Old 10-06-2013, 01:45 PM   #15
mandolindave's Avatar
Alan
Your math is correct if you subtract 10% and then subtract 10% of the sum.
If you just subtract 20%, the number would be 1749 lbs. To be safe I use 1749, multiplied by two tires....it comes to 3498 lbs. That's cutting it close for my trailer. Idroba said his Argosy 20' load on the axle is about 3500 lbs
I forgot to add in weight of food, drink, pots & pans, silverware, clothes, bedding, tools, cables, books, toiletries, stone guards, and mandolin strings.
mandolindave is offline   Reply With Quote
Old 10-06-2013, 01:57 PM   #16
1981 31' Excella II
New Market , Alabama
Make sure you subtract the hitch weight from the load.
Perry
Old 10-06-2013, 02:02 PM   #17
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Perry
I would think the best way to get the weight is at the scales, fully loaded and with WD applied. This will tell you exactly what's on the trailer axle(s). I know others recommend weighing each wheel position.
Old 10-06-2013, 02:10 PM   #18
Perry
I am using Idrobas stats, and yes he subtracted tongue weight
By the way thanks Idroba.
Old 10-06-2013, 02:16 PM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
"This makes me wonder how the Michelin tires that come from the Airstream factory are warrantied. Has anyone had an experience with obtaining service for Michelin tires on a trailer while under warranty?"
Alan
If it's the same as all the other "equipment" warranties, it's covered or not covered by the manufacturer. In this case.... never mind, they'er 16" LT's.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-06-2013, 03:31 PM   #20
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The factory installed 16" Michelin LT 225/75R16E LTX M/S2 (Michelin part number P/N 05681) tires are rated 2,680 pounds at 80 psi and the SenDel T03-66655T wheel is rated 3,580 pounds at 80 psi. Since these are NOT passenger tires, they do NOT need to be derated.
These tires are not speed limited to 65 mph like "ST" tires.
The dealer of the tire typically provides and services the warranty (He fills out the warranty paper work and checks how the tire is being used).
I purchased the five 15" Michelin LTX (P) 235/75R15 XL tires for our 25FB International Serenity from a specific dealer who knew the Airstream application. I recently got a roofing nail in the corner of the tread and he replaced the tire at no charge under their road hazard program.
He will also sell me the five 16" tires captioned at the beginning of my post for our new Airstream Classic model 30 when it arrives in February.
Here is some informative and precise reading on the derating topic:
49 CFR 571.110
Tire selection and rims and motor home/recreation vehicle trailer load carrying capacity information for motor vehicles with a GVWR of 4,536 kilograms (10,000 pounds) or less.
S4.2.2.1
Except as provided in S4.2.2.2, the sum of the maximum load ratings of the tires fitted to an axle shall not be less than the GAWR of the axle system as specified on the vehicle's certification label required by 49 CFR part 567. If the certification label shows more than one GAWR for the axle system, the sum shall be not less than the GAWR corresponding to the size designation of the tires fitted to the axle.
S4.2.2.2
When passenger car tires are installed on an MPV, truck, bus, or trailer, each tire's load rating is reduced by dividing it by 1.10 before determining, under S4.2.2.1, the sum of the maximum load ratings of the tires fitted to an axle.
S4.2.2.3
(a) For vehicles, except trailers with no designated seating positions, equipped with passenger car tires, the vehicle normal load on the tire shall be no greater than 94 percent of the derated load rating at the vehicle manufacturer's recommended cold inflation pressure for that tire.
(b) For vehicles, except trailers with no designated seating positions, equipped with LT tires, the vehicle normal load on the tire shall be no greater than 94 percent of the load rating at the vehicle manufacturer's recommended cold inflation pressure for that tire.
Old 10-06-2013, 03:43 PM   #21
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I just read through the Michelin Truck Tire Warranty 2013 and see NOTHING that states if installed on a trailer that the warranty is void. So, the dealer may be wrong. It does mention using on motorhomes and it is covered.
Old 10-06-2013, 04:25 PM   #22
K.C. , Missouri
Another of the few remaining options of LT for 15" rims in the Continental Vanco 2.
215/70-15 LR D is rated as 2271 lb @ 65 psi
gmw photos is offline   Reply With Quote
Old 10-06-2013, 04:29 PM   #23
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by switz View Post
49 CFR 571.110
S4.2.2.1
S4.2.2.2
S4.2.2.3
Would you mind sharing the source of these?
Thanks!
Alan
Old 10-06-2013, 04:41 PM   #24
K.C. , Missouri
Thanks!
Alan,
if you do a search for 49 CFR 571.110 it will lead you to various DOT and other documents regarding tire specs
Old 10-06-2013, 04:44 PM   #25
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
This is a link to the warranty for Michelin Light Truck and Passenger tires.
http://www.michelinman.com/mediabin/...omise_Plan.pdf
When I asked the customer service rep at Michelin about warranty of these tires on a trailer, they referred me to page 1 (which is 4/30 in the pdf) about 2/3 down where it talks about misuse or misapplication.
I'm not trying to argue a point, just pointing out what Michelin told me.
Alan
Old 10-06-2013, 04:59 PM   #26
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Thank you!
Originally Posted by gmw photos View Post
Alan,
A link to the document
http://www.gpo.gov/fdsys/pkg/CFR-201...sec571-110.pdf
Alan
Old 10-06-2013, 04:59 PM   #27
2006 25' Safari
Images: 8
Hey AW Warn. You probably got a similar message that I got from my local dealer. I did look over the warranty on your link, it was different from the Truck Tire Warranty book. I did not see anywhere where misapplication was spelled out nor did it exclude trailers except on the three year road assistance warranty which says it does not include the replacement, etc. So, I am not sure they would be able to call it misapplication do you? Just thinking.
Old 10-06-2013, 05:15 PM   #28
1981 31' Excella II
I don't know why everyone is worried about warrantees. Passenger and Light truck tires very rarely fail. I have never returned a tire for failure. I have returned some that were out of round. I have never had a tire blow out. I am not talking about trailer tires and I don't run trailer tires on my trailer. For the rare occurance of a tire failure, just buy a new one and move on. If you want a warrantee just tell them that the 15" 6 bolt rims you brought in are from a 90 Suburban 4x4.
Perry
