Old 08-16-2007, 07:07 PM   #1
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Knowledge of this Tire
Hi All,
When I bought our AS the tires were dry-rotted, not knowing anything I removed them and took to the local Discount Tire Store, told them what they were for and that I needed replacements.
They replaced with:
Supermax LT.0015 Made in China
QZ-106
8P.R
Max Load Single 2040lb. @ 60psi
Max Load Dual 1820lb. @ 60psi
Are these suitable/good/poor tires, as I know nada.
thanks for the help
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 08-16-2007, 08:34 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
China and tires...etc.
Lots of discussion here, and in the press, about the delamination problems with some China made tires. Discount Tire Co has a good rep here in this part of the country. I wish you would have researched more before the tire buy. For all your future buys...look thru these forums....great info from great folks. Helps is always at hand.
Old 08-16-2007, 08:46 PM   #3
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Never heard of the brand nor the size you note, but "LT" sure sounds "Light Truck". Generally people chose ST or "Special Trailer" tires for their Airstreams, because ST's are made for trailers and LT's are not. That said, I think LT's are used on some of the larger 5th wheels.
ST's supposedly have a different compound to better withstand UV exposure, because they tend to sit and not move for longer periods of time than truck tires. This is becuase most trailer tires "rot out" rather than "wear out".
The tire you got may be OK, but who knows. I'd have preferred to have gotten an ST tire in a known size from a brand I'd at least have heard of. Sometimes in an emergency that may not be an option. Good Luck.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 08-17-2007, 06:39 AM   #4
1970 27' Overlander
Houston , Texas
I wish I had of researched more to but I knew nothing of this forum or travel trailers at that time. Just told them what the tire was for. Thanks to this forum I have learned tons in the past year. Hopefully I can start to be a contributor instead of an "asker" in here. Tracked fedex this am and axles are due for delivery today!!!
I will call Discount and talk to them about the tire today.
James
____________
1970 Overlander
Old 08-17-2007, 06:52 AM   #5
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Fedex? What kind of axles did you buy?
Welcome to the forums by the way! Enjoy the new AS!
Marc
Old 08-17-2007, 06:54 AM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Not familiar with that tire, but if you do a search on tread seperation, you may find lots of great info on tires.
Old 08-17-2007, 07:45 AM   #7
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
You know, with all the "bad press" products from China have been getting over this summer, I really am more than ever disposed to buying Made in America. For years I've heard about the "junk" coming out of China and now it is being born out in the press so I would be a little leary of anything, especially something as safety oriented as tires, from China these days.
I know at the time you had few options and didn't have the information at your disposal to make quick decisions. But it seems like many of the tire issues discussed on this forum have been related to Goodyear Marathons and other brands that were manufactured in China. IIRC, the Goodyear Marathons that were manufactured in Canada haven't had the same problems as those from China. I know I seem to be ragging on China a lot considering there have been two food processing plants right here in Georgia that have had botulism contamination within the last 4-6 mos. (Peter Pan peanut butter and Castleberry meats) but they are the exception to the rule here, I think, and both cases were issues of building maintenance, IIRC, not the actual food processing/recipes.
Anyway, you have the tires so I would keep a very close eye on them. Keep the tire pressure at the max listed on the tire wall. Make sure you do a visual before you hit the road each and every morning of the trip. Keep a close eye on the side wall temperature and make sure that none are unusually warm/hot compared to the others. If you can, find out the safe operating range for the temperatures and invest $50-$80 in an infrared thermometer to keep a closer check on those temps at each stop and make sure those stops are at least every 2-3 hours. Get a tire dressing product that replaces the rubberizes and apply it to the tire sidewalls several times a year. Don't get the petroleum based product, get the silicone based one. And plan on replacing the tires earlier than you might have otherwise. I think the lifespan of camping trailer tires is about every 5 years or 10,000 miles whichever comes first. Perhaps you should plan on replacing them at 4 years or 8,000 miles whichever comes first unless you see a problem developing. Your trailer being an older one, it is probably lighter and shouldn't wear them out as soon as if it were a newer, heavier one so you should be OK. But when it's time to replace them, you will have time to research tires on this forum and there may be a shift in opinions as to what is best as far as brand performance by then.
Now, here I have rambled on and on as if I were an expert and all I've done is give my personal opinion. It is worth every penny it cost you, but I hope it has offered you some advise as far as keeping an eye on the tires you have.
Good luck and happy camping.
Family of Disney Fanatics
WBCCI# 4821
Old 08-17-2007, 07:49 AM   #8
1970 27' Overlander
Houston , Texas
Its FedEx Freight, axles from Inlandrv. Discount assures me this tire is one of their standard tire for TT's, its an 8ply and the LT does not stand for light truck. I will continue to look into it though.
James
____________
1970 Overlander
Old 08-17-2007, 08:26 AM   #9
richinny's Avatar
2011 34' Classic
Originally Posted by jsflint
Hi All,
They replaced with:
QZ-106
8P.R
thanks for the help
James
i believe they are made by maxxis. try searching under "maxxis"
Old 08-17-2007, 10:17 AM   #10
Hi All,
They replaced with:
QZ-106
8P.R
thanks for the help
James
Use "extreme caution" when adding 8 ply tires.
If your trailer has used 6 ply tires for an extended period of time, adding 8 plies to them will cause the wheels to split.
If you want to use 8 plies, and the old tires were 6 plies, you must change the wheels, to avoid the failure problem.
The wheels must have a minimum rating of 2600 pounds each.
Old 08-17-2007, 10:37 AM   #11
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
To add to Andy's info - our vintage wheels have trapped moisture along the tires' bead sidewall seal for so long corrosion will have etched away considerable metal just from where it is needed the most.
When I bead blasted my wheels, one could count how many times the tires had been changed and/or how many times the AS had sat long term exposed to the elements by the various swoop shapes of missing metal, mm wide trenches of noticeable depth running for about 90° just above the rim shoulders. Before I tow seriously there will be new wheels installed, the spare rim was affordable but trailer ain't going far for now... I went with Canadian Goodyear tires and so far there are no problems!
I painted the bead area with a single coat of automotive epoxy spray paint - no issues with long term air leaks for now. I wonder if there is a product that would protect the rim more than paint without harming anything over a period of years?
Old 08-17-2007, 10:38 AM   #12
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Use "extreme caution" when adding 8 ply tires. If your trailer has used 6 ply tires for an extended period of time, adding 8 plies to them will cause the wheels to split. If you want to use 8 plies, and the old tires were 6 plies, you must change the wheels, to avoid the failure problem. The wheels must have a minimum rating of 2600 pounds each. Andy
Hi Andy:
jsflint's new tires have an 8 ply rating, not 8 plies, and are rated to carry a maximum load of 2,040 pounds when inflated to 60 psi and used as a single tire. Why would he need new wheels rated at 2,600 pounds for this 2,040 pound maximum load tire?
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 08-17-2007, 11:59 AM   #13
Originally Posted by 47WeeWind
Hi Andy:
There are three reason for using 2600 pound wheels.
1. Airstream says so for 40 plus years.
2. Experience says so.
3. Side loads on wheels become huge.
The tire rating has nothing to do with the rating of the wheels.
Old 08-17-2007, 12:02 PM   #14
1970 27' Overlander
Houston , Texas
Getting really nervous now
New axles arrived
____________
1970 Overlander
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Spare tire storage mysilverbullet Our Community 9 10-23-2002 10:35 AM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
