Old 08-20-2002, 04:15 PM   #15
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Hi 76Argosy,
Thanks for the Cooper article. The trailer life article on tires in the Sept. issue states similar facts.
How about those safety jack stands they sell all over the place? You can use them to lift your trailer and keep it in the air safely.I guess it would be a good idea to find out where the best for support is for long term storage, so as to not bend the frame rails.
Uwe
www.area63productions.com
Old 08-20-2002, 07:31 PM   #16
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
76Argosy:
Thanks for taking the extra time and effort to contact Cooper Tires and then taking the time to post a carefully edited thread with your discoveries. This is what the AirstreamForums is all about. Sharing great information with each other.
I would also like to encourage you to take a little more time to email a thank-you to Cooper Tires customer service and mention the good information and service the tire specialist gave you. I know they like to hear good feedback as well as bad. Maybe it will sell a few more tires for them. This link shows the history of the company. Kind of interesting. http://www.coopertire.com/about/history/index.html
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 08-21-2002, 06:15 AM   #17
BobbyWright -
Thanks for the kind words and the link to the history of Cooper. It was interesting. I will send that E-Mail thank-you to Cooper, as you suggested. - Guy
76Argosy is offline   Reply With Quote
Old 08-29-2014, 03:30 PM   #18
2012 19' Flying Cloud
Bricktown , New Jersey
My trailer is an enclosed Homesteader 6x12 single axle used for toy hauling & utility purposes. Rather than replace with 205/75/15 Carlisle Radial Trails, I opted for LT 215/75/15 Yokohama Geolander's load range C. I did so for two reasons: Higher speed rating and matching tread pattern on both my truck and trailer. No problems after about 1500 miles so far. Trailer tires are prone to blowouts if you drive over 65mph especially in the summer when most people use their trailers.
jsvetrano is offline   Reply With Quote
Old 08-29-2014, 04:03 PM   #19
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by 76Argosy View Post
I said I would report what response I got from Cooper Tires on the ST vs LT issue. Here goes. Cooper sent me an email with a phone number to call. The customer service rep at the number put me on hold and got a gentleman to talk to me who has years of experience actually building the tires and is a trailerist, also. Yes, there is a definite difference between Cooper LT and ST tires.
However, it is not a "safety" difference as long as the load rating is correct for your trailer's gross weight when towed. Both ST and LT tires can be safely used for trailers. The difference in construction is this: Cooper ST tires are basically a tire that combines passenger car tire construction techniques, with heavy duty truck tire fabric and cord materiels. This results in an ST tire having a high LT type load rating with the lower air pressure requirements and soft, shock absorbing sidewalls of a passenger tire. There is also extra UV inhibitors and oils added to the rubber to help in storage. This is much easier on the suspension and other components of the trailer on bumpy roads than the stiff sidewalls and higher air pressure of the LT tires. As far as tire safety is concerned, he stated that is up to the trailerist and how he maintains the tires, keeping the proper air pressure in the tires, and choosing the correct load rating. He stated LT tires have an advantage because of the larger choice of tread patterns and number of sizes available to choose from to suit the conditions you are towing in, such as snow, unimproved roads, etc. He also stated that it is imperative to not allow the trailer to rest on the tires in the same spot for months at a time in the off-season. This causes the fabric cords in the tire to take on a flat "set" which can then cause some of them to actually break apart when you next take the trailer out on the highway. This can cause complete tire failure. He stated the best thing to do is to store the trailer on jacks with the tires in the air, or removed completely. This last information was of concern to me since I only have "stabilizing" jacks and cannot lift the trailer enough to take the load off the tires without serious effort. At any rate, that is what Cooper Tires has to say on this subject.
But are not Cooper's comments about ST tires having "soft shock absorbing sidewalls of a passenger type tire" the opposite of what Andy is saying about ST tires having "Greater sidewall strength" to cope with the side loads of turning a dual axle trailer?
All so confusing! What Andy has said is more typical of the comparative comments I have read elsewhere.
Having said that, I have so far been extremely happy with the 16"LT tires I put on last year to replace my 15" ST's !
Hoping that will continue, but this is indeed a controversial subject, and my fingers are still crossed hoping I will not later regret making the switch!
I have to admit that my decision was based largely on other folks experience as reported on this forum - that, combined with my own less than stellar experience with ST tires!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
"We don't normally balance trailer tires....." Pick Tires 36 07-16-2012 02:30 PM
Trailer Tires? Austin Runner Tires 21 06-27-2004 11:42 PM
Questions about trailer tires... cactushead Tires 2 10-22-2003 05:58 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
tires? trailer will sit after move goodgrey Tires 4 12-06-2002 02:10 PM
