Old 08-25-2016, 12:08 PM   #71
Tom T
Tom_T's Avatar
Orange , California
Originally Posted by cole3444 View Post
After reading the post on this subject it seems the Maxxis tires are a descent tire. I have a 1972 31' Sovereign and need to get tires since my rebuild is almost complete and was wondering which load range would be better. I am looking at the ST225/75R15. Airstreamer67 can you add anything on this since you have ran these tires. Thanks
Cole,
I would think that the E rated (10PR on some charts) would be needed on a 31 footer AS, but what you'll really need to do is take the total gross trailer wt. of your rig, divided by the number of tires on it, & then get the tire load rating higher than that per tire/wheel load.
It's a matter of the max. weight a particular tire size & PR/LR is rated for, cuz they all vary, as you can see in the Maxxis load chart in the article, & at the one on their website, both at the links which I provided above.
This is true no matter which brand, tire model, ST, LT or for your cars/trucks.
Sounds like a nice Resto! Maybe we'll see it featured in a future "Vintage Camper Trailers" magazine!
Cheers!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner)
Tom_T is offline   Reply With Quote
Old 08-25-2016, 12:58 PM   #72
Tom T
Tom_T's Avatar
Orange , California
FYI - I inspected my 1960 Avion T20's & 1988 VW Vanagon CamperGL "Westfalia" Maxxis tires, & these are the specs & place of manufacture for them below:
1960 Avion T20:
Maxxis M8008 ST225/75R15-D 8PR speed rated for 65 mph, load rated for 2540#@ max. 65 psi, DOT date coded for late 2011 (installed July 2012) & Made in Thailand - No sidewall nor tread cracks, No Bubbles nor visible defects, nominal tread wear (with gauge still at nearly new depth) - after 4 years & under 16,000 miles.
The Avion is single axle & was rated dry/empty/without options at 2680 lbs & 285 lbs. HW, but as currently set-up/restored/wet/loaded has a 542 lb. HW & is about 3000-3500 lbs (no max. GTWR was listed back then, but I'd assume 4500 lbs, but have no idea where you'd put all that to get to 4500!)
1988 VW Vanagon CamperGL "Westfalia":
Maxxis UE-168 LT 205/70R14C 8PR 100/102Q (load index 100 = 1764 lbs & 102 = 1874 lbs., speed rating Q = 99 mph), rated for 1874 lbs @ max. 54 psi (IIRC the 100 = 1764 is for 35 psi), DOT date coded for Dec 2013 (installed March 2015) & Made in Taiwan - No sidewall nor tread cracks, No Bubbles nor visible defects, nominal tread wear (with gauge still at nearly new depth) - after 1.5 years & under 8,000 miles.
Our non-synchro VW Vanagon CamperGL Westfalia (full camper version) was rated at 5160 lbs GVWR, & oddly enough rated to tow 2200 lbs & 220 lbs. HW out of a wheezy 4-banger which can barely do 0-60 in 20 minutes!
Note that 14" tire sizes for classic cars are getting harder to find, & especially so for an LT rated for the needs of our VW Vanagon based full camper, & this exceeds the 98 load index from the factory Michelins which are NLA.
And before you newer AS folks get your noses out of joint about why info about an old VW Van is being posted here -
1.) It is a Class B Van based RV with California HCD certification, which makes it & all trailers/RVs eligible for 10 year "RV/Mobile Home financing" - just as are the AS MBZ based units today;
2.) With the very low production numbers of the full camper pop-top Westfalias, they are now very collectable - as are vintage AS's etc. - & the Splitty era earliest Westy's are getting in the $150-200,000+ range, while the middle Bay Window era Westy's are in the $100,000s range, & the later Vanagon era are in the high 5-figure range now, with some of the 4WD Synchro's passing $100k (ours is 2WD);
3.) Therefore, in it's fully restored state I expect it to be valued/appraised at $50,000 -$75,000+, which you can see at the GoWesty.com website under their recent sales for restored Westfalia full campers.
So our little one owner restored Westy is certainly in the same league by value & collectablilty, as are any of your vintage or newer AS's, & certainly deserves mention here on the stock size LT tires available for them, since there are other members out there with Westies!
Cheers!
Tom
Orange CA
Old 08-25-2016, 01:01 PM   #73
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Oooh, ow, ow, facts and figures! Yikes!
Nice details, thanks.
Rocinante is our 2014 International Signature 27FB
Rocinante is online now   Reply With Quote
Maxxis Tires -Load Range? Wingeezer Tires 43 12-11-2010 01:35 PM
Maxxis Tires Now Running jcanavera Tires 36 09-20-2010 03:55 PM
Help with tires maxxis krlajwvater Tires 10 03-09-2009 05:51 AM
I cannot find MAXXIS tires! Chitown AirStreamers Tires 6 08-21-2008 06:20 AM
Maxxis Tires Darrell Root Tires 2 07-10-2006 06:16 PM
