Old 04-16-2011, 07:34 AM   #15
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The orange ones (lynx) are available here:
Tri Lynx Levelers
Richard
Old 04-16-2011, 05:31 PM   #16
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
I picked up an 18v Pep Boys impact gun, extra battery and I can change a flat just like a Nascar pit man. I double check with a torque wrench when I tighten the nuts on the lugs. The impact gun was on sale for 79.00
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 04-16-2011, 05:54 PM   #17
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Ah, I checked our truck's jack and lug wrench. The wrench fits the Airstream as well, and the jack will lift it easily. The jack is a bit short, but we carry the orange things anyway to level the rig, so no need to add anything to what we're already carrying.
More recent Airstreams are a lot heavier than vintage, so it might be important to check the jack in the tow vehicle to make sure it can lift that much weight.
Lynn
WBCCI 21043
Old 07-22-2011, 03:20 PM   #18
2005 30' Safari
Dallas , Texas
Lug nut question?
Does anyone know what type of socket is required to remove this lug nut?
Thanks.
Name:	Airstream Lug Nut.jpg
willphil is offline   Reply With Quote
Old 07-22-2011, 03:31 PM   #19
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Originally Posted by overlander63 View Post
A chrome 4 way lug wrench would be a good addition for changing tire.
I use a 4-way lug wrench and I put the pipe that is used to flip up the chains on my hitch on the leg with the chisel end for extra leverage. That makes it easy to break the lug nuts loose initially. A socket on my drill makes short work of removing and reinstalling the lug nuts from there.
You should never use a torque wrench as a wrench to initially loosen the lug nuts. That is abuse of a tool. A breaker bar doesn't cost much if you don't want to carry a 4-way lug wrench.
John W. Irwin
WBCCI #9632
Old 07-22-2011, 04:31 PM   #20
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I have sometimes found (with various different vehicles) that lug nuts can at times be quite tough to remove with as standard cross type lug nut wrench, so I carry a 3/4" x 36 "breaker bar" to be sure I will be able to get the things off! Once loose, I use the same 18v drill that I use for my stabilizers and Hensley Jack screws to spin them off/on quickly.
I use the Lynx leveller blocks as others have mentioned - much easier than messing around with bottle jacks IMHO.
I also carry a torque wrench to re-install the nuts and I re-check them again after 50 miles or so of travel.
Brian.
PS you can usually get the Lynx lavellers at Wally World for way less than that well known camping store!
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-22-2011, 04:39 PM   #21
Wingeezer's Avatar
2005 30' Classic
Thanks.
I'm guessing that may be one of those fancy anti-theft lug nuts that is used with a special wrench to stop people from stealing expensive alloy rims.
Not sure where you would get something to fit unless the previous owner may still have the special socket. Might it be stored in your trailer somewhere?
Maybe you might have to improvise to get it off then replace with a standard lug nut?
Brian.
2005 Classic 30'
Old 07-22-2011, 04:50 PM   #22
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
As it turns out, the lug wrench in our Ford is the same size as the lugs on the Airstream. And the Ford jack will lift the Airstream. Problem solved for us.
Lynn
WBCCI 21043
Old 07-22-2011, 05:04 PM   #23
1985 31' Excella
Fresno , Texas
Thanks.
Looks like anti-theft one I would take a photo to some place like Discount Tire or where they sell wheels.
Wsmith is offline   Reply With Quote
Old 07-22-2011, 06:09 PM   #24
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I would not use the marked "label" jack point, If I had not been careful I would have jacked right thru into the bedroom. Use the axle mounting plates or the Lego blocks.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-22-2011, 06:35 PM   #25
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
I give all of my AS lug nuts a shot of WD40 each Spring........just in case.
62bam is offline   Reply With Quote
Old 07-22-2011, 06:53 PM   #26
Wingeezer's Avatar
2005 30' Classic
Any time I remove lug nuts - say to repack the wheel bearings - I put a smear of anti seize compound on the threads of the lug nut studs.
Only thing is I'm not sure if the added lubrication that creates might screw up the torque readings and might cause me to over torque the lug nuts, so I generally stop a little shy of the spec. torque reading.
Brian.
2005 Classic 30'
Old 07-22-2011, 07:44 PM   #27
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
What size torque wrench?
I went shopping the other day looking for a torque wrench for the AS. Got confused by the different sizes available. What size should I be looking for and is there a particular brand? I am expecting to spend some buck since I think cheep tools are NOT a good choice.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 07-23-2011, 04:36 AM   #28
Craftsman
CDI 1503MFRMH
Take your choice, CDI is made by Snap-on thus the price.
Chraftsman good unit, would work fine for the AS, easily available also lifetime guarantee.
Get 1/2" drive at least 150 ft/lbs.
I do not lube the threads, just keep clean, don't over tighten and always start by hand. Others may differ.
PFC
"Tahawus"
RLC
John Prine
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 08:08 PM
Jack point on 20 foot-Caravelle/Argosy ? glacierrunne Jacks, Stabilizers, Lifting and Leveling 1 03-16-2011 10:53 AM
Newbie question - decorative lug covers idmtman Wheels, Hubs & Bearings 9 02-05-2011 11:41 AM
