Old 02-18-2008, 04:02 PM   #15
1994 30' Excella
Mississauga , Ontario
Seems to me that you don't want to inflate the tire more than is required to safely care the load. Inflating more than is required only makes for a harsher ride and that is a whole other discussion.(rivets etc.).
Al
Old 02-19-2008, 01:22 AM   #16
JDL
JDL's Avatar
2005 19' International CCD
T , Oregon
All,
I have been following this thread for some time. Two questions come to mind:
1. Has any one running Maxis tires had any problems? (I assume no..)
2. Does anyone running maxis load range D tires notice a stiffer ride? I get the impression per the article quoted from Silvertwinkie that they may. However I do not necessarily believe everything our friends that manufacture tires say - "nylon caps produced a more rigid tire with a rougher ride." My ride is stiff enough as it is now and I do not want to make it any worse.
I have a 19' bambi CCD and considering that I have a single axle I plan on replacing my Goodyear Marathons this year with a pair of Maxis tires. My Marathons are 4 years old this April.
JDL is offline   Reply With Quote
Old 02-19-2008, 08:03 AM   #17
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I think Eric's concern was going to the E rated Maxxis rather than sticking with the D's. I don't believe you should be concerned about this assuming you stick to the D rated tires. If the nylon cap keeps those belts from squirming, all the more to it. At this point my slide out is the heaviest trailer that Airstream builds on a tandem axle. After the failure of a Marathon, I felt the extra weight capacity that the E rated tires provided was worth the upgrade.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-20-2008, 03:09 PM   #18
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Tires for 76 31' A/S
What would be the recommenced Maxxis ST tire size and load rande for my 1976 31' A/S? Thanks guys
Don Hardman
adonh is offline   Reply With Quote
Old 02-20-2008, 03:16 PM   #19
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Don Hardman
If you know the GVWR of your unit, then add the weight rating of the D tires which is 2540lbs per tire x 4. If the total weight of your 31 footer is close to or exceeds what 2540x4 equals, then you'd need to go to the E tires.
My guess is that a 31' 70s unit weighs less than my 2004 25' (6300lbs), so I'm thinking you'd be well under the max total capacity of the D rated tires....
Old 02-20-2008, 03:26 PM   #20
adonh's Avatar
1976 31' Sovereign
Thanks that what I was thinking, D rating. Maxxis ST225/75R15.
Here in the Houston area I see that Discount Tire has the Maxxis tires. Now all I need to do is decide if I need the axles replaced which I am looking into now. Of course aluminum wheels would be great to. When does the government "stimulus" check get here?
Don
Old 02-20-2008, 03:53 PM   #21
Aluminut
2004 25' Safari
. , Illinois
Don
I think in April or May...I wonder if we'll have to pay tax on it next tax year.
If so, would that mean it's only really $420? That's not even enough to get 4 new Maxxis tires!
Old 02-20-2008, 05:47 PM   #22
holland , Michigan
I have an o4 28 safari on the original marathons. Sitting in roswell and you guys have me worried. To be honest the PO never used the unit and I see no side wall cracks. I have put 15k miles on it since Oct. Heading to Ft.Collins tomorrow and off to Michigan. I have a spare, am I crazy???
safari 28 is offline   Reply With Quote
Old 02-20-2008, 06:30 PM   #23
Aluminut
2004 25' Safari
. , Illinois
The tires can fail without warning from what I've read. JCanavera, whom I know is up on all the maint on his unit had a tire fail. I would not worry a lot, but I am planning on replacing my 4 year old tires this summer, even though they look fine. Looks can sometimes be deceiving.
Old 02-20-2008, 07:09 PM   #24
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You can get 4 ST 225 75 15 D Maxxis M8008 ST Radials tires from Discount Tire Direct for under 400.00. I bought 4 last spring (still sitting in the garage on new wheels) - they were 369.00 delivered to the house. That includes 10.00 per tire for the extended warranty.
They don't show Maxxis on the web site but they had them when I called.
Home - Discount Tire Direct?
Old 02-20-2008, 08:27 PM   #25
JimGolden's Avatar
1977 31' Excella 500
I got my spare from Unser tires online. They cut me a good deal. I have the D rated 235's on my Avion. They're working great so far. A really nice running tire. I don't think you'll go wrong with them.
- Jim
JimGolden is offline   Reply With Quote
Old 02-24-2008, 08:02 AM   #26
jcanavera's Avatar
Fenton , Missouri
Images: 143
No, but you are near the end of the life cycle of those tires. Mine were manufactured in '03 and I had planned to replace them before my first outing this spring. Unfortunately as Eric noted above, I lost a chunk of tread returning from the Branson rally last fall. That accelerated my replacement schedule and I did the replacement prior to my Florida trip in November.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-24-2008, 09:05 AM   #27
Aluminut
2004 25' Safari
. , Illinois
Thanks for the info Gary. I will give them a call. Looking at the site, if I need them installed and want any road hazard type warranty, it's $30/tire, so my total cost, unless I can find a place to install them for less than $20/tire is going to be about $120.00 more than the current delivererd cost.
I may call the local shop to see if it's any better on the mounting, going through the retail store and having them do the ordering and such.
Old 02-24-2008, 06:33 PM   #28
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Send a message via AIM to eikel1we
I guess we made a mistake buying Marathons in June of '06. We figured there are around 6000 mi. on them after Ike found a bulge in the outer sidewall after we arrived in Gulf Shores. We now have a new tire and the others have been checked on the inner sidewalls as well. Should those tires be renamed Scare-a- thon???
sue
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Maxxis Tires Darrell Root Tires 2 07-10-2006 06:16 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
Pump keeps running Alden Miller Water Heaters, Filters & Pumps 6 08-03-2005 07:55 AM
furnace keeps running wfdyer Furnaces, Heaters, Fireplaces & Air Conditioning 6 01-26-2004 11:32 AM
Running AC question... Sneakinup Furnaces, Heaters, Fireplaces & Air Conditioning 8 09-12-2003 08:53 AM
