Old 02-25-2014, 06:38 PM   #43
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Originally Posted by vegangirl57 View Post
Hi Everyone,
Well, Discount tires was very nice. Their Claims department in Arizona is going to send a check for the repairs...
Thank you all!
Sounds like a company worth supporting!!
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 02-25-2014, 07:53 PM   #44
JFScheck's Avatar
Rockville , Maryland
Images: 33
I agree - I will use them now!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 02-25-2014, 08:01 PM   #45
2007 25' Safari FB SE
San Antonio , Texas
Ok. Dumb question but I am glad t read this. Where do you put the jack. 2007 25FB
AJUNEK is offline   Reply With Quote
Old 02-25-2014, 08:38 PM   #46
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I have single axel Bambi, so blocks dont work for me, right? I purchased a jack and four way thingy to keep at all times. On the jack box I wrote where jack goes, but as soon as all the snow melts, I will be down under adding reflective tape. I think my hardest part would be getting spare tire out, and instruction manual.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 02-25-2014, 08:59 PM   #47
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Originally Posted by Zigidachs View Post
With our last tire replacement ( Michelin recall) I used a local tire shop and was on my hands and knees with the tech pointing to the exact locations for the jacks! I didn't take any chances.
We've had our tires changed at tire shops, and like Zigidachs, I am right there with the tech them showing where to put the jack and I stay there the whole time. If they don't want me to watch I will not let them do it.
I have changed a tire along side the road twice using a bottle jack ... once from a flat in town (valve stem failure) and once from a blowout on the highway. Neither were fun. Having a single axle, we have no choice but to jack. It worked, but it was hell, so I now carry a floor jack and use the axle bracket rather than the jack points ... A floor jack works better because you can get the rig high enough to get the tire off and the spare on.
TB & Greg and Abbey Schnauzer
#3954
Old 02-25-2014, 09:14 PM   #48
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Hints on getting the spare out of the rack:
Before
you jack the rig up, standing on the curbside of the tongue, release the spare rack latch using your left hand to squeeze the rack arm in the latch where the pin is, lifting it slightly up to lessen the tension on the latch ... this makes it much easier to get that pin out ... then move the latch mechanism off the arm and let the rack down to the ground.
Then move to the street side of the tongue and sit on the ground with your legs spread to either side of the lowered rack... this gives you the leverage to drag the spare out of the rack through the forward opening in the rack with your hands .... much easier than trying to stoop over to get it out.
After
you have the spare on the rig and off the jack, reverse this process using your feet to push the flat tire into the rack (unless you can carry the flat tire elsewhere).
Don't forget to re-latch
the spare rack in the upward closed position before you take off! I would practice getting the spare out at home BEFORE you need to do it along side a busy road.
#3954
Old 02-26-2014, 03:50 AM   #49
2006 19' Safari
New Smyrna Beach , Florida
What is an axle bracket?
nsbcpa is offline   Reply With Quote
Old 02-26-2014, 05:36 AM   #50
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by m.hony View Post
But I do have the tire change ramp in the trailer.
The jack that came with the truck is not heavy duty enough to lift the trailer.
Hauling a floor jack around doesn't appeal to me- too heavy for me to lift and eats up payload...
You don't need a floor jack - a bottle jack will do the job. That's what I use at home. They're not that large, either, so you probably could find a spot to store it in the camper, and they're fairly inexpensive to boot.
I don't carry it with us when traveling, so the one time I had a flat on the road, we pulled it up on blocks to change the tire. If it were going flat in the campground, I'd probably have to hook up and do the same - although I wouldn't bother with the lifter bars and sway control, just drop it on the ball and put the spare on. I'd be tempted to just wait until we're hooking up to leave if at all possible, then just switch at that time. This delay wouldn't work if it was leaking so badly that the trailer was putting too much weight on the stabilizers.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 02-26-2014, 05:42 AM   #51
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The axle bracket is the part that hangs down where the axle is mounted to the frame. You can use that or the axle mounting flange on the frame.
Old 02-26-2014, 07:16 AM   #52
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
I never leave home without my "trailer assist"; it is easy, safe and weighs almost nothing. I keep it in my TV all the time.
Trailer Aid - Free Shipping on Orders Over $99 at Genuine Hotrod Hardware
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 02-26-2014, 09:09 AM   #53
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Before
After
Thanks for posting these hints, which I added to our trip binder!
SilverGate is offline   Reply With Quote
Old 02-26-2014, 11:15 AM   #54
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I carry a bottle jack at the bottom of a closet that's over the curbside wheel well. There's just enough room between the door and the wheel well for the bottle jack, a folding sewer hose support (that I've used about 3 times in 3 years) and the coupler lock that I use when the trailer is stored.
I've only lifted it with the bottle jack, because the storage sheds are paved with gravel so a floor jack would be inconvenient at best. It has plenty of lift to get the trailer high enough.
— David
Old 02-26-2014, 01:07 PM   #55
Baltimore , Maryland
Originally Posted by T1NCAN View Post
I just checked mine, and it is CLEARLY labeled where to place the Jack.
I would be very careful of that assumption. I have an 04 34' in the shop. It has a big reflective decal saying "JACK". The problem is, that decal is 9" from the frame rail where you actually are supposed to jack. Had I not known, had I gone by the owners manual, I would be fixing the belly pan instead of moving on to the next project. The location back to front is very critical, but more critical is the jack being under the frame rail.
Old 02-26-2014, 02:59 PM   #56
golfarch's Avatar
2007 27' Classic FB
Myrtle Beach , South Carolina
Hey Veggie Girl:
All things happen for a reason! It's waiting for and accepting the 'reason' that makes life interesting. Hang in there, something good will come from this.
"The Percolator"
golfarch is offline   Reply With Quote
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
235/75R15XL vs 225/75-15 trailer tire perryg114 Tires 129 07-18-2012 01:59 PM
New tire problem madpaddler Tires 6 11-07-2011 05:49 PM
Very strange tire wear rbhinzman Tires 17 10-21-2011 08:43 AM
