Old 02-12-2017, 03:43 PM   #1
2017 30' Classic
Roaming , Many
Leaking Tire, Questions
Hoping to get some suggestions on a course of action for a tire that's leaking on our 2016 Classic we picked up in December. We brought it back from Wisconsin and it went straight into storage. Probably should set the stage as well, we're newbies to all of this.
We've been "visiting" at least each weekend and a few weeks ago my wife noticed one of the tires (front, left) was looking low. Check the PSI at 16.5 versus the 80 it's supposed to be at. Used my tire inflator to bring it back up. A week later it was down about 10PSI. Inflated again. This weekend it was completely flat. Pumped it back up but wondering what to do at this point.
Because it's gone completely flat, is the tire shot?
I don't see any reason for the loss of air. Could be something under the tire that I can't see. Could hitch up and roll it so I could check.
Should I just remove it and take it to a tire shop and have it checked out?
Any other suggestions would be appreciated.
Nelsonsrus is offline   Reply With Quote
Old 02-12-2017, 05:14 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I think your tire should be fine once it gets fixed. Last month I had a tire go flat on my car while it was parked in the garage. I took the tire to a tire shop and they patched a puncture and told me it should be fine. So far so good.
There are a few possibilities for what is wrong with your tire. I can think of
1) puncture
2) Bad seal of tire to rim
3) defective valve stem
4) leaking core in valve stem.
#4 can be fixed by a low-skilled do-it-yourselfer like me, with a cheap little tool from an auto repair shop. Anything else I would take it to a shop. If you want to investigate further yourself, you could re-inflate it and put some soapy water on the valve stem to see if you get bubbles there. That might locate the problem.
SSquared is offline   Reply With Quote
Old 02-12-2017, 06:14 PM   #3
r carl's Avatar
Lin , Ne
I would do what my grandpa and my dad would do, take the tire off and get it fixed.
Old 02-12-2017, 06:18 PM   #4
Plasma800's Avatar
houston , Texas
take the tire AND wheel off and head for discount tire. Call Airstream ahead of time. If you notify them before the work there is a good chance they will reimburse you under warranty.
I had a tire on my brand new f150 that kept losing air. 3 attempts at discount tire didn't resolve it. I put a new tire on and it's been perfect. I still have no idea why....
Regardless it would be a good idea to get the weight off the one good tire...
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 02-12-2017, 07:03 PM   #5
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Yes, good advise, how hard is that just get it fixed period, jesus!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Tire pressure and tire temperature questions Stewball On The Road... 20 01-17-2017 05:52 AM
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 11:38 AM
Tire protection, tire cover and airconditioning leong1 Tires 0 06-22-2009 04:02 PM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
