Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 12-13-2015, 09:16 AM   #1
Antiquepedaler
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
It could be my imagination
After six years of running the original GYMs on our trailer, I replaced them with Michelin LTs. I went with the 15 inch ones. It might be my imagination, but the trailer feels more secure with the Michelins. This is especially true when surpassing my personal speed limit of 63 mph when passing someone.
FYI. The GYMs were a year old when installed by the factory on our new trailer. So they were actually 7 years old when replaced.
Antique Pedaler
2021 Caravel 20 FB
Antique Pedaler is offline   Reply With Quote
Old 12-13-2015, 10:58 AM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Our change to Michelins gave me a sense of security that I never had with the GYMs, so much so that I went from constantly watching the trailer TPMS out the corner of my eye, to leaving the TPMS at home.
Too much of a sense of security perhaps, but after many thousands of miles without thinking about tires as we go down the road, the trip is at least more pleasant.
Doug and Cheryl
Old 12-13-2015, 01:41 PM   #3
2010 27' FB International
La Crescent , Minnesota
I did the same. Now inflating the tires to 50psi. Do notice a slight difference in how it tows.
Jay
mjayjensen is offline   Reply With Quote
Old 12-13-2015, 02:23 PM   #4
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I change tires every three years no matter what. Our Bambi gets 22k a year on it.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 12-14-2015, 12:55 PM   #5
cbrittan's Avatar
2020 22' Caravel
Woodstock ON , Ontario
We have been running since new 10,000+ miles on dealer installed Michelin "235/75 15" EXTRA LOAD" tires (the word MICHELIN is white on these tires) which according to Michelin's website, can carry an elephant at 13,000 pounds. We inflate to no more than 50lbs cold. These tires show a sidewall obviously thicker than the Michelin tires on our GMC pickup. They are visibly different in shape at the sidewall.
Since we are discussing confidence in Michelin tires, we agree. We have a high degree of confidence in these tires, and while our dealer joked about "not needing to carry a spare", we do anyway just so we know where it is.
Properly balanced, wheel nuts torqued before every trip, we don't think about tires any more!
cbrittan is offline   Reply With Quote
Old 12-14-2015, 01:10 PM   #6
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
After 7 years new GYMs would probably ride better too.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 12-14-2015, 01:42 PM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I honestly can't tell a difference in the way my trailer tows with the new LT tires, but I have extreme comfort and peace of mind.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-14-2015, 03:12 PM   #8
2000 30' Excella
2014 30' Classic
Princeton , Iowa
No you feel it, but so will your trailer. Shake the "s???" out of it. For one I think real trailer tires are best.
larryglarson is offline   Reply With Quote
Old 12-14-2015, 04:18 PM   #9
Antiquepedaler
Laramie , Wyoming
Images: 11
One thing I should add is this. So far I have pulled the trailer with the new Michelins three 300 days. At the end of each day I have reset the lug nuts torque. After the tried day there was only one nut out of specs.
Antique Pedaler
2021 Caravel 20 FB
Old 12-14-2015, 05:36 PM   #10
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
You went from seven year old POS tires to brand new higher-quality tires, I would hope you'd notice an improvement!
Bob Martel
WBCCI# 5766
Old 12-14-2015, 07:40 PM   #11
2005 19' Safari
GLENDALE , AZ
Re: Our Airstream's tire history
2005 19' Bambi (4,500 lbs, single axle):
  • Two of three original GYMs failed (ST225/75x15D) -- Tire age = 3 years, approx 7,500 miles, tire pressure = 65 psi.
  • One of two Maxxis replacement tires failed (ST225/75x15E) -- Tire age = 2 years, approx 5,000 miles, tire pressure = 80 psi.
  • Two Michelin XPS Ribs (LT225/75x16E) have had absolutely no problems -- Tire age = 5 years (and still running), approx 35,000 miles (to date), tire pressure = 80 psi. For safety, these two XPS Ribs will probably be replaced at age 6-7 years with 60-75,000 miles on them, and over half of the tread still remaining. (At 35,000 miles, the tread shows almost no visible wear.)
Detailed tire history for our Bambi: http://www.airforums.com/forums/f438...ml#post1503775
Old 12-14-2015, 07:57 PM   #12
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Have you weighed your bambi to know how much load your tires are actually carrying?
SSquared is offline   Reply With Quote
Old 12-14-2015, 09:29 PM   #13
2005 19' Safari
GLENDALE , AZ
Total weight on our Bambi's axle was 4,280 lbs, fully loaded, weighed while on an 8-month, 13,000 mile roadtrip. Sorry, I didn't weigh each wheel individually.
For those unfamiliar with the XPS Rib, it has a 1-ply steel sidewall, 3 steel radial belts, weighs 49 pounds, and is rated to carry 2,680 lbs @ 80 psi. Our two tires were made in Germany.
Old 12-14-2015, 10:43 PM   #14
2019 25' Flying Cloud
Sequim , Washington
Do the 15" rims with LT tires fit in the wheel well of a 23' FC?
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 12-15-2015, 08:05 AM   #15
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I had to buy 16" wheels as Michelin did not have the tire that I wanted in 15 inches......worth the expense but I loved the moon wheel covers I had for them.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 12-15-2015, 02:44 PM   #16
SSquared's Avatar
Longmont , Colorado
Thanks for the update. That really shows how the single-axle trailers put a big load on the tires. My dual axle 25FB was at 5960 pounds on the axles last time I weighed it.
Filaments of the imagination! Excella CM Lights - Interior & Exterior 0 05-17-2007 11:58 AM
I could use some help.... RVNUTTY 1970-79 Tradewind 5 12-21-2004 12:53 PM
Truck bed covers? Could use some help! maxandgeorgia Off Topic Forum 17 05-26-2004 10:45 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
