Old 11-13-2010, 09:04 PM   #15
Western slope , Colorado
Non ST tires from Airstream?
Originally Posted by moosetags View Post
What we got for Lucy was the 16" wheel/Michelin Tire package from the Airstream Factory Service Center.
Brian
Please do let us all know what tires/recommended pressure/all the details. Many who read the forums have struggled with this issue and would like to move away from the ST tires and have a reliable tire that is recommended by "airstream". Especially if it is a M.
"If you come to a fork in the road, take it."
Yogi Berra
Streamside is offline   Reply With Quote
Old 11-14-2010, 07:29 AM   #16
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by Phoenix View Post
Can you publish details on the wheels and tires, please? Next year, we plan to replace the original 15-inch wheels and 225/75x15 Maxxis tires with 16-inch wheels and Michelin XPS Ribs; and I'd like to get them locally. (Indianna is a long drive from Phoenix.) --Thanks...
The tires installed on Lucy at Jackson Center are Michelin M/S LTX LT225/75R 16E's. The wheels do not have any brand name on them, so I can't give you any specs. If you call the Factory Service Center, they may be able to give you the wheel specs.
Also, keep in mind that you will need to do five new tire/wheel combos as your spare needs to be the same size as the others.
Brian
SuEllyn & Brian McCabe
Old 11-14-2010, 08:52 AM   #17
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
IF WE HAD KNOWN U WAS COMIN WE WOULD HAVE BAKED A CAKE. Glad you enjoyed your stay in our area Moose. Those people at JC are great and they do nice work too.
Wish ya could have stayed longer we would have like to meet you also.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 11-14-2010, 08:54 AM   #18
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Airstream gets the wheels from a supplier in Indiana. When we did the switch, the supplier only carried Goodyear LT tires, so we picked up the same Michelins Brian and SuEllyn have now at Discount Tire in Dayton. They installed them at JC. We had also bought Centramatics previously. We are very pleased with the Michelins. The wheels are much easier to keep clean too, and we think they look better than the spoke style.
Brian, did you keep the old wheels? We had no need for them, so we were glad to get rid of them as the clear coat was coming off and they looked bad. Was it difficult to get the spare in the tire carrier, or did you put it in the back of the Suburban?
Airstream filled the tires to 80 lbs., but I reduced it to 68 as that appeared to be proper for our trailer's weight. They are wearing perfectly across the tread, so the tire pressure appears to be correct.
And Aage, it may be "meese" in Canada, but here in the US the plural is "mooses", just like Canada gooses.
Gene
Old 11-14-2010, 11:43 AM   #19
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Fer sher - it can't be "meeses" 'cause that word's already taken.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 11-14-2010, 12:53 PM   #20
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
Brian, nice wheels! The Columbas Zoo is one our favorite places to go. Did you get to the underground Polar Bear area in time to see the feeding? That is quite an experience. LJH
LJH is offline   Reply With Quote
Old 11-27-2010, 11:34 AM   #21
moosetags's Avatar
When Lucy's new tires and wheels were mounted at the Service Center, the tires had been pre-inflated to the max 89 psi. I decided to reduce the inflation to 72 psi. That was the psi at which I was running my Maxxis E's.
Airstream recommended to 80 psi, but I felt that was a little much as Lucy weighs 7400# ready to camp. I want her to had enough inflation to support her weight on 3 tires in case of a tire failure. 72 psi covers that.
The Airstream factory Service Center is great at fixing anything on an Airstream. They fix right and know what they are doing. They are a little short of knowledge in the area of actually pulling an Airstream on the highway. I think this is why they hand you the tires with 80 psi in them and don't seem real concerned about balancing, etc.
Brian
Old 11-27-2010, 11:42 AM   #22
moosetags's Avatar
Gene
We did not keep Lucy's old wheels and tires. The wheels were pretty corroded, and all but one of the tires had 15,000+ miles on them.
The new spare mounted fine in the OEM rack.
What I like most about the new wheels is that you can actually get to the valve stem to check pressure and add air. The valve stem position on Lucy's OEM spoke wheels was awful. I could never figure out why Airstream would mount a wheel with such a terrible design. Someone was asleep at the switch when they selected that wheel.
Brian
Old 11-27-2010, 11:44 AM   #23
Master of Universe
Gene's Avatar
Brian, that's is an interesting approach. Since various gauges I have vary by 3 lbs., I may actually have 71, not 68. I suppose if I have a flat and have to drive on 3 tires for more than a mile, I could add air to the 3 tires. I am more concerned about the extra weight on the axles and bearings when driving on 3 tires.
How was the ride back to Florida? Could you tell any difference? We couldn't once we switched, but we felt better knowing we had better tires on the trailer and noticed quickly we were not constantly losing air.
Gene
Old 11-27-2010, 11:50 AM   #24
moosetags's Avatar
We were a little to lake for the Polar Bear feeding, but we did get to see the lounging around. We did get some good shots of Edward (the bull moose) and his girls. We really enjoyed our visit to the Zoo.
ID:	115999   Click image for larger version
ID:	116001   Click image for larger version
Old 12-17-2010, 08:32 AM   #25
moosetags's Avatar
Gene
Lucy's trip home was uneventful. We came home first, and then brought her over to Jacksonville, where she is now.
We now have about 1,200 miles on Lucy's new tires and wheels. I can't tell any difference in her towing behavior. Lucy pulls beautifully, as always.
I do like the new wheels very much. I think that they look much better than Lucy's OEM spoke wheels. What I really like is that I can now easily get at the valve stem to check pressure and add air. They OEM wheels have a terrible design. The valve stems are virtually inaccessible. I had added a curved valve extenders to make them usable.
Brian
ID:	117148   Click image for larger version
Old 12-17-2010, 10:08 AM   #26
Master of Universe
Gene's Avatar
Brian, we've both had the same experience. I didn't like the look of the spoke wheels and the clear coat was coming off. It looks like yours were wearing badly too. Now I'm in the process of replacing the lug nuts to solid ones as I rotate tires.
Gene
Old 12-17-2010, 01:41 PM   #27
2005 28' Safari
saline , Michigan
Question - Why go all the way to JC for wheels and tires? Or were you just taking a trip anyway?
Kosm1o is offline   Reply With Quote
Old 12-17-2010, 01:45 PM   #28
moosetags's Avatar
Gene
I am also am considering new lug nuts. I don't like the covered ones either. They are really hard to get the wrench on and off them. I might also like some new hub caps. Lucy old ones have a few dings in them. If you find something cool, let me know.
Brian
Trip to Jackson Center OH TankerIP On The Road... 40 11-11-2009 05:20 PM
First trip was to Jackson Center erock53 On The Road... 6 07-31-2009 04:31 PM
Jackson Center trip/repair davidz71 On The Road... 27 01-12-2008 04:23 PM
Lucy's Trip Home to JC moosetags General Repair Forum 8 10-26-2007 04:38 AM
Trip to Jackson Center Silvertwinkie On The Road... 31 04-30-2005 10:57 PM
