Old 06-24-2013, 12:47 PM   #57
dznf0g's Avatar
Oswego , Illinois
Interesting...I have noted no difference in temp nor pressure rise between 70, 75, and 80 psi. I'm running 70 psi right now. Ant the AS tires always run a little hotter with a bit more rise than the truck tires. AS tires run between 117 and 128* depending on ambients.
-Rich-
Old 06-24-2013, 06:36 PM   #58
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I've found that dropping down to 72 psi seems to work well on my rig. I follow the pressure and temp with the Dill carefully, and there've been a few instances where I've been on some washboard roads where an 80 lb psi would have whipped the cream in my fridge.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-24-2013, 07:06 PM   #59
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I run 70 lbs cold on my 28 ft
Old 06-24-2013, 10:07 PM   #60
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
The temps on my new Michaelin LT's haven't gone over 80 degrees even with ambient going over 100, very cool. Handling, sway and ride are so much better than with the ST's, it isn't even close.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 06-24-2013, 11:52 PM   #61
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If you think your tires are running cooler than the ambient air temperature you may not be measuring the temperature accurately. There's nothing that would keep them cooler than the surrounding air and lots of things that would heat them up like the road surface, sunlight and flexing as they roll down the road. I find that my LTX Michelins (the 15" ones that work great for my tandem-axle vintage trailers) run just a little over ambient temp when running down the highway, much cooler than the STs I had before.
David
Old 06-25-2013, 02:31 PM   #62
interstateflyer's Avatar
2017 25' International
Los Osos , California
Tire temps taken with a racing quality infrared pyrometer on Michelin LTX M/S 2 LT225/75 16Es on SenDel T02s last week in ambient temps of 88-91F on a reasonably smooth 80 mile stretch of highway, immediately after stopping. 80 psi cold.
Truck LF 112 RF 109. Truck LR 114 RR 113. Single axle 2013 Bambi 19. LR 117 RR 117.
The Dodge Ram's computer had it's tires at 44-45 psi hot.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 06-25-2013, 09:52 PM   #63
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I have been running E-rated ST tires at 70#. I think I'll start out at 70# with the 16" Michelins and see how the 28 tows at that pressure.
A friend that went the LT route claims a small, but measurable, increase in fuel mileage over his former E-rated Carlisle ST tires along with great handling.
After Southwest Wheel totally screwed my wheel order up, I ordered elsewhere and the rims should arrive here Thursday by Fedex. I reordered from Trailer-Wheels.com in LA and I'm impressed with their service. They didn't have the exact wheels I ordered, though they were still on their website. They called me and offered a nicer wheel at a lower price for my trouble.
John W. Irwin
WBCCI #9632
Old 07-05-2013, 07:56 AM   #64
pappy19's Avatar
We just got home after a 2,000 mile trip and have a total of around 4,500 miles on our new Michaelin 16" MS-2's and they still look brand new. I also have the Centramatics on the AS and my TV. Seem to be working on both. Time will tell, but my monitoring system shows no temp or pressure issues.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Old 09-03-2015, 09:58 AM   #65
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Apparently all ST trailer tires are bad about tread separation.
I nipped it in the bud.
I joined the LT truck tire movement, too.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-03-2015, 11:03 AM   #66
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . previous comments not withstanding, 2 ASs with GYMs, not a single problem in nearly 35k miles, Current AS just went 11,400 thru the rough roads of Western Canada & Alaska on a set of new Carlisle trailer tires without a problem ! Had a blow out on a Michelin on my TV ! just sayin', regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
