Little damage to both sides of AS. Mostly cosmetic and can be repaired by me so it is not visible. Very relieved that it was not worse. I will get under trailer as soon as I have time and will post pictures. One thing that I don’t understand. I felt the first blowout at the same time the pressure monitor started squealing. My spare still has rubber valve stems and I was afraid to put the TST pr ensure sensor on that stem. With one sensor removed, the display kept chirping every time it sensed the missing sensor. Our two Yorkies did not like that and continuously barked. So, I turned off the TST. When the second tire blew, I felt nothing. Both were front tires. If a passing motorist had not pointed at the tire, I would have kept driving. By the time I stopped, only the beads and about 2” of the sidewalls were still on the wheel. So rubber dust is on the back of the AS. Go figure.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
