Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 11-07-2003, 06:45 PM   #1
Tinsel Loaf's Avatar
Profile:
Keeping Tires & Rims?
I have a question about keeping my tires & Alcoa rims on my AS. I think this has been answered on the our form before, but I'll ask again. The other day I noticed some rather shady looking individuals admiring my AS rims. There is no locking lug nut on any of the four rims. Where do you find locking lug nuts which are comparable looking for AS rims. Also should there be different key for each lug nut or will one key for all nuts be sufficient.
Tinsel Loaf is offline   Reply With Quote
Old 11-07-2003, 09:37 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Locking lug nuts are available in many sizes.
Usually they come in sets of 4, with one key fitting all 4 locks.
The different styles are either a lug nut with no hex, but an oval shaped groove with a corresponding "key" for your lug wrench, or the kind with a locking sleeve over the hex.
I prefer the sleeve type.
Truck accessory places should be able to help you. Take one of the lug nuts with you when you go shopping. To get close, start looking at 3/4 ton stuff. The stud size and hole pattern is reminiscent of 3/4 ton trucks of the 80's.
Good Hunting!
Uwe
www.area63productions.com
Old 11-07-2003, 09:55 PM   #3
dinoburb's Avatar
Profile:  1982 34' Limited
Tidewater , Virginia
Save the Wheels!!
Hi Tinsel Loaf,
Something I learned in the mid-'60s (ouch!) is that to properly lock your wheels you should conside two locks per wheel. What this does, especially with the locks as opposite each other as possible, is reduce the possibility of a thief, upon discovering the locked wheel (one lock), take the other studs off and pull on the wheel to break the center section (sort of an, 'if I can't have it, you can't either!' mentality). With only one lug holding an aluminum wheel there is enough leverage opposite the locked stud to break the wheel. Using two per wheel reduces this probability.
Just a thought.
Take care,
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 11-08-2003, 11:15 AM   #4
Profile:
Thanks for the info. I'll get some lock nuts Monday. Good idea dinoburb, never thought about a crooks attitude when getting ripped off.
Old 11-08-2003, 04:23 PM   #5
Profile:
Just be sure not to forget the key-socket when you leave for a long trip. I knew a friend who did this and he was not a happy camper. OK OK I admit it! It was me! Geez!
bbb
biggerbadbrad is offline   Reply With Quote
Tires Causing Sway? Pick Tires 14 12-03-2006 04:38 PM
Questions about trailer tires... cactushead Tires 2 10-22-2003 05:58 PM
Tube type tires for 77 alum rims Mike B Tires 10 04-09-2003 08:04 PM
"We don't normally balance trailer tires....." Pick Tires 14 01-16-2003 04:45 PM
tires? trailer will sit after move goodgrey Tires 4 12-06-2002 02:10 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
