Old 04-06-2011, 10:26 AM   #1
Hillbilly Hagrid
KyMoonshine's Avatar
1973 29' Ambassador
Stanford , Kentucky
Local Tire Brands....
I shop local if I can...its how my neighbors make a living....sometimes its impossible to get exactly what you need...
My question is about tires.... I am replacing the tires on my 73 Ambassador and need your advice....
It has H78-15ST tire size on it now... I realize this is an old number and best I can figure it translates to a 225/75 15 in current tires..is that correct?
The only local tires I can find are:
Greenball Towmaster 8ply D load radials
King Trail d load
some other places had tires like a GT Radial and some others I have never heard of....
Is the Towmaster a good tire?....I can get four of them out the door for $485.00 and its right around the corner....
Thank you for any info I did some searching but not enough info was found....
1973 29ft Ambassador Double Center Bath International Land Yacht
KyMoonshine is offline   Reply With Quote
Old 04-06-2011, 11:08 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Yes. You might need new rims, if your old ones are two piece.
King Trail d load
In general I have had good luck with unusual brands of tires from reputable local dealers. No idea on those specific ones, and I suspect that to an even greater extent than major brands they are produced in different factories at different times so you never know for sure what you really are getting.
Old 04-06-2011, 12:51 PM   #3
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Be sure to read the DOT date code on the tires the dealer wants to install for you. The code will be something like (DOT 0311) (this is only an example of numbers), meaning the tires were built in the 3rd week of 2011. You want NEW tires, not old dealer stock.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 04-06-2011, 12:51 PM   #4
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
I have purchased trailer tires several times over the past 4 or 5 years for my two trailers. Each time I did some research. As to the Greenballs, I believe they are now made in China. Some folks seem to have great results with them, others complain about them. But that seems to be the rule for most trailer tires, even Goodyears. So, like the rest of us, I guess you will have to "spin the wheel" and hope for the best that you get a good set.
That said, what I have purchased and drug down the highway at 65- 70 mph, over a few curbs in tight spots (oops) etc. have been Maxxis M8008 ST tires. I purchased mine from Discount Tire Direct . Right now, other than running a Michelin LT (truck type) tire, they are the tire I tend to recommend based on my experience and research. I believe that they are a Taiwanese company. Some folks have problems with them too, but most seem to be like me, very happy with them.
I know you want to keep the money local and I respect that, however, I would do some research and make sure you are happy with what you are buying (and maybe that will be the Greenballs).
On topics like this I always suggest checking out RV.NET (same as Trailerlife Open Roads Forums, Woodalls Open Roads Forums and I think Good Sam forums that share the same forum under different names). Airforums is super, but RV.NET, has many more folks posting as it is a general RV / SOB site and is great for stuff like tires. Of course as always you need to sort the wheat from the chaff.
Good luck and safe travels no matter what you decide to do.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 04-06-2011, 01:14 PM   #5
Ottawa , ON
From what I have read on the net, it appears that Towmasters are made by Greenball in China.
Old 04-06-2011, 04:56 PM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The 1973 trailer will not have split rims. Split rim usage on Airstreams stopped in the early 60s.
>>>>>>>Action
Action is online now   Reply With Quote
Tire alignment sawyerpoint Tires 4 06-29-2011 05:04 AM
On-axle tire and wheel balancing Jammer Wheels, Hubs & Bearings 8 02-16-2011 05:56 PM
Any good tire covers? hhendrix Tires 15 02-01-2011 02:43 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
TowMaster range E trailer tire tvanwave Tires 8 01-14-2011 04:50 PM
