02-02-2019, 02:23 PM
#21
Washington
, Missouri
You'll love the gye's. I do and have 15-20k or so on them. New this time last year. For me it was a hard decision as i was heading for the nokians. Lots around eugene,main!y on horse and utility trailers. In the end went with the gye's last minute decision as i was POSITIVE they would fit in the spare rack and the nok's were slightly larger dia. I also thought the meatier looking nok's would be better...the gye's looked a bit weanie tread wise. But i now understand that that tread design (gye) runs cooler.
So know the nokians are just another option with pretty much the the same rating spec.
02-02-2019, 02:48 PM
#22
2006 19' Safari SE
Tucson
GoodYear Endurance here, as well...have tried many tire brands through time, and these have been the best....we are very pleased with them...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
02-02-2019, 06:10 PM
#23
2014 27' FB International
Clearwater
I am a 4 year replacer. The new endurance tires have been great. Continue with the lable tire pressures. Tire max pressures have increases.
02-03-2019, 08:00 AM
#24
1973 25' Tradewind
Reno
, Nevada
I thought Nokians were winter tires. Which tire are people using?
Phil N Lisa
Reno NV
1973 25' Tradewind
2007 GMC 2500 HD SLE Classic Crew Cab Duramax
02-03-2019, 08:21 AM
#25
Wichita Falls
, TX
Most motor home users advise replacing tires every 5 years no matter what. I plan on doing the same with my AS.
02-04-2019, 07:30 AM
#26
Washington
, Missouri
Phil, i'll follow up with the spec when I'm on the laptop
B
02-04-2019, 11:12 AM
#27
2004 30' Classic Slideout
Fenton
, Missouri
I will finishing my 6th year on my Michelin 16" LT's this July. I seriously am considering replacement this coming year. I'm trying to contemplate what tire to replace them with. Rebates on the Michelin's got them to $140 each when I bought them. Tires are much more expensive now. One side of me says go Michelin again, but the frugal side asks the questions as to whether it has to be a Michelin. I'll just have to do the shopping and see.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
02-04-2019, 11:29 AM
#28
2002 30' Classic S/O
Garden Valley
, Idaho
Go to Tire Rack, I got my Michelins cheaper than anywhere else. Arrived in 2 days and I got a $70 Visa card.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
02-04-2019, 04:21 PM
#29
Washington
, Missouri
Now made in TN. I had that impression but re winter orientation, but after researching things think they are a great all around tire, simply breaking into the US market and shaking a Scandinavian reputation. I like them as they are an LT and not an ST tire, but in the end and for my TT weight, the ST was also a fine fit...keeping it generally under 65. Know your tire load and go from there. Again these are 235 and the fit may have been a bit tight in the tire hange...that in light of a last minute install decision I decided to go with the GYE, which I new fit. If I had been ahead of schedule I'd be running Nok's right now. But to be clear, IMO this is splitting hairs, and I would be satisfied with either...assuming the noks fit as described.
http://www.airforums.com/forums/f438...15-156339.html
http://www.airforums.com/forums/f438...3s-120650.html
B
02-04-2019, 05:20 PM
#30
Garden Valley
, Idaho
For those looking at LT tires, specifically Michelin Defender MS/2 , look at the Tire Rack. I found them to be the best price, free shipping and got a $70 cash card to boot. I got my tires in 2 days. I used them once before and highly recommend Tire Rack.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
02-04-2019, 06:44 PM
#31
Washington
, Missouri
I have the mich defs ms2 on the TV as they were available in a LT spec when I swapped out the 10's ( Michelin Defender LTX M/S, 245/55R19 103H (1929 lbs) for the Michelin Defender LTX M/S, 245/65R17 107T SL (2149 lbs). Love them!
However the Mich Defs were not available in an LT when replacing the GYM’s which is why everyone was swapping their 15” rims for 16” rims to go with an LT tire (my spec LTX 225/75R16 115/112R. I have a Bambi and expect that others with a dual axel and a different load per tire need may be able to find the mich Def in an LT in their size.
http://www.airforums.com/forums/f438...es-148274.html
there are numerous other threads that address swapping rim size to get a better load rating with a mich LT tire. However with the presence of Nokians and now GYE's the need to buy new rims to accommodate the larger (lt) rated tire seems to me to have subsided. I simply didn't see a reason to buy larger rims
02-04-2019, 07:31 PM
#32
Garden Valley
, Idaho
However, there are other 15" LT's in other brands, but not E rated, that's why many went to 16" wheels.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
02-04-2019, 09:39 PM
#33
Sag Harbor
, New York
Originally Posted by aliner
. . .The DOT on them is Nov. 2014. I'm planning a 5000 mile trip in March and would like some input on weather I should change them out or go one more season. The tires look great but going on year 5. Any thoughts would be appreciated.
If you choose not to replace them now, and end up having a blowout which causes some damage [or worse], will you kick yourself for not spending the money to minimize your risks?
Personally I would replace them ASAP.
Why tempt fate?
Peter
PS -- In the "big picture" scheme of things, new tires are a very small part of your overall investment, including tow vehicle, annual expenses like insurance, maintenance etc., and so forth.
02-04-2019, 09:56 PM
#34
Garden Valley
, Idaho
Why tempt fate?
Peter
Tires are the key to safety for your AS and your TV. Tires are the most important part of your whole setup.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
02-04-2019, 11:28 PM
#35
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
If you want the best internet, delivered price available on Endurance tires use SimpleTire.com.
I have purchased four full sets of tires (for both trailer and our vehicles) over the years with great satisfaction.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
02-05-2019, 11:36 AM
#36
2017 27' Flying Cloud
London
, Ontario
Based on this thread, I am going to replace the tires on our 2017 27' FB FC. We have put only 10k miles on them and only two seasons, but we are going on a long trip to Florida in March and starting in snow locally. I thought about maybe trying to get another summer out of them, but then I found myself thinking of our security and the chances of a blow-out. I came down on saying "why take the risk for the relatively small amount of money to have peace of mind".
Thanks to everyone for posting with their experiences.
27FB 2017 Flying Cloud
F-150 Lariat
Ham Radio Callsign - VA3PGJ
02-06-2019, 10:59 AM
#37
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Don't forget to also get a TPMS; that will help your "peace of mind" with your new tires!
02-06-2019, 05:36 PM
#38
Washington
, Missouri
Pappy19...totally agree. I needed the E's but suspect that some duals may not.
To also agree with others...tires are cheap, especially if you only need 3...i also replaced the spare.
B
QUOTE=pappy19;2206888]However, there are other 15" LT's in other brands, but not E rated, that's why many went to 16" wheels.[/QUOTE]
02-06-2019, 07:43 PM
#39
2013 27' FB International
2012 23' Flying Cloud
GVA
, British Columbia
Tires to be replaced
I have a 2013 -27 FB ( 6yr.old in May) with about 20k + miles on and they are going to be replaced next month. Going with Goodyear Endurance tires 15 inch
I have not had an issue with my OEM tires. Feeling very fortunate about that.
Up here in good old Canada they will be installed for $1020 taxes included Canadian Funds.
Laurence
02-10-2019, 10:01 AM
#40
2017 25' Flying Cloud
west plains
, Missouri
Over 100,000 miles in Alaska, Canada, many NPs and trails, Newfoundland and boondocking...never any tire trouble of any kind. Michelins, but even more important EARLY REPLACEMENT and always check the manufacture date EVEN IF THEY ARE “NEW”.
