Old 06-23-2008, 11:08 AM   #1
2006 F350 V10 Ext. Cab LB
Driver1's Avatar
1998 30' Excella 1000
Sherwood , Oregon
Images: 12
Manual says ST225/75R15LRC 50 psi -- PO used ST225/75R15LRD at 65 psi
Hi All,
1) What's best (C or D) for my 30ft. 1998 Excella 1000 (GVWR 8300#)?
2) In searches, I've seen references to Spin Balance Tire & Wheel, Static Balance Tire & Wheel, and something called Road Force Balance. I think Spin Balance Tire & Wheel is what I should have done when I buy, but need confirmation.
Walt
Driver1 is offline   Reply With Quote
Old 06-23-2008, 11:27 AM   #2
_
hi walt
a reasonable case could be made for either the c or d rated tires...
my vote would fall on the d rated side, perhaps at 55-60 psi...
or 65 psi if towing at 65+ mph.
hunter road force balancing is a superior method of matching/balancing the tire/wheel package...
and i utilize it on the stacks of low profile tires and performance rims in the garage...
BUT for a trailer running tall tires and with unbalanced hubs/drums, the extra cost and precision is suspect.
it might be better 2 spend that $ to add centramatics to the runny gear,
and rely on the more common spin balance for the tire/wheels...
cheers
2air'
Old 06-23-2008, 01:59 PM   #3
Balancing.
This is the finest method of balancing a tire, wheel, hub and drum assembly.
Wheel Balancing Photos - Inland RV
Old 06-23-2008, 08:26 PM   #4
Driver1's Avatar
Sherwood , Oregon
Images: 12
Hi 2air (That seems deflated with no Capital A) & Andy,
You 2 have helped think through many issues -- thank you both.
Couldn't get into the local(?) Camping World shop's schedule until tomorrow, but they met/beat the local competition price for the same 4 - ST225/75R15LRD Marathons after some 'discussion' (After all I am a member of their club). It will be the D's and a spin balance tomorrow PM. I will inflate them to the 65 psi for freeway speeds+ (I5, in some parts, is 75+ conditions permitting).
Andy, California hasn't been one of my favorite places to go since the 1965 Watts introduction (It was Jr>Sr Yr. summer vacation from Penn State in Manhattan Beach and commuting to Culver City -- 50 calibers on Jeeps on street corners don't interest me, though I did get lost while driving through the areas with the fires - they were interesting). Where is Corona, maybe (If it's somewhat north) the next time I gotta do something you can do, we can get together.
Walt
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 10:11 AM
What PSI should I have my tires? silversled Tires 7 03-03-2008 12:05 AM
700-15 vs. ST225/75/15 chuman70 Tires 7 07-20-2007 04:52 AM
Tire PSI? ldetsf Tires 9 11-10-2006 08:18 AM
Is a ST225/75R tire the same as a 7.00-15? Bryanhu Tires 7 05-08-2004 07:40 PM
