Old 11-17-2007, 03:48 PM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Hey Guys,
A Tire Pressure Monitoring System (TPMS) is a very good thing if you buy the right system. A lot of people like the Pressure Pro, but they do have limitations. I used to sell them, but I have since found a superior system that I'm beta testing at the moment. It was designefor the heavy trucking industry and is really built to last!
When I'm confident that the system works as designed (so far....so good ), I'll post on the results.
This system not only give you a signal when your tire hits a pre-set percentage drop in tire pressure, it also tells you if the pressure has increased beyond a set threshold, will notify you of a slow leak and the real deal maker........gives you a temperature reading also.
The sensors are made of brass and DuPont Zytel nylon and have a brass valve extending from the sensor so you can fill the tire with air without removing the sensor. PLUS.............they have an 8-10 year battery life!!!
So far...........I like them a LOT!
Stay tuned.......................................
Old 11-17-2007, 04:00 PM   #16
1984 31' Excella
Norfolk , Virginia
Images: 11
wingfoot321
Use a little logic here.
If the pressure is 0 psi the tire is flat.
So;
It follows that if the tire pressure drops below the pressure you want in it is partially flat.
When the pressure drops below what is required to support the weight on the tire, the tire's sidewalls flex more causing heat. This heat build up will lead to the disintegration of the tire.
Conversly, if the tire was at 65PSI when you checked the pressure in the morning and now it is 58 lbs and the alarm is going off then something has occured (you have hit something on the road, the rubber valve stems are giving up, the belts have seperated and ruptured the air bladder of the tubeless tire etc.) to cause the air to start venting.
I have the Pressure Pro.
I don't sell them or have interest in the company.
I chose them because they are easy to install (remove the valve stem cap and replace it with the sensor/transmitter, about the size of a walnut.
If the tire has to be serviced (nail screw etc) then remove the sensor and put it in your pocket. The tire changer then has no chance of damaging the sensor in the process of removing/installing a tire on the rim, unless he whacks you in the pocket with a tire tool where you have the sensor (levity) and by the way, given the ruggedness of the Pressure Pro Sensors your leg would probally be broken.
Have they saved me from damage from a tire failing, yes.
I stood there in the sholder of I 64 and watched the offending tire continue to go flat. It did not disintegrate or flail the trailer all though the steel belt was hanging out between the tread bars.
You generally cannot tell when a tire is flat on a twin axle trailer and flailing the trailer unless you catch the pieces flying away in the rear view mirror or a passing motorist gives you some weird hand signals as he passes you as he tries to get out of the debree pattern.
Given the cost of the Pressure Pro for a twin axle trailer and the cost of replacing a side pannes on the trailer, the Pressure pro is cheap.
My two cents worth.
Beginner
Beginner is offline   Reply With Quote
Old 11-17-2007, 04:50 PM   #17
RBolton's Avatar
Belington , West Virginia
As a dealer selling cars and trucks with tire pressure monitoring systems, I'll say this: Untill they come up with a better system that gives the driver more info as to what is actuallly going on, they are nothing but an aggrevation.
If your neighbor or someone in the parking lot at the grocery store would happen to say, "hey buddy, it looks like you're gettin a low tire," you'd say, "thanks man" and then go put some air in it. But the second or third time the tire pressure monitoring system light on the dash illuminates, you are at the (my) service desk saying, "that damn light's on again." It becomes a re-ocurring problem with the car.
There are different things that could cause this TPMS light to illuminate. The tire has a leaked and the pressure has either dropped below a certain theshold or is significantly different than the other tires. The ambient temp has caused the tire pressure to drop. The sensor is bad. The tire, if leaking, may or may not have a leak that is apparent enough to find. The seal around the bead may be leaking, but not all the time, the valve may leak, either around the valve to rim seal or through the valve. Maybe only at certain temperatures or pressures. The rim/wheel may be pourous. Anyway you do your best to find a leak and repair it and a few weeks later the light is on again. Is it the same tire? Is it the same leak? It's the same damn light and that is all the customer knows.
Some systems will indicate which tire is low. Some will show readings on the individual tires and the actual psi for each. Some will only tell you there is a low tire somewhere and you have do determine which one. It's a help to know that there is problem or a differntial in pressures. But, these systems only affirm the fact that we need to check our tire pressures often and maintain them at the proper levels. Tires will always leak or at least pressures will fluctuate for various reason. Unfortunately these systems are accused of being faulty or inaccurate when in reality they are only doing what the guy in the grocery store parking lot was doing and getting thanked for.
I know that this thread was aimed more at trailer tire monitoring systems, but the short comings are the same as with the systems on our vehicles. So, my opinion is that until they give more specific info, these devices should not be relied on too much and we should continue to check our tires frequently the old fashion way.
RBolton is offline   Reply With Quote
Old 11-17-2007, 06:45 PM   #18
1984 31' Excella
Norfolk , Virginia
Images: 11
Tpms
Sorry
But the Pressure Pro indicates which tire is low on pressure and alarms on a 12? pressure drop (I think is a 12? drop).
You can also check the pressure of all four tires whild going down the road and know which tire you are looking at.
Its a simple system.
It was bound to be improved upon sooner or later (temperature).
All alarms I have had with it (two to be exact) were accurate.
In short, its never lied to me.
Beginner
Old 11-17-2007, 09:05 PM   #19
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Beginner,
Thanks for the reply. You are confirming what I was hearing from the folks on the caravan this summer. They were using Pressure Pro and it had saved damage to at least one of the group.
My tires lost about 7 lbs of air this summer in 3 months. I run nowhere near my max weight & with bad roads,cool weather, & slow speeds, I just allowed them to slip down. I was unable to find a good location to air up due to no air locations, poor access with a trailer, plus whatever. It was very frustrating to the point that I researched and bought an air pump/tank as soon as I got home.
I plan to start at 65psi cold with the low pt detector set at 58-60psi. This means the tires from 65psi cold probably elevate to approx. 67psi warm and then would lose 8-10 lbs before the alarm would sound.
I am of the opinion that most tire failures are due to road hazards, nails, etc. and that a pressure drop should be the first indicator and hopefully before a temperature rise due to sidewall flex which leads to belt & or tread separations.
Thanks for the info.
wingfoot321 is offline   Reply With Quote
Old 11-17-2007, 10:49 PM   #20
2005 16' International CCD
Ogden , Utah
This is a good thread, thanks for starting it. Here's a couple more thoughts
I don't 'check' my tire pressures - I 'adjust' them. On my cars every two to four weeks, and on my Airstream every time before I move it (if it has been parked overnight or longer), or every stop while on the road.
After a while, I seem to 'learn' how the different vehicles/tires perform, in terms of pressure changes, so it is easier to detect a change that is out of normal. So when I check the tires (when cold) I put the pressures right to the level I want, making it easier to detect any significant change. Last week, for the first time in the last 10 years this obsessive behavior paid off - a tire on my wife's car read out of normal - was down to 24 when two weeks before I know it was at 32 - so I knew something was wrong. Sure enough, a screw in the tread and a slow leak. I never let a change of more than 3 or 4 PSI go uninvestigated, and I adjust the pressure if it isn't exactly where it is supposed to be (when cold).
I also carry an infra red temp sensor in the truck, and check tire temps at every stop when towing. Anything out of 'normal' performance, based on years of checking and paying attention - deserves further investigation.
I am excited about the prospect of being able to do this in near 'real time' while driving down the road, and would like to add some kind of monitoring system to the Airstream before next season. I expect technology will improve over time - it seems like more and more cars & trucks are getting these kinds of systems. In general, that has to be a good thing.
RDM16CCD is offline   Reply With Quote
Old 11-18-2007, 05:47 AM   #21
1984 31' Excella
Norfolk , Virginia
Images: 11
Tpms
wingfoot321
I looked it up.
The delta threshold is 12.5%. That delta is hard wired into the monitor.
So if you inflate the tire to 65 psi it will alarm at 57 psi.
Beginner
Old 11-18-2007, 06:40 AM   #22
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
my Pressure Pro results
I'll jump in here and post a link to my Pressure Pro experience:
http://www.airforums.com/forums/f206...tml#post453263
We won't travel without them anymore.
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 11-18-2007, 07:49 AM   #23
2008 27' Safari FB SE
tustin , California
steel vrs rubber stems
For those of you that are using the PP system, have you changed your stems to steel or are you having good luck with the factory rubber units.
The reason I ask is I'm ready to install my PP unit but the factory included a note saying that they recommend steel, my trailer is a 08' 27 fbse, with about 1,000 miles on it, I will change them out in a hart beat if anyone has had any problems with the units that AS uses, thanks for your help, as stated befor, this is a great forum.
terrygaines is offline   Reply With Quote
Old 11-18-2007, 07:53 AM   #24
lewster's Avatar
Terry,
Regardless of what PP says, I would change out your valve stems to metal immediately. Many tire inflation problems can be traced to leaky valve stems, and it's the very first thing I would change on any tire hat had rubber stems. They just don't have the longevity or air holding capacity of a metal stem.
Old 11-19-2007, 08:29 AM   #25
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The PP, as described, may be like adding a weight to the wheel. I don't know how much they weigh (never seen one), but the lead weights added to wheels to balance them aren't very heavy. So…
Would the wheels have to be balanced when any pressure measuring system is added to the valve stem?
Gene
Old 11-19-2007, 08:53 AM   #26
1984 31' Excella
Norfolk , Virginia
Images: 11
Balance
I use balancing sand so the added weight of the sensor is compensated for automatically. Centramatics will do the same thing.
Beginner
Old 11-19-2007, 04:58 PM   #27
lewster's Avatar
The PP sensors weigh about 0.75 oz. and if they make a niticeable difference to your tire balance, they recommend addind a 1/2 oz. weight opposite the sensor.
I use a tire sealant that also balances the tires as you drive like the Centramitics, but you get puncture protection as well. Never had a probem with balancing after that............
Old 11-27-2007, 10:05 PM   #28
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Thanks for this report, Tin Diesel...I am serioiusly considering the Pressure Pros for our 19' 2006 Bambi...only 1 axle and I don't want either tire to go completely flat en route...nor do I want to discover a shredded tire after it's too late and the damage is done...
Did you have to rebalance your tires when you put them on, and did you change out the facatory valve stems?
One other note, just to put it out there...our Tacoma has factory tire pressure monitoring sysem...it has alerted us twice (since getting it in March) to pressure problems before they became a problem...and I have been very happy with the system. I believe the factory truck & auto systems are a different breed than the after-market technology, so I feel like comparing them is an apples and oranges thing. I also believe it's still prudent to check the tires regularly even if you have these systems...it certainly can't hurt to take a look before you look down the road.
Travel well...
TB
TB & Greg and Abbey Schnauzer
#3954
Tire pressures Silvertwinkie Tires 28 09-10-2004 11:00 AM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Flat tire detector Pahaska Tires 6 08-08-2002 06:38 PM
