Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 03-06-2007, 01:27 PM   #15
CaravelBrian
Profile:  1965 17' Caravel
Auburn , California
I keep a combo jump start/air compressor/light in my truck all the time. 12 volt and recharges. I bought it at Sam's club for 45 bucks. Use it all the time and have used it to run the trailer lights in storage when my battery was dead.
CaravelBrian is offline   Reply With Quote
Old 03-06-2007, 01:42 PM   #16
Foureagles
Full-timer
Profile:  1971 27' Overlander
above Shavano (pop. 0) , Colorado
A good (about three times the cost of cheap ones) 12v air compressor is nowhere near the "top", though a 110v model might be climbing on up there. An example of things approaching the top might be my plan to convert the A/C on my old Jeep to a compressor capable of running air tools, and adding a second alternator with diodes suitably bypassed to serve as an emergency booger welder.
"Don't confuse symmetry with balance". Tom Robbins
Foureagles is offline   Reply With Quote
Old 03-06-2007, 04:38 PM   #17
Safari64
Safari64's Avatar
Profile:  1964 22' Safari
Eagle River , Alaska
If you really want a project, and don't want to carry excess equipment…
Simple Jeep mod: Did this on my Jeep and truck.
We air down tires for off roading to 10-12PSI. At end of the trail you need to air up.
I mounted a York upright auto A/C compressor with electric clutch on my Jeep motor. Belt runs right off fan pulley. Piped the air intake into the engine air filter. Output goes to a big truck brake air tank w/ high pressure cutout mounted tucked up along the frame member, then to a quick disconnect air hose fitting on rear bumper.
Start engine, Plug in air hose, flip dashboard switch and Voila…..all the compressed air you could want. Fill tires, run air tools, pressurize water tanks. The only thing to carry is the air hose.
Cost in parts (all used except air lines) about $75. Knowing it’s there to rely on (and I have)….priceless.
Safari64
Safari64 is offline   Reply With Quote
Old 03-06-2007, 04:42 PM   #18
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Gen Juel and i found compressed air cartrages at lowes last night. they hook to a regulator you can air up tires or use a nailgun if you want .thought it was pretty neat. Juel 'Bob
juel is offline   Reply With Quote
Old 03-06-2007, 11:31 PM   #19
cammur
cammur's Avatar
Profile:  2005 25' Safari
Roseville , California
Rodney,
I bought the Husky 2air talks about (I probably got it as a result of his post) and it works fine around the garage but is more than I would want to carry.
This last weekend I noticed at Harbor Freight a 12V (battery clamp) compressor nice and compact but sturdy for about $60 Harbor Freight Tools then I saw a similar cleaner looking model with the same promises in Costco for about the same price. I'd be interested in what anyone has to say that has tried either the Harbor Freight or the Costco model.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 03-07-2007, 12:07 AM   #20
2airishuman
2airishuman's Avatar
Profile:
with 10 tires on the road and the genset handy, i use husky often...
also carry a 12 volt and i've used it on the road when i didn't want to get out the generator. it is soooooooooooo slow.
craftsman now has a 112 volt compressor that is 2/3 the size of the husky.
so it's is easier to carry and store. works well too...
might be the next one to try...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 03-07-2007, 03:08 PM   #21
cammur
cammur's Avatar
Originally Posted by cammur
...I noticed at Harbor Freight a 12V (battery clamp) compressor nice and compact but sturdy for about $60 Harbor Freight Tools then I saw a similar cleaner looking model with the same promises in Costco for about the same price. I'd be interested in what anyone has to say that has tried either the Harbor Freight or the Costco model.
I screwed up the Harbor Freight link. Try:
Harbor Freight Tools - Quality Tools at the Lowest Prices
This is a Costco link but I'm not sure this was the exact one in the store:
Costco Cyclone High Volume Portable Air Compressor
Cam
2005 25' Safari SS
AIR #8752
Roseville, CA
Top 20 Contributors, Top 10 Forums/Threads & New Stats Info.... Andy R Our Community 7 04-01-2008 10:19 PM
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 10:26 PM
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 2 10-16-2002 09:39 PM
On top of Mt. Kiamichi Pahaska On The Road... 4 09-09-2002 12:42 PM
carry a pod on top?? pebblepoint Roof 1 06-28-2002 10:05 PM
