Old 01-14-2015, 07:28 PM   #43
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I believe that the 16" tires should have a lot more air pressure..I looked at the michelin site and it was hard for me to read but I think I saw. E 2680 @ 80, 2560 @ 75 and 2440 @ 70 lbs air pressure, it didn't say nothing about 45 lbs...
Old 01-14-2015, 07:41 PM   #44
Bigcgar's Avatar
2015 25' FB International
2011 23' International
Larkspur , Colorado
I ordered a 2015 25' Serenity this week and asked my dealer to get a quote from AS to upgrade to the 16" wheels/tires combo. They quoted me $1,700 to upgrade. That seems crazy to me. I would have expected maybe 700.00 to swap out the 15 for the 16's. Anyone else have experience with AS on this topic?
Curious,
Bigcgar
Allan & Vicki
Larkspur, CO
Be well, fish on!
Bigcgar is offline   Reply With Quote
Old 01-14-2015, 07:49 PM   #45
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
You can buy 5 Wheels and 5 Michelin 16's for that.Then sell the ones that come with the trailer n Craigslist or Airstream forum classifieds.That is what I did.
Old 01-14-2015, 08:06 PM   #46
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I just bought 5 16" Sendels with 5 Michelin LT's at $330 per set mounted and balanced. I sold my 15" OEM"s for $600. This upgrade cost me a little over $1,000.
This was an excellent price as an Airstream dealer quoted me $4,000 for the same thing.
Brian
SuEllyn & Brian McCabe
Old 01-14-2015, 08:28 PM   #47
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We bought four Sendels/Michelins for ours and sold the originals. Considering the reliability of these Michelins I think replacing the original spare tire is a waste of money, it will get you home (or to the tire shop) should the unlikely event of a flat actually happen.
I suspect the only bad trait of these tires is a rougher ride for the Airstream. Combine that with the stiff ride of a heavy duty truck and the Airstream structure can take a beating. We tow with a 1/2 ton and try to minimize hitch and truck bed loads. I started with 80 psi in the Michelins, now use 65 psi but keep an eye out for things tossed around inside, shell condition outside.
Doug and Cheryl
Old 01-14-2015, 10:29 PM   #48
Moflash's Avatar
Having a wrong size spare to save a few bucks is your choice.But if it was the right thing to do your new Airstream would have come with a smaller diameter spare or none at all.As we all know Airstream cuts corners anywhere they can.
There are people on this forum willing to spend the money to do things the proper way.
Old 01-14-2015, 10:46 PM   #49
dkottum's Avatar
I have also considered leaving the spare and its carrier at home to lighten the heavy hitch weight and achieve a smoother ride for our Airstream. The probability of the 16" Michelins failing is slim to none, and if running over a nail the trailer can continue with one tire removed to a tire shop. It's in your Airstream Owners Manual.
Doug and Cheryl
Old 01-15-2015, 06:30 AM   #50
SteveH's Avatar
Common Sense , Texas
After having a BF Goodrich Commercial TA 225/16 separated and blow out last summer, I installed the original spare, a Goodyear Marathon ST225/15 and drove it about a hundred miles to the first tire store where I could buy a replacement 16" LT tire.
Nothing bad happened as result.
Regards,
Steve
Old 01-15-2015, 07:00 AM   #51
r carl's Avatar
Lin , Ne
Of course not, about like running one tire 10 psi low.
Old 01-15-2015, 10:36 AM   #52
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
LT Tire Survey
I know that each of us will do what we think is best.
My reference is the Michelin truck tire data book 14th edition 2011. The first part refers to rv applications and charts the rv tires as an each side weight on the tire/axle pg 12 has the 16" XPS Rib 225 listed with weight to psi figures. Interestingly if you go to page 22 you will find the M/S tires cross referenced to the Rib with the same weight psi specs on the 16" Size. Under the RV application the rib has a 1940lb side rating @50 psi which matches the 3880 lb rating per axle on the m/s and rib chart. My contention is twofold 1) that if tires were unsafe at anything other than max psi on the sidewall the charts would not exist nor would cars use lower figures on their door frames 2) the chart exists to match psi to load approximately to optimize the radial foot squat- not too much, not too little. I actually run 50-52psi.
Good to hear you are considering the tires and wheels. You will like them.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 01-16-2015, 08:36 AM   #53
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I did look at the chart, interesting,but I would still run more air, 65-75. The tire flexing at the sidewall causes heat and heat causes tire failure.On my big trucks we try to run the maximum pressures,even though the tires are sometimes lightly loaded. My life is mostly dependent on the steer tires, with 16000 lbs on the front axle,you lose one of them, you will be in the ditch,and it does happen when a tire is run low or has a slow leak from picking up road debris....You learn to be vigilant when you stop every couple hours and do a look see. Knock on wood I have not had any tire failures from low air pressure....
Old 02-28-2015, 03:01 PM   #54
68tradewind's Avatar
1968 24' Tradewind
2005 25' International CCD
Corvallis , Oregon
I have a 2004 25' CCD that needs tires. I want to go to LT tires, but would rather not have to move to 16" rims. Having some trouble finding michelins that will fit. Can you give me the size and type of tire you are using? Thanks.
68tradewind is offline   Reply With Quote
Old 02-28-2015, 04:45 PM   #55
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
27FB P235/75 R15 108T XL BFG long trail. 4 years. No issues. 6000 lb spread amongst the 4 tires.
SuperTrouper is offline   Reply With Quote
Old 02-28-2015, 04:48 PM   #56
Check out post 11 in this thread for more details. http://www.airforums.com/forums/f438...ml#post1374406
R.V. tire survey. ROBERTSUNRUS Tires 2 07-10-2010 07:25 AM
WBCCI Survey smily WBCCI Forum 33 11-13-2005 09:08 AM
New Airstream Classic motorhome survey ALANSD Airstream Motorhome Forums 0 03-31-2003 09:53 AM
AIR Midwest : Midwest Rally Interest Survey overlander64 Forum Rallies & Meet Ups 4 03-20-2003 06:30 PM
WBCCI Survey jcanavera WBCCI Forum 1 10-26-2002 07:14 AM
