08-04-2017, 03:08 PM
#21
2016 19' International
Orange County
Originally Posted by CRH
TR416
I bought those at O'Reillys.
Thanks! I just ordered the same ones from Amazon based on your recommendation!
08-05-2017, 07:03 AM
#22
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
Mine will arrive today.
08-19-2017, 01:49 PM
#23
Hiawassee
, Georgia
Valve stem update
I checked with AS support and they also said get the TR416's. So I did. The washer is slightly too large to fit down into the well for the valve stem.
VS-902WP-1 is the one that works for mine. My AS is a 2017 FC manufactured in late 2016. I guess specs on the wheel might have changed from the supplier.
The stem comes with an extension (shown) but is not needed.
08-19-2017, 02:01 PM
#24
1976 31' Sovereign
Oswego
Any tire that uses more than 35lbs. air should have uncovered metal stems IMO. All my rolling stock uses uncovered metal stems regardless of pressure used or there usage.
08-19-2017, 02:11 PM
#25
Hiawassee
, Georgia
Got mine so I can install a TPMS. I wish AS would just go with metal stems and not make the owners go thru the hassle of researching replacements and getting them installed. On a $60K+ trailer you'd think AS would spend a few extra bucks for metal stems
03-27-2018, 04:36 PM
#26
Tampa
Okay, now that we have metal stems, I looked into a way of installing them myself.
There's some pretty clever ideas on YouTube, usually involving a floor jack and a ratchet strap.
03-27-2018, 08:22 PM
#27
2013 19' Flying Cloud
2018 23' Flying Cloud
Lincoln
, CA
My 2018 Flying Cloud has the 15" Sendel T02 wheels and GYE Tires. I'm adding TPMS, and also wanted to know compatible metal valve stem for this wheel. I ran across the eTrailer website, and their Q&A section answered this very question. They recommend the Americana Metal, Bolt-In Valve Stem 1 1/4" long part number AM20906. I'm sure there are other valve stems that will work, but this is the recommendation from one of the Sendel wheel distributors.
03-27-2018, 10:08 PM
#28
1995 25' Excella
xxxxx
, xxxxxx
I changed mine myself. I used a manual tire changer from Harbor Freight to break the beads.
03-27-2018, 10:41 PM
#29
Tampa
They have a bead breaker only for about $50.
Did you escape dinging the rims when using the tire changer?
Growing up on a farm, my dad just drove over the tire with the tractor. Bead gave up.
03-27-2018, 10:46 PM
#30
1995 25' Excella
xxxxx
, xxxxxx
I use that bead breaker to break the beads on my fancy chromed motorcycle wheels. Never scarred one up.
03-27-2018, 11:12 PM
#31
Tampa
03-27-2018, 11:40 PM
#32
2007 22' International CCD
Corona
Metal Valve Stem on Endurance Tires
Very simple. Just have to support the trailer A-frame with something solid, like a sturdy jackstand or two, and away you go. I’ll bet the gadget doesn’t weigh much either.
Sadly, he’s in Queensland, Australia, and does not seem to have a US sales channel. Darn it!
I’d bet just using a stand and my jack foot could do it...or my bottle jack under the hitch on my hooked-up truck?
More than one redneck way to do it, and lord knows I’m qualified...[emoji3] Easier than beating it with a BFH and risking dinging the rim, huh?
Or, of course, wait for AAA to arrive...
