Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 08-10-2002, 01:53 PM   #1
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Thumbs down Low Tire Detector
I stopped by Camping World today with the intention of buying a set of the low tire detector they were pushing by mailouts a couple of months ago.
They have withdrawn the detectors permanently from stock. That location installed about 3 sets of them and every one of them had repeated false alarms. They had to remove the sensors and issue refunds.
I guess I ducked a bullet by not getting them installed earlier.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Pahaska is online now   Reply With Quote
Old 08-10-2002, 03:33 PM   #2
83Excella
83Excella's Avatar
Profile:
Tire detector
I dont think 3 failures is much of a trend to warrant removing them from the shelf, the system they advertise in the catalog is made by Roadmaster they make alot of stuff for towing. I would verify through other sources about their product or even call them and ask about the CW failure/returns see what their side of the story is. It could have been caused by faulty installation by CW. And there are other systems out there such as Tele-tector in the Blue beret. I plan on getting one but thats down the road (with no flats I hope) .
John
83Excella is offline   Reply With Quote
Old 08-10-2002, 04:25 PM   #3
Pahaska
Pahaska's Avatar
Images: 12
Detector
I doubt that the local CW pulled it unilaterally; it isn't listed in any of the CW catalogs anymore. I just checked their website and their 800 number and it isn't there either. Those are national in scope.
The local CW had 100% failures, but, IMHO, they wouldn't have pulled it if other outlets were successful with it. Installation is simply putting a self-adhesive sensor inside the tire and mounting the receivers nearby.
The Teletector apparently doesn't work on my International though I will call them and verify that.
I had destructive blowouts over the years with my last 2 trailers and I really would like the sensors.
John W. Irwin
Old 08-11-2002, 06:33 PM   #4
Pahaska
Pahaska's Avatar
Images: 12
Roadmaster
Interesting that even Roadmaster doesn't have them on their website. I have a strange feeling that they didn't work out.
John W. Irwin
Old 08-11-2002, 08:28 PM   #5
83Excella
83Excella's Avatar
Profile:
Roadmaster brochure
A few months ago I received literature from them and the tire brochure was in it, but I did'nt save it.
John
Old 11-11-2007, 12:59 PM   #6
DON GUBRUD
Profile:  2003 22' International
hillboro , Texas
teletector failures
i just got back from a caravan and we had many flats. almost everybody had various types of detectors. none of the detectores gave positive readings that helped. i think the technology needs to ketch up with the demand. i will wait a bit befor buying one.
don
DON GUBRUD is offline   Reply With Quote
Old 11-11-2007, 01:57 PM   #7
richinny
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
i've wondered if a wireless microphone would be a better addition. if you could hear the tire flapping, it would be helpful. i suppose a vibration sensor would work too.
Ricky & (Ingrid)
Ingrid, 99.5 y.o. and counting & Ricky, a long way from there!
give life. have you signed your donor card?
kidney & pancreas transplant 9/9/06
welcome to the collective
Old 11-11-2007, 02:41 PM   #8
herrgirdner
Profile:  Currently Looking...
Afton , Virginia
I wonder if a "flat tire detector" would be the same item as a "tire pressure monitor"?
If so, there have been a few posts on this subject. Do a search and see what turns up. There have been some positive reviews .
regards
herrgirdner is offline   Reply With Quote
Old 11-11-2007, 03:49 PM   #9
CrawfordGene
Profile:  2008 25' Safari FB SE
Crawford , Colorado
Here's a negative review on tire pressure monitors. They are on my Toyota 4Runner. The dealer's service dept. hates them because they give a lot of false readings (one problem the 4R is they also read the spare and I can't keep extra pressure in it because warning light goes on) and when tires are changed they are easily damaged. My warning light has been on 2 months—we are used to it by now. I do check the 4 tires regularly, but the spare is a pain to check. They read rotations I was told so as the tires wears would readings get even stranger? I don't see how a reasonably priced system could be installed on the trailer and send readings to the TV. I think Ricky has the right idea—a mike to hear the flapping.
Gene
CrawfordGene is offline   Reply With Quote
Old 11-11-2007, 07:58 PM   #10
wingfoot321
Profile:  1987 29' Sovereign
Sparta , Tennessee
This thread is scaring me. I am about ready to order the Pressure Pro system of tire monitoring. A number of folks on our caravan this summer had them and seemed to be quite positive on their day to day operation plus ability to alarm on pressure drops over 5-8 lbs.
Only problem noted was potential vandalism or theft and cost to replace batteries every 3-5 years.
Are your detectors a completely different system?
wingfoot321 is offline   Reply With Quote
Old 11-11-2007, 08:19 PM   #11
16595
Profile:  2005 31' Classic
Gretna , Nebraska
I just listened to a guy talk about his Saturn Aura with tire monitors. He wasn't very happy either because of lots of false alarms.
Dwight
16595 is offline   Reply With Quote
Old 11-12-2007, 07:54 AM   #12
Ahab
Ahab's Avatar
Profile:  2008 22' Safari
Oracle , Arizona
We have the OEM tire pressure monitor on our Ridgeline and after 40k mi. it works fine with no false alarms. The only time it gave an indication was when I got a nail in a tire. Great safety system.
Ahab is offline   Reply With Quote
Old 11-17-2007, 01:25 PM   #13
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
I just came back from Europe and drove a high end Peugot. It had tire pressure monitors on it and the system was alwasy saying the rf tire was low. I manually checked it several times in the 12 days I was there. tires were good. Some times the LF would show low. Other times no warning as in all was good.
Neat idea. And the teckys need to find a better design. Cause this French design doesn't work.
>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 11-17-2007, 03:33 PM   #14
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
I went to the root of the problem, the crappie 15" ST tires!
Switched out to the 16" steel rims/metal valves (0 off set) and Michelin load range (D) LTX tires. They fit like a glove.
I've run the (E) range on my TV for 70,000, without a hitch. No more checking the sideview for black bits.
Thank you David and HowiE
Michael
ArtStream is offline   Reply With Quote
Tire pressures Silvertwinkie Tires 28 09-10-2004 11:00 AM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels 3 09-06-2003 02:25 PM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Flat tire detector Pahaska Tires 6 08-08-2002 06:38 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
