Old 06-12-2013, 07:03 PM   #43
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
Originally Posted by polarlyse View Post
Are we confidant whether or not the 15" LT tires have an adaquete load rating to handle the 30'ers. I've read some threads on the changeover to LT tires but I'm confused as to if they will handle the load without having to go to 16"ers. Maybe someday but not interested in going that route right now.
Once you derate the Michelin LTX tires as per DOT guidelines, then the rating is less than half the axle rating for my 30' (2005 Safari LS Bunkhouse) - but more than adequate for the weight as measured on the scales.
I've not heard of any issues with the LTX tires on this same model of AS.
The tires were well recommended by Andy T at CanAm RV -
MaxTow is offline   Reply With Quote
Old 06-12-2013, 07:31 PM   #44
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
Originally Posted by Captain Hank View Post
Sandlapper,
There is a date code on every tire. Look on the sidewall by the DOT number and the code will be the week and year the tire was made. (Ex: 4912)
A few days ago I ordered Michelin 15" LTX MS2 tires from Tirerack and had the same concern because in the past I had a bad experience with Discount Tire Direct shipping me ST tires that were 18 months old. It you call Tirerack they will tell you the age of tires they recently shipped that are the same brand and size you are interested in.
When my new tires arrived the age information provided by Tirerack was accurate.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 06-12-2013, 08:02 PM   #45
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
I have a Safari 30 also and the gvwr is 8400, derated the 15" michelins should bring you in right at 8k. I have 5 kids and have never weighed more than 7670 lbs and that is full of water. Should be fine on the bunkhouse
SafariSS is offline   Reply With Quote
Old 06-12-2013, 08:20 PM   #46
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by JamuJoe View Post
Installation on the trailer was easy using a Camco Trailer Aid 21 Tandem Tire Changing Ramp - much easier than using a bottle jack.
Would you look closely at that ramp to see if has an expiration date stamped on it somewhere? I know the Camco wheel chocks do. That would be a lot lighter than the wood ramp that I carry with me.
Alan
Old 06-13-2013, 07:23 AM   #47
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Thanks Max for summing that up. I think I'm good for this season but perhaps by next year I'll be looking to upgrade the rubber. I have good service with the Michelins on my truck and would likely stick with them for the trailer too.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-13-2013, 05:48 PM   #48
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Ramble On View Post
I just ordered 4 Sendel T03 66655st wheels from Tredit and will pickup tomorrow. Now the tougher debate as to which LT tire to match to these wheels. I have narrowed my choices to either Michelin or Bridgestone.
Michelin LTX M/S 2 $245.00 29.2 dia 38.2 lbs
Duravis R250
(steel casing) $223.00 29.4 dia 52 lbs
Duravis M895
(steel casing) $225.00 29.4 dia 53 lbs
Duravis R500 HD 183.00 29.2 dia 41 lbs
Any opinions or suggestions?
Of these, the r250 as it has shown excellent performance for commercial operators of hotshot / LTL equipment. None are bad choices, per se. The BFG Commercial T/A (a slight step down, but we don't run high miles with RV's) is my second choice.
Old 06-13-2013, 06:09 PM   #49
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Also taking the plunge. Getting the Sendel T07 Black Machined rims, Michellin LTX and adding Dill TPMS sensors. Should be a significant upgrade.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 06-13-2013, 09:17 PM   #50
Ramble On's Avatar
2004 28' International CCD
rockwall , Texas
I got a decent price on the the Michelin LTX m/s 2 plus a rebate, so I went for it. The manager of the tire store said that this was a popular tire for trailers and they sell alot of them for that application. His opinion of ST tires was "JUNK", just confirming that my decision was the right one. At least one national retailer of tires is on board with using LT tires for trailers.
Name:	2013-06-13 10.09.49.jpg
Ramble On is offline   Reply With Quote
Old 06-14-2013, 08:24 AM   #51
Ramble On's Avatar
rockwall , Texas
I guess I should have looked into TPMS prior to having tires mounted. Let us know how the Dill system works out. I think I need to establish a budget, things are getting out of hand. An Andersen hitch is next on the list.
Old 06-14-2013, 10:41 AM   #52
Westfalia's Avatar
Images: 35
It's not a cheap extra, but neither is blowing a hole thru the side of your wheel well. There is another system that I have discovered that has external flow thru sensors that screw on to the valve stems, provided that you have metal valve stems. It might be worth looking at:
New User Replaceable Bat - Truck System Technologies, Inc
Old 06-14-2013, 11:15 AM   #53
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I have run the Dill system for two years and it works great for me.
Cheap insurance and peace of mind.Gives real time temp and pressure.
Sensors sleep when not in use extending battery life of sensors.
Old 06-15-2013, 06:54 AM   #54
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Just noticed Airstream2GO website photos, the Airstream rental company in LA and Las Vegas has the "Eddie Bauer" 16" wheel/tire option on their fleet of Airstream Internationals.
Not to mention two air conditioners on a 23FB as well as a 28.
doug k
Old 06-16-2013, 03:27 PM   #55
SafariSS's Avatar
2005 30' Safari
Wow...2 Acs on a 23!
Old 06-24-2013, 12:31 PM   #56
interstateflyer's Avatar
2017 25' International
Los Osos , California
Just returned from a 3 week, 2700 mile trip to the Pacific Northwest from Central California. The Michelin LTX M/S 2 LT225/75 16Es on SenDel T02s performed flawlessly on the International 19.
I ran them at 80 pounds cold most of the time. Tried 75 pounds in the cooler NWest for an easier ride for the AS. We had lost 4 curb side interior rivets on some brutal truck lanes in the SF bay Area. I suspect that 80psi exasperated that situation. What I did notice though was that tire temps on my infra red pyrometer were higher (8-10 degrees F) with 75psi. 80psi kept the temps almost identical to the truck's rears.
The 1/2 inch height increase of the wheels actually caused the trailer to tow perfectly level......a result that we were struggling for with the Husky WD system.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
