means 1000 kg (2200 lb)
TireRack says 2185 for the specific tire (look here and click the Specs tab)
In this overall definition of load indexes TireRack says 108 is good for 2205 lb.
Discount Tire lists the same 2205 lb for 108 load index, as does Firestone.
— David
Old 09-01-2012, 09:23 PM   #30
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
From the tire
Originally Posted by Doug C View Post
The local dealer and some internet sites list the capacity of the LTX M/S2 P235-75-15 108T at 1985 pounds. Does it say 2183 pounds right on the tires? If they actually can carry 2183, I'd have a lot more reserve carrying capacity. I've got to have tires on within a week so I'll have to make a decision pretty soon. I'm leaning toward these Michelins.
It says "max load 2183lbs at 50 psi" on my tires.
Lance
Top is offline   Reply With Quote
Old 09-02-2012, 12:25 PM   #31
1981 31' Excella II
New Market , Alabama
I think the 1985lb is the derated value of the 2185. Your supposed to derate the load rating by 10% if you use a P rated tire on a high profile vehicle like an SUV or RV. I don't know how you classify an Airstream since it has a low center of gravity. You get 1986lb if you devide 2185 by 1.1. If it is already rated for LT use then 2185 is a good number.
You won't have any problems with any tire rated 108T or an XL rating. My trailer tops out at 7000lbs and I am having no issues.
Perry
Old 09-02-2012, 02:26 PM   #32
Enthusiastic New AS'r
3campers's Avatar
1985 31' Limited
Glenville , New York
Images: 18
Yes it says it right on the tire!!!
1985 31' Limited
2003 GMC Sierra HD SLT 4x4
3campers is offline   Reply With Quote
