Old 02-02-2019, 09:54 AM   #15
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
You should get Michelin LT tires in E rated. After having very bad experiences with GYM, I invested in 16" wheels and Michelin Defender tires.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 02-02-2019, 09:59 AM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Another vote for GYE's...ASAP
We have been on GY's since new...one nail, one curb rash 'failure' oop's.🥴
Swapped out last Spring...well pleased!
Instead of going to íStarbucksÖI make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 02-02-2019, 10:08 AM   #17
1994 30' Excella
Rutherfordton , North Carolina
Recently the repair manager at an Airstream facility told us never go by how the tires look and never go five years. Better to spend the money and feel safe than to have a blow out and risk damage to the trailer. It could easily happen especially if traveling some of the roadways of this country in serious need of repair. We had a negative experience in that vein last fall and trust me, it's traumatic. Good luck!
Sharon Rose is offline   Reply With Quote
Old 02-02-2019, 10:08 AM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by Dal Smilie View Post
A properly inflated 3 year old Marathon, blew on our very light 1949 Curtis Wright Clipper. No weather crazing, lots of tread, reasonable speed. Tore up belly pan, blew off closet door, tore up plumbing.
I donít use them any more. And change any trailer tire by 4 years. No matter tread or miles
This could have been from a road hazard. Which no tiree is immune from. And the older more worn a tire the more suspetable to road hazard damage.
>>>>>>>>Action
Old 02-02-2019, 10:17 AM   #19
2014 25' Flying Cloud
Temple , Texas
When in doubt - change them out. I made "one last trip" on our GYM's last spring before a planed tire change and paid the price. One GYM separated which was bad but we were lucky as the second tire on that side was also noted to be separating when it came off of our unit.
I put on GYE's and the FC spent a month in the shop, after $2,200 of body work we were back on the road.
Another way to describe this problem is "turn around don't drown" or in your case replace and don't repair.
2014 Flying Cloud 25FB
2016 Ram 1500
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 02-02-2019, 11:20 AM   #20
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Agree with consensus...you don't want a blowout with the GYM's (or any tire)! I chose to stay with 15" wheels and went with the new GY Endurance last summer with only 10K on my original GYM's. No issues but pay close attention to the PSI recommendation on the GYE chart for your AS weight. The installers filled my tires to 70PSI...way too much air and caused loose rivets and door hinge issues inside. Get your AS weighed at the scales and adjust tire pressure according to the chart. For me, ~50 PSI is in the range and recommended...no more issues inside. Also, recommend getting a TPMS set up to help you monitor should something happen. So far I am very happy with GY Endurance tires.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 02-02-2019, 02:23 PM   #21
CruizinDux's Avatar
Tracktown USA , Oregon
You'll love the gye's. I do and have 15-20k or so on them. New this time last year. For me it was a hard decision as i was heading for the nokians. Lots around eugene,main!y on horse and utility trailers. In the end went with the gye's last minute decision as i was POSITIVE they would fit in the spare rack and the nok's were slightly larger dia. I also thought the meatier looking nok's would be better...the gye's looked a bit weanie tread wise. But i now understand that that tread design (gye) runs cooler.
So know the nokians are just another option with pretty much the the same rating spec.
CruizinDux is offline   Reply With Quote
Old 02-02-2019, 02:48 PM   #22
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
GoodYear Endurance here, as well...have tried many tire brands through time, and these have been the best....we are very pleased with them...
TB & Greg and Abbey Schnauzer
#3954
Old 02-02-2019, 06:10 PM   #23
2014 27' FB International
Clearwater , Florida
I am a 4 year replacer. The new endurance tires have been great. Continue with the lable tire pressures. Tire max pressures have increases.
ChuckFeldt is offline   Reply With Quote
Old 02-03-2019, 08:00 AM   #24
1973 25' Tradewind
Reno , Nevada
I thought Nokians were winter tires. Which tire are people using?
Phil N Lisa
Reno NV
1973 25' Tradewind
2007 GMC 2500 HD SLE Classic Crew Cab Duramax
DiHrdBowTi is offline   Reply With Quote
Old 02-03-2019, 08:21 AM   #25
Wichita Falls , TX
Most motor home users advise replacing tires every 5 years no matter what. I plan on doing the same with my AS.
ga adkins is offline   Reply With Quote
Old 02-04-2019, 07:30 AM   #26
CruizinDux's Avatar
Phil, i'll follow up with the spec when I'm on the laptop
B
Old 02-04-2019, 11:12 AM   #27
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I will finishing my 6th year on my Michelin 16" LT's this July. I seriously am considering replacement this coming year. I'm trying to contemplate what tire to replace them with. Rebates on the Michelin's got them to $140 each when I bought them. Tires are much more expensive now. One side of me says go Michelin again, but the frugal side asks the questions as to whether it has to be a Michelin. I'll just have to do the shopping and see.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-04-2019, 11:29 AM   #28
pappy19's Avatar
Go to Tire Rack, I got my Michelins cheaper than anywhere else. Arrived in 2 days and I got a $70 Visa card.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
Time to buy a new toilet..... Jared129 Sinks, Showers & Toilets 6 03-16-2013 09:48 AM
New time streamer, long time dreamer Wilburstream Member Introductions 25 01-12-2009 08:32 PM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
A time to buy, a time to sell jeffyockey@m Member Introductions 2 03-12-2008 10:39 PM
