07-06-2006, 10:50 AM
1980 31' Excella II
Stonewall
, Mississippi
Marathon and other side-wall failures
We have just bought a 31', 1980 Airstream Excella A, and are needing to buy tires.
Bringing it home we had a tire blow out, did some damage to the rv, tires were the maraton, after reading post here, the only ones I see recommended are Cooper and Tow Master.
Our old tire size is ST225/75R15.
Any assistance would be appreciated.
Alice Crane
07-06-2006, 12:00 PM
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Alice, there's nothing wrong with Marathons, per se. Trailer tires tend to see more abuse from curbs and other hazards. That abuse tends to cause sidewall separations and other problems. Often, a visual check of the tires, inside and out, will find bulges and other potential problems before they cause a blowout. I have one Marathon on my 34' that has a sidewall bulge. It needs replacing before I take it on any lengthy road trips. The sidewalls on trailer tires are also subject to a greater amount of deterioration from UV exposure as they tend to sit out unused more than car or truck tires. That degredation also causes failures. Many folks recommend replacing your trailer tires every five years regardless of treadwear for those reasons.
Good luck!
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
07-06-2006, 12:11 PM
1960 24' Tradewind
santa barbara
Just yet another case where a marathon bit the dust.You need to recognize
that these tires do have some issues with failures ,Looking the other way pretending it isn't happening is unwise .Many marathon failures recorded on many rv websites .Im sure the weight of the coach is a determining factor.
I would take that blown out tire to someone who can inspect the damage to
check for tread separation etc. They cannot handle the weight of larger trailers.Probably ok on a safari or bambi etc. lighter weight .It is a red flag
pay attention theres a real problem here .When was the last time anyone posted that their towmaster or hercules bias tires failed ,or any michelin ??
Never that I have read .I do not see that great of a tire with the marathon .
Its apopular choice by recommendation ,I won't get near them .
Scott
07-06-2006, 12:35 PM
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley
my friends with black helicopters and little aluminum hats, who have read voluminous rv threads in regards to marathon tires, are convinced that the tires are a "no buy". our resident expert didn't ask how old the tires were, how long they sat in the sun, and or were they abused by the previous owner(s). what load range were they? who checked the tire pressure B4 the trip home? who inspected the tires B4 the trip home? i have the marathons on my 50k airstream, and when it's time to replace them, i'm not going to be looking at anything else... opps... gotta run, my moonbeam is here...
07-06-2006, 01:08 PM
1978 24' Argosy 24
Woodinville
How old are the tires? There's a date code molded into them on the side wall. I'm in the market for tires too so I'd really like to know if they are relatively new or original equipment 1980 tires. Also would like to know how much use the trailer had prior to you buying it. Were the previous owners actively using it or had it sat in one place for some time. The fact that it blew out the first time you used the trailer makes me suspect the tires had been sitting in the same position supporting the weight of the trailer for some time which will cause any tire to fail. And did you check the tire pressures before towing it home? How many PSI were they inflated to?
ST225/75R15 doesn't tell the whole story for trailer tires. You also need to know the load range. They could be C or D. To my knowledge the Marathon does not come in a load range E but other tires this size do. Load Range D Marathons are rated to 2540# but only when inflated to 65psi and only up to 65mph. Metal as opposed to rubber valve stems are recommended for this pressure.
According to their website the Cooper Custom Trailer and Custom Trailer Plus are discontinued:
http://www.coopertire.com/html/produ...m_trailer_plus
Click on "Full specifications". Makes me wonder what will happen in a warantee situation. It's too bad as Cooper is the only manufacturer that I've seen give the Service Description. For the load range D tire it's 113S ( 113 = 2561pounds, S = speed rated to 112 mph). This is the way Passenger tires (P) and Light Truck (LT) are rated. I haven't seen any LT tires that come close to this rating so I think you're only choice are the Special Trailer (ST) type tires.
Tow Master is the "Brand Name" that the Greenball Company uses for it's trailer tires. Originally these were made for them by the Cheng Shin Rubber Company in Tiawan. Then for a while the Tow Master was made by Goodyear. So for some time the "good reputation" was built around the exact same product as the Marathon. Now days Greenball uses a laundry list of supplies located in; China, Taiwan, Indonesia, Thailand, and India.
http://www.greenball.com/company.htm
There actually is a way to determine what plant the tires are made it. Every plant in the world has a unique two letter code which gets molded into the sidewall. This is how they can control recalls. The problem is most tire stores need to special order trailer tires so you can't just go to the rack and look at them. If anyone has bought a set of Tow Masters recently I'd be very interested to know where they were made. I'd have no problem if they've gone back to Cheng Shin in China.
-Bernie
07-06-2006, 03:58 PM
1999 34' Excella
Joshua
I have been running Marathons on our 34' for a long time and never have had any problems (knock on wood). I also keep them treated with UV protectorant and keep them covered when at an RV park. I also change them after about 5 years even if they look good. I have bought my tires from www.tirerack.com. They have always been freshly dated, great prices and have never had any complaints, even Goodyear recommends them as a source to buy form.
07-06-2006, 07:05 PM
Retired.
, At Large
I had two 2-year-old Cooper Travel-Tracs fail within minutes of each other on our previous coach. You can get bad tires from any manufacturer, regardless of price or age. Our current Marathons are holding up just fine at 14 months of use, so far. If I have any problems with them, y'all will be the first to know, after us.
07-06-2006, 08:06 PM
1960 24' Tradewind
santa barbara
The marathon radial made by greenball is the same as there own radial .The other tires such as the bias towmaster are good tires and are not marathon related ,I suggest some research into the greenball website as they make tons of different tires.Say what you all want about marathon tires ,they last am million miles even when balled and they can perform miracles and such
nothing in the world can touch them .But you cannot deny the chronic problem related to them no matter what the claims .Some have good luck
many do not .I have recently read about sob fifth wheeler tri axle ,new coach
4 marathons blew out on the trip home ,tore up some of the trailer ,the plumbing underneath ,the dealer wanted nothing to do with it because
thay did not make the tires ,so these problems are a reality ,and pretending
they do not happen does not make sense to me .The article and others like it
are in the rv magazines under the readers columns.The tires i mentioned were not 5 years old.
Scott
07-06-2006, 08:46 PM
2004 28' International CCD
Camarillo
Thought I would make my first post on tires. I have a 28 foot CCD 2004. When it was about 6 months old I had a marathon blow and was always suspicious that is was a bad tire and not a road hazzard. My trailer is in central Louisiana ,but before it comes home to California I'll have it fitted with Maxxis tires.
07-06-2006, 09:54 PM
2004 30' Classic Slideout
Fenton
, Missouri
Originally Posted by scottanlily
Some have good luck
Scott
Before we throw the baby out with the bath water, if this is the Trailer Life story I think that I read, it ended up that the fellow was overloaded. I think the empty weight of that 5th wheel was right at the edge of the tires capacity. The manufacturer really didn't do their job in equipping the trailer with the proper sized tires. The owner loaded up his stuff and put himself over the tire's capacities.
There are lots of stories regarding motorhomes and failed front tires. RVSELF, does seminars on this. The problem? Axles which weighed as a whole are within specs. Weigh each wheel separately on that front axle, and many are overloaded on one wheel.
I think there are enough of us out there that if the Marathon's were as bad as you say, these forums would be burning up with the reports. I'm on my third trailer with Marathon's. I've had no problems....and if you go back for 14 years prior to those three trailers, I had multiple brands of tires on my SOB. I never had one fail and I continue to note that I kept them inflated, didn't overload them, kept them protected from excessive UV, and replaced them every 3 to 4 years.
I think to continue the campaign that Marathon's are bad is very unfair to the manufacturer and doesn't reflect the number of these tires in use and the percentage of failures. Yes you will hear of more problems but that's because there is a heck of a lot more of them out there. It just stands to reason.
BTW, I have no financial interest or friends or family working for Goodyear. I just don't believe we are being responsible if we don't post all the issues here.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-06-2006, 10:51 PM
1960 24' Tradewind
santa barbara
well jack you have a right to your opinion ,and I believe I read the marathon
was being phased out .My small input could not possibly affect goodyear .I read all of your personal opinions as well as others touting this tire as the best thing ever ,frankly its tiring .I am stating factual information that has been posted here and on other rv sights.I will say that the overloading issue is a real problem and the marathon cannot tolerate it .I have said in past posts that the weight issue was a weakness . why can't then you support
towmaster or carliles or bfgoodrich or michelin or sears or cooper or maxxis
or bridgstone or uniroyal or toyo or yokahama etc?You are incorrect that
that the failures are small ,go to RV .net or Google marathon tire failures
before claiming that really I am making false statements.My comments are
expressed only as I have looked over many tire /rv sites for extended amount
of hours to research tires .I was really surprised by the findings.If everyone wants marathons primarily because others use them ,thats ok ,It should be
fine for me to share my knowledge and state it here .You state your position
as someone that thinks they are great. Further you do not have any
evidence to support your conclusion that failures are not common.Did you read darrell roots post before yours on his 6 month old marathon failure?It
was only 6 months old he said when his blew out .You may work for goodyear
who knows? But I see that everyone IS posting all the issues .I think that
the pros and cons of anything can be shared on a forum such as this.I don't think my few statements are any campaign .The point is this .Why should we be having any tires blowing out in the first place .I agree that airstreams
have not shown as many troubles with the goodyear.My airstream as well as
most all coaches up thru the 70s to possibly 80s had 700-15 bias tires for
strength and heavy duty service .NOT marathons ,however radials improved and airstream said lets use them .Ok ,I would like to see some options on
available tires that work ! Not a campaign always that it is better than any
other tire for these trailers . So if I point out that problems exist,and then ,
Im hurting goodyear ,well I don't want people having blowouts ripping up their trailers ,theres no excuse for that .One other thing about trailer life ,the tires
could not handle the weight even empty ,and he had just bought it and was bringing it home ,how could he have it overloaded?As for goodyear ,they better get it together and build a better trailer tire.enough said.
Scott
07-06-2006, 11:37 PM
Camarillo
Clarification on earlier post. Trailer was not overloaded. Tire pressure 65psi one hour Prior blow out. Goodyear dealer with a 5 second exam and sounding rehearsed gave me the road hazzard rap. I'm giving Goodyear the lost a customer rap. Did I mention minor damage I was lucky enough to repair myself. Respectfully Darrell
07-06-2006, 11:45 PM
1960 24' Tradewind
santa barbara
hey Darell Root,
the last post of mine was not in mention of any overloading with your airstream .I agree also the tire was no good ,the discussion previuose involved some other fifth wheel trailer.
Scott
07-06-2006, 11:52 PM
1960 24' Tradewind
santa barbara
TO THE GOODYEAR TIRE COMPANY,
IF you are reading this post .The goodyear workhorse bias ply tire and many
goodyear tires from LT tires to high performance and street automobile tire
to your racing tires have been excellent in quality and have performed well.
I have been a tire adjuster for many years previouse to my current proffesion
and have found your tires to be one of the best in quality.I wanted to make clear that my tire failure observations have been with the marathon trailer tire only.
Regards
Scott
07-07-2006, 12:54 AM
Camarillo
Scott, no problem ,I knew you were refering to the other post. I just wanted to add more info to my situation. If anyone has experience with Maxxis tires-lets here it. Thanks Darrell
07-07-2006, 01:00 AM
1978 24' Argosy 24
Woodinville
It's a fact that the reports are posted but I don't take everything posted as being fact. It may be that the Marathon has a worse track record than other tires but there's simply not enough information to statisticly support this. Another question I have is why don't we see posts for tire failure on Private Brand tires made by Goodyear when rebadged Marathons have been sold for years under other names?
Failures of more than one tire at a time don't necessarilly indicate a quality problem with the tire. The failure of the first tire put's added stress on the rest of the tires. A tire on a tandem axle trailer could be low on air for an entended period causing the other tire on that side to carry all the load. That might actually be the first to fail and then the tire already low is suddenly carrying nearly half the total trailer weight. No tire is going to tolerate that for long.
I'm not thrilled with any of the ST tire choices. For starters none of them are made in a size that matches the original 7.00x15 tires my trailer was designed for and I can't afford to give up ground clearance. Second, when you look at the weight of tires there's a direct relationship between the weight (construction) and the cost. ST trailer tires are basicly lightweight cheap tires. That's what the market has decided people want in a trailer tire. Note that you have no choice in a Winter tread/compound (M+S rating) or speed rating (heat dissipation) with the exception being Cooper.
It sure would be interesting to find out more about the Goodyear tires made for U-Haul. If they're already producing a higher quality tire (note I said IF) then why not market it? It should be a higher margin product than the Marathon and more production would mean lower costs for U-Haul. If on the other hand it's just made cheaper then I can understand Goodyear not wanting to damage it's reputation (and profit margin) by devaluing the brand name.
-Bernie
07-07-2006, 01:14 AM
Camarillo
Bernie I believe Goodyear is a rebadged Greenball Towmaster. Darrell
07-07-2006, 02:14 AM
1960 24' Tradewind
santa barbara
you know bernie , other folks not just on other sites have had tire failures with the marathons ,so why discount all experiences as not valid ,how much info do you need anyway .I have said not all but it reads as many .i posted another thread and it has dissappeared somehow ,so if it reappears some things may be repeated here. I run herculese 700-15 tires bias with real
5 ply tread and 4 real sidewall plys ,marathons only have 2 ply sidewall .
I know my tires are strong and heavy duty 5000 miles so far .These ST tires
need to be built more heavily and stronger ,that will solve the problems.
I use to adjust tires for a living before my current profession ,so i know about tires as I had to determine why a tire failed ,the type of failure and no how to read tires as well as a tire installer for some time .Anyway I guess I need to explain that i just might not be so ignorant when we discuss tires here and
I believe other good and better options are worth looking at.
Scott
07-07-2006, 06:56 AM
2004 22' Interstate
Tipton
, Iowa
Scott,
There are some other factors you're overlooking. First is that Marathons seem to be far and away used more frequently in RV trailer applications than any other tire from other manufacturers. They are going to have more reported failures just because there are so many of them out there. The second issue is that Goodyear can't control how their tires are used. Many RV manufacturers mount the tires and are overloaded at factory-option curb weights before any 'owner' stuff is placed into a trailer. Scamp 5th wheels are a prime example; they use tires rated at 2700 lbs max on a trailer with a 2700 lb dry curb weight and a 3500 lb GVWR axle.
To say that Marathons fail at a higher per-unit rate than other manufacturers' tires just from anecdotal reports and without any supporting emperical evidence is a little reckless. I have yet to see comparative data from tire manufacturers, magazines, or any consumer group with that kind of data.
While Marathons aren't the only tires out there, and I've had Cooper STs and Carlisle STs in the past as well, the only tires I've had fail on a trailer were on a tandem boat trailer equipped with overloaded p-metric car tires.
Regardless of the brand, if you make sure the tires are properly weight rated for the load, are ST rated, are in good condition (regularly inspected), and less than five years old, the odds of having a blowout (sidewall failure) are reduced radically.
Roger
07-07-2006, 10:19 AM
Fenton
, Missouri
was being phased out .My small input could not possibly affect goodyear .I read all of your personal opinions as well as others touting this tire as the best thing ever ,frankly its tiring .I am stating factual information that has been posted here and on other rv sights.I will say that the overloading issue is a real problem and the marathon cannot tolerate it .I have said in past posts that the weight issue was a weakness .Scott
Scott, you've hit the nail on the head. Overloading is a real problem and overloading will cause tire failure. The overload can be caused by carrying weight in excess of the maximum pressures as stated on the tire sidewall, or insufficient pressure in the tire to carry the weight load of the trailer. In either case once you exceed those specifications, no tire manufacturer has any responsibility to support you as a customer or user. I wouldn't doubt that there is the potential that some tires may have more capacity in reserve to deal with this issues and Goodyear's may not be as tolerant. That in itself does not make the tire bad. If anything, it hammers in the fact that people need to be vigilant and take a proactive approach in dealing with their tires. If you have attended the tire training sessions that RVSELF puts on (I have) they emphasize the need to know what your trailer weighs and know how much it weighs when you load it up. I've weighed my trailer and have done the homework.
I'm not dissing any other tire. If you notice in one of my posts I comment that if the tire you have on presently works for you, then you might as well continue using it in the future when you look for replacement.
No I don't work for Goodyear, I work in a Convention Center so don't think there is any bias for them from me.
I continue to contend that you aren't considering the universe of tires out there. The most popular tire is going to have a higher number of reported failures, and to do a fair assessment one needs to look at that as a percentage of overall tires in use. Until someone provides hard statistics on those percentages by brand of tire, any reference to a tire being bad based on the number of reports you see on the Internet has questionable value.
I appreciate your concern regarding the issue, and like you said I certainly do not want to see my trailer damaged by a tire that is defective. My issue is keeping a balance on this discussion and making the point that this is not cut and dried that Marathon's are bad tires.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
