Old 06-02-2008, 02:24 PM   #1
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Maxxis Tire Tread Separation
Not quite but only because I caught it just in time. Was doing a general trailer inspection and one of the tires didn't look right - in fact it is a mess. Entire tread center is bulging out and there are several big chunks of rubber missing from the tread area. These are ST225 75R15 "E" load range tires. They are a bit over a year and a half old and have been run at 70 lbs. Mileage is between 15 and 20K. Messed up tire is on the road side. Don't know just what caused this as I've been paying pretty close attention to these tires. I think this is the same tire I got a screw in last July and it had to be plugged. Can't remember any serious holes or other road hazards I've run into lately. Or maybe it was just a defective tire. Or maybe there is some other reason I'm not aware of. So those of us who bought the stronger "E" rated Maxxis are not out of the woods as far as the tread separation problem goes. Sorry but I don't have any way of posting a picture - I'm probably the last person in the world who doesn't own a digital camera - or any camera for that matter.
Al - K4GLU is offline   Reply With Quote
Old 06-02-2008, 02:36 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Not the best of news...but thanks for posting the info....
Old 06-02-2008, 02:51 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
For future reference, a plug is considered a temporary repair, and should be replaced with a patch as soon as possible. The plug can force the steel belts apart, encouraging separation.
Old 06-02-2008, 02:52 PM   #4
1973 25' Tradewind
Romulus , New York
These tires need to be repaired with a patch on the inside. Even then there is a possibility for air to get in between the tread and the belts. This causes a bubble which then throws of chunks of tread off the tire. The worst part of this is the vibration which will shake your coach like crazy. Bias ply d rated tires don't do this and were the tires of choice for years. Much stronger sidewalls and long tread life to boot. Bias tires age and crack long before tread wears out.
I think your troubles started when you had the tire "plugged"
jayray5 is offline   Reply With Quote
Old 06-02-2008, 03:03 PM   #5
It's possible I'm wrong about the plug. That may have been a slip. The tire was repaired at a tire shop and I assume they did it correctly. Pardon the possible slip. However if it was plugged and didn't have a patch applied guess that might have been the problem.
Old 06-02-2008, 03:24 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Did you get a chance to look inside the tire? Any sign of a patch? The fact that it was the one that had picked up the screw says that obviously there may have been more damage than you realized or the repair didn't make things right with the tire. If anything it's a smoking gun.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-02-2008, 03:40 PM   #7
LoydBonifide's Avatar
2003 30' Classic
Londonderry , New Hampshire
It figures. I just signed for the delivery of 4 Maxxis this afternoon, unwrapped them, checked out my free Maxxis sport water bottle, cracked open a cold one, and decided to check out the forums.
Now this thread.
My GY Marathons are 6 years old, and have never been a problem. But I am on the verge of a Boston to LA round trip, followed by a Boston to Florida rount trip. After reading the the plethora of threads on the tire failure subject, I determined that I would replace them with the Maxxis, which draw high praise on the forum. In all the discussions, I did have a nagging recurring thought. There is a vast population of GY marathons in use, are the failures statistically insignificant? I am sure that the population of Maxxis in use is far smaller, so does this failure negate the perceived better performance of the Maxxis?
I am not well schooled in statistics, I am sure someone out there is. Am I thinking too much? Is it time for another cold one?
LoydBonifide is offline   Reply With Quote
Old 06-02-2008, 03:45 PM   #8
Aluminut
2004 25' Safari
. , Illinois
Now this thread.
I'm right there with you......
Just got my Maxxis water bottle with 4 tires about a month ago and have about 700 miles on mine.
Old 06-02-2008, 04:01 PM   #9
Well I haven't given up on Maxxis. The same place that answered my road service call didn't carry them but they could order Maxxis tires and I've got a new one on the way - should be here on Wed. But if I should have yet more problems - then where do I turn? I've only been RVing 8 years - first 6+ with a Casita and the AS going on 2 and I've had many tire problems - Carlisle, GY Marathons and Tow Master on the Casita and now Maxxis on the AS. I'll admit that before my first failure - which was a Carlisle - I didn't pay much attention to the tires beyond looking to see if they still had air in them but after the first tread peeled off I've kept pretty close track of things and even that doesn't seem to be doing any good. Am I snake-bit? About 5 weeks ago I picked up a nail in one of my truck tires. Fortunately it didn't lose much air and was able to get it to tire shop. Will it never end?
The damaged Maxxis is still on the rim - in fact it still has air in it. When it gets broken down on Wed I'll take a look at the inside and see what it looks like where the repair was.
Old 06-03-2008, 01:36 PM   #10
Area 63 Productions
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
Send a message via Skype™ to Area63
Thanks for sharing this.Please keep us informed on the defective tire.
Uwe
www.area63productions.com
Area63 is offline   Reply With Quote
Old 06-04-2008, 02:41 PM   #11
Got my new tires today. I ordered two new "E" Maxxis and I'm glad I did as the other tire on the trailer was also looking a bit worn. Sorry but I got in a hurry and completely forgot to look inside the badly damaged tire and see if it was the one that had been repaired. Didn't even think about until I was back at the campground.
Was told by the people who put the new tires on that the old ones appeared to have been very poorly balanced as both had 3 weights at different places on the rim. Not sure if this could have been a factor - a lot of people say it isn't necessary to balance trailer tires.
Interestingly enough the total cost of tires/installation/balance/new valve stems was less than the cost of the first set of tires alone that I ordered direct from Maxxis and had shipped to me UPS - and I then had to pay someone else to mount. Probably explains why Maxxis can afford to give away their little gifts with the tires they sell direct.
Old 06-04-2008, 03:02 PM   #12
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
One of my good friends, a long time Airstreamer who is meticulous in checking his tires runs Maxxis @ 70 lbs. pressure on his newer 30' Limited. He had one blow and do extensive damage to his trailer's road side. He went back to the factory to have his trailer repaired a few weeks ago. I don't know what tires are the best. I've always ran Goodyear Marathons and so far haven't had any problems though I've read of all the problems others have encountered and am in no way touting one brand over another. We put on over 15,000 miles last year with the Marathons. I worry every time I hook up that this will be the trip, but so far trouble free.
GStephens
GStephens is offline   Reply With Quote
Old 06-04-2008, 03:06 PM   #13
jcanavera's Avatar
Fenton , Missouri
Images: 143
They need to be balanced...no doubt on that. Not all manufacturers balance their tires though. I bought from a rural dealer about 140 miles from here since there was no dealer in the metro St. Louis area that I could find, that handled them. My neighbor who was in the area at the time picked them up for me. The cost for 4 E's was around $380 or so with tax. I paid $15 a wheel locally for mounting, balancing and disposal of the old tires.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-04-2008, 03:31 PM   #14
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I thought one of the factors in the Marathon issue was the date of manufacture and more importantly, country of origin...I thought the bad ones came from China and the good ones were made in Canada and U.S. No, nothing political in this post, just memory which can be flawed at times.
Family of Disney Fanatics
WBCCI# 4821
Maxxis Tires Now Running jcanavera Tires 36 09-20-2010 03:55 PM
Body Separation HowieE Repairing/Replacing Floor &/or Frame 88 07-05-2010 04:28 PM
Goodyear Marathon tread separation ... and our solution RossFam05BH Tires 226 06-26-2010 10:27 AM
Maxxis Tires Darrell Root Tires 2 07-10-2006 06:16 PM
Underside damage truck tire tread - 2004 Classic gklott 2001 - 2005 Classic 1 06-11-2004 08:15 PM
