Old 08-23-2016, 04:35 PM   #57
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
After ST tire failures twice, I am hedging my bets with LT tires.
I have had p-rated tires fail, but not within 3 years.
When I have had a P-rated tire fail, the tires were very old- way beyond 5 years.
The ST tires failed within 3 years.
I ignored all the anecdotes until it happened to me.
Then my opinion was formed not based on anecdotes, but personal experience.
I don't recall ever having an LT tire fail, but have had 2 blowouts on Michelins of unknown age or unknown road debris.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-23-2016, 05:52 PM   #58
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Tires & Guns...both get everyone on this forum all fired up, every poster is an authority of sorts including myself. So, let's respect every opinion because after all we all know it all......I like Maxxis, I own a Glock, my choice not yours!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 08-23-2016, 07:18 PM   #59
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by Mrjkq View Post
Tires & Guns...both get everyone on this forum all fired up, every poster is an authority !
What, excluding hitches?
Insert smiley face here.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-23-2016, 08:24 PM   #60
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
For what it's worth we have Maxis tires on some of our SOB brands. We found the reliability to be similar to Marathons so not great.
Interesting we are on a trip at the moment and due to a last minute trailer change I am running marathons on a 26U. Another unit in or group is a 2012 19 Flying Cloud running P235/75 x 15 Michelins. When following them both the 19 bounces less than the 26. Which really shouldn't be. As well the 26 is on a smoother tow vehicle.
Besides the virtually perfect reliability record I think the biggest benefit of the 235/75 x 15 Michelins is the reduced road shock in the Airstream.
There may be other tires just as good but when we have had such a great track record with a product it is hard to justify experimenting with something different.
Other than a few heavily loaded classic 30's Airstreams are not heavy enough to make E range tires ride properly.
I hope this helps.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 08-23-2016, 08:45 PM   #61
m.hony's Avatar
2013 30' Classic
...and tow vehicles...
TAC #MS-10
Airforums #70955
Old 08-24-2016, 03:01 AM   #62
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by SeaLevel View Post
These tire threads are a hoot. So I do a google search for "premium tire brands", and what do you know, I find a listing of what a source considered the top 5 premium brands, and guess what? Goodyear was on the list, and they make an ST tire. But this thread is about Maxxis ST tires, and I will consider them when it's time to replace my current tires. Note: I prefer towing at 65 MPH or less.
Goodyear is a second rate line. Same with Firestone. The "premium" lines are Michelin and Bridgestone.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 08-24-2016, 09:03 AM   #63
2014 25' FB International
Metuchen , New Jersey
Andrew T
Hi Andrew,
I'm a bit surprised you're using 15" Michelins when all I've read on these forums were people switching out to 16". Have you tried the 16" as well? I would love to know what your experience has been.
Your insight is always appreciated.
GenXair is offline   Reply With Quote
Old 08-24-2016, 09:37 AM   #64
Airstreamer67's Avatar
I bought a new set of Maxxis STs last year after experiencing great performance out of a previous set that had lasted eight years.
Airstreamer67 is offline   Reply With Quote
Old 08-24-2016, 09:48 AM   #65
Holly Springs , Mississippi
When I got a call from the Factory to ask "...how's it going with your new Airstream?," I grumbled about the lug nuts and the GYM tires. The TechRep suggested I consider Maxxis as replacements for the GYM's, but didn't indicate AS was considering an OEM change away from the GYMs. As for the lug nuts, AS is considering alternatives to the two-piece ones, and I believe will make that change in the not distant future.
2016 FC 25' FB-twin
2013 F-150 CrewCab 3.5 Ecoboost 4X4 3.55 Lariat
Bob662 is offline   Reply With Quote
Old 08-24-2016, 03:39 PM   #66
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the original lug nuts will last forever if you use a 1/2" drive, 6 point, thin wall, 3/4" / 19mm, deep impact socket.
Short, worn out, sloppy fitting, wrong size, or 12 point sockets will destroy these lug nuts and any other lug nuts made.
The right tool always works better.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-24-2016, 05:17 PM   #67
Originally Posted by ROBERTSUNRUS View Post
...the original lug nuts will last forever if you use a 1/2" drive, 6 point, thin wall, 3/4" / 19mm, deep impact socket.
Absolutely right, assuming they weren't mangled at delivery. Two of mine were, and three others were just cracked---all as they came from the Factory. I didn't want to be on the side of the road somewhere, swearing at lug nuts that won't come off. The replacement cost was insignificant compared to the inconvenience of being stranded.
2016 FC 25' FB-twin
Old 08-24-2016, 06:46 PM   #68
1971 31' Sovereign
1972 31' Sovereign
1967 22' Safari
Soddy Daisy , Tennessee
Maxxis Tires
After reading the post on this subject it seems the Maxxis tires are a descent tire. I have a 1972 31' Sovereign and need to get tires since my rebuild is almost complete and was wondering which load range would be better. I am looking at the ST225/75R15. Airstreamer67 can you add anything on this since you have ran these tires. Thanks
cole3444 is offline   Reply With Quote
Old 08-24-2016, 07:18 PM   #69
Ray Eklund's Avatar
2014 25' International
Castle Rock, CO & Boulder City, NV , Colorado
I do not know any of the previous posters on this thread.
Some could be among those who could navigate around roofing nails on the highway and drive over a roadless mountain without damaging their tires... or trailer.
Some may be like those seen at RV Parks and pulling out of gasoline stations wreaking havoc with sharp turns as their tires squeal in anguish. Others leaving rubber 'kisses' along side curbs and pulling their tires over broken objects in the road. Some drivers having no idea where their tires or trailer are tracking on the road or pavement and hit every pot hole in the process.
Large RV's pulling their vehicles over curbs and thru bushes at parking lots is another... visual to experience!
At Jackson Center, OH, watching trailer owners backing into a spot was a good education in what people say and what they do not know they are doing. Some trailer owner's tires were rippling on the sidewalls, when at right angles to their tow vehicle and backing into a concrete slab. After five days... we saw enough to be skeptical of statements being made and accept them as proof beyond doubt.
MY statements also should be suspicious and incorrect....
Myself... I prefer to do, watch and learn from all sources of information. I take many posts with a 'grain of salt'. Possibly two grains. Take my statements with a grain of salt, although my mistakes are admitted.
FOURTEEN INCH C Rated Marathons are a poor excuse for any use for an Airstream.
Fourteen inch Maxxis and Tow Masters served my 23 foot Airstream well. The only complaint is the amount of tread on these tires... little.
I never had an issue with Marathon FIFTEEN INCH tires during the limited time I had them on my 2014 International. Although from previous experience with the 14 inch C Rated, and both having minimal tire tread compared to any LT Michelin... I paid to be confident while traveling highway speeds.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 08-24-2016, 07:18 PM   #70
Mrjkq's Avatar
Venice , Florida
Cole3444, I use the Maxxis E rated 8008 tires on my 25 ft AS. We just completed a 10,000 + mile trip. The tires are inflated to 75 psi using nitrogen in lieu of air, they preformed without a flaw in temps ranging from 60 to 110 degrees.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Maxxis Tires -Load Range? Wingeezer Tires 43 12-11-2010 02:35 PM
Maxxis Tires Now Running jcanavera Tires 36 09-20-2010 04:55 PM
Help with tires maxxis krlajwvater Tires 10 03-09-2009 06:51 AM
I cannot find MAXXIS tires! Chitown AirStreamers Tires 6 08-21-2008 07:20 AM
Maxxis Tires Darrell Root Tires 2 07-10-2006 07:16 PM
