Old 08-25-2016, 10:00 PM   #1
1993 30' Excella
Aptos , California
Lookiing for an approximate trailer tire life
Can't find the info at the manufacturer's site. We have Gladiator st22575r15 tires on a 30' 1993 AS put on about a year ago. We are at about 25K miles on these. Tread looks fine. How do I find the recommended life/mileage expectancy of these tires? Thanks.
Silver Wolf is offline   Reply With Quote
Old 08-25-2016, 10:17 PM   #2
Airstreamer In Training
FCStreamer's Avatar
2014 30' Flying Cloud
They have a two year warranty.
GLADIATOR ST LIMITED WARRANTY
American Pacific Industries, Inc. (API) hereby warrants that every new Gladiator ST Trailer Tire purchased from API bearing the brand name Gladiator to be free from conditions of workmanship and material that would cause the tire to become unserviceable for the life of the original tread less 2/32”. The life of the original usable tread ends when the tire tread has worn down to 2/32” remaining, at which point the tire is considered to be fully worn out. This warranty applies only to the original purchaser for a period of two (2) years from the date of manufacture. API’s liability under this warranty shall be limited to replacement and/ or credit for the cost of the tire.
http://apitire.com/wp-content/upload...eaflet_Web.pdf
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2013 Cadillac Escalade Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 08-26-2016, 07:36 AM   #3
CapriRacer
CapriRacer's Avatar
I'm in the , US
Just an FYI:
Most tire wear occurs in the cornering mode. Make a lot of turns and you wear the tire more quickly. This applies to motorized vehicles (cars and trucks) as well as trailers.
What this means is that tire wear can vary greatly depending on what route you take - and not the vehicle or the tire brand. I did some testing and got a range of less than 10K to over 100K miles from the same make and model of tires - and the major difference was how much cornering took place.
Since trailers - especially travel trailers - don't do much cornering, their tires hardly wear at all. They will much more likely need to be replaced based on time rather than miles. Some have said 5 years for trailer tires.
CapriRacer is offline   Reply With Quote
Old 08-26-2016, 07:58 AM   #4
Long Island , New York
You should look on the sidewalls and find the DOT-required date of manufacture on each tire. That will guide your decision. Anything older than 3 years, I would consider replacing before any major road trip. Older than 5 years I would replace ASAP, as CapriRacer suggested.
Date of Mfg. info:
http://www.tirerack.com/tires/tirete...160811155954:s
Good luck!
Peter
Old 08-26-2016, 12:40 PM   #5
2000 30' Excella
Greeneville , Tennessee
I just replaced mine on our 30' Excella. They look fine, no sidewall cracks, etc. The reason for this change was to go with 16" Syndell wheels and Michelin LTX tires. FYI, the Maxxix tires and Alcoa wheels are for sale. Just a note, our AS is ALWAYS covered and we have and use tire covers to avoid sun deterioration.
jimfa440 is offline   Reply With Quote
Old 08-26-2016, 02:37 PM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
3-4 years is all I've gotten from ST tires- the reason I will not be getting any more of those-
I might do 10,000 miles per year average, so 30,000-40,000 miles on a set of ST tires-
Sometimes they look perfect one weekend and then the next weekend- POOF!
Sometimes they give you a warning by the tread rounding out rather than being flat across the tread surface. If you ever see the tread rounded, go ahead and put the spare on and get new tires.
Even if you stay with ST tires, upgrade to 8 or 10 ply Load Range E.
That in itself will help them to last longer without separating.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-26-2016, 02:41 PM   #7
1967 26' Overlander
Spartanburg , South Carolina
There is a great article in the current issue of Airstream Life Magazine about Maxxis tires with a lot of very good general info on trailer tires in general.
I once ran a set of GoodYear Marathon's (made in Canada) for 13 years with no problems. I am currently running 2 year old GYM's (made in China) which now have about 3,000 miles and they are performing as well as the older set so far. In general, it is recommended to change tires when they have reached 5 to 7 years of age from the date of manufacture or when down to a minimum (I think) 1/16th tread depth, whichever comes first. On our tandem axle trailer with a loaded weight of around 5,200 lbs there was little tread wear after 13 years and approximately 10 or 15,000 miles. I keep them covered when stored for more than a few weeks and sprayed monthly with Armor All Tire Foam.
Jacob D is offline   Reply With Quote
Old 08-26-2016, 03:42 PM   #8
Old Sailor
McArthur's Avatar
1983 34' Excella
Victoria , Texas
Date of Mfg. info:
Good luck!
Peter
Thanks for the link. My Excella has been parked since I bought it two years ago while I finished the interior that the PO started. I towed it from Kentucky where I bought it back to Texas and have been intending to buy new tires before towing it anywhere. According to the link you provided, the week and year code on my tires are 353 which I understand means the 35th week of 1993. Scary, huh?
These tires would fool someone that knows nothing about tires. I knew they were old because they are 7.00X16's, bias ply, and look good with good tread and no sidewall cracks. Mounted on the original aluminum wheels.
'82 Excella 34' "AlumaLady"
'06 Ram 2500 Lonestar
"Mollie Bug" The Boston Terrier
WBCCI #4456 - Born to Cruise
McArthur is offline   Reply With Quote
Old 09-02-2017, 03:22 PM   #9
2004 30' Classic
Hillsborough , New Jersey
gladiator tires
I found this old thread and since I don't know how to start a new one I'll just start here.
I have two Gladiator 225/75R15 tires on my 2004 Classic 30 footer, purchased a couple of years apart. Also two Marathon tires.
I tried to find the date of manufacture and, like Silver Wolf, I cannot find the dates of manufacture. I called the tire store from whom I bought the tires and they said "the Chinese tires did not have the DOT dates on them prior to a couple of years ago."
I know that there are some tire experts on this forum, so can anyone give me some guidance as to what the codes next to the DOT: box means?
One tire shows: DOT: PPTD GTS in another box shows G-4
The other tire shows: DOT J 2 DT GTS
The tire store said the tires should have a 10 year life span, yet I have read on this forum that many believe that the tires should be discarded after 5 to 6 years. Anybody out there who can help me out?
Wolf146
wolf146 is offline   Reply With Quote
Old 09-02-2017, 03:51 PM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Trailer tires don't wear out. They age out. 3-5 years on ST rating. LT can be longer.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 09-02-2017, 05:42 PM   #11
Mollysdad's Avatar
I think all tires sold in the US have DOT date codes. 4 digits after 2000.
However, they may only be on one side of the tire. Take one off or look on the inside with a flashlight. Although the odds of all four being inside is rare.
Amazon sells the 225/75R15 Gladiator tire for $60. Holy smoke, way cheaper than GY Marathons.
Gladiator tires are imported by American Pacific Industries Inc. (API).
Surprisingly, I couldn't find a lot of complaints about them.
Seemed to be OEM on boat trailers.
Good luck.
Old 09-02-2017, 06:42 PM   #12
richw46's Avatar
Lexington , Kentucky
I've heard that after 10 years tire manufacturers won't even talk to you, but I can't find that reference today. Most sites are saying 6-7 years IF the tires appear to be in good condition (no cracks), are used regularly (not sitting for 6 months at a stretch) and are protected for the sun as much as possible (tire covers). Regular travel and not overloading will also extend the usable life. ST tires don't have a deep tread on them, so don't go by tread depth. Time is the enemy on trailer tires. Trailer tires are supposed to follow the tow vehicle, not grip the road because that builds up heat. Use age and appearance as your guide.
If you are wondering if your tires are good enough, maybe it's time to get new ones. Is another year of savings worth the trouble and expense of a blowout? If older than 6 years replace and baby the new ones.
From Goodyear:
http://www.goodyearrvtires.com/tire-...uidelines.aspx
Goodyear does not state a specific replacement age for RV tires because there are many conditions that dictate a tire's life span. Some factors that influence how long a tire will last are:
Usage per year - more frequent usage will result in longer life
Vehicle storage practices (6 months loaded with little or no rotation is not good!)
Usage in warmer climates can also impact a tire's overall life due to greater extreme ozone exposure
Sidewall
Weathering
Weather cracking is a naturally occurring condition that results from exposure to heat and sunlight. Goodyear's warranty for weather cracking is four years from purchase date (or four years from manufacture date if proof of purchase is not available).
Weather cracking is common in RV tires from all manufacturers.
Appears as crazing and or cracking in the flex area of the sidewall
Probable causes of sidewall weathering
ó Long periods of inactivity or storage
ó Direct exposure to air and sunlight
ó Exposure to high levels of ozone (smog, electrical generators)
ó Excessive washing or dressing using alcohol or petroleum based cleaners
When should the tire be replaced?
Cracks > 2/32" deep
Internal components of tire (steel or fabric body plies) are visible
Without evidence of weather cracking, use the following as a gauge:
Usage per year --More frequent usage will result in longer life
Casing quality --Absence of repairs, liner wrinkles, weather cracking, sidewall scuffs or cuts
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 09-03-2017, 07:52 AM   #13
CapriRacer
CapriRacer's Avatar
I'm in the , US
Wolf146
[/I]
Look on the other side of the tires. The date code only needs to be on one side and you are looking at the side that doesn't have it.
Approximate Total Wattage 22fb Sport? LannyD Generators & Solar Power 10 10-07-2016 05:10 PM
Tire life and replacement RetiredGuy Tires 7 10-07-2009 01:35 PM
Tire Life Smokin Camel Tires 3 11-24-2008 08:22 PM
The "Rule of Thumb" on Tire Life RangerJay Tires 27 03-22-2007 10:58 AM
Approximate weight of various Airstreams LonnieW Towing, Tow Vehicles & Hitches 4 10-27-2003 08:50 PM
