Old 05-08-2004, 06:32 AM   #1
Is a ST225/75R tire the same as a 7.00-15?
I have 7.00-15LT tires, Load "C" tires on my 68 Globetrotter. Should I replace with load "D" rated tires? Also I am reading that LT tires are not the best way to go. The tires on the coach are in excellent condition but am concerned about their weight carrying capacities.
Love not to spend the $ but, certainly will to keep it safe. If I need to replace, will the ST225/75R fit properly? Thank you
Bryan/Dallas, Texas
Bryanhu is offline   Reply With Quote
Old 05-08-2004, 06:40 AM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
A small factor..
Bryan/Dallas, Texas
Bryan,
Based upon my experiences...You should use radial only with the wheels designed for radials. If you were to try and keep the original steel wheels, the radial would not be a good choice. Slippage is an issue from what I understand. Somewhere on here is a thread on that topic of going from different load rating as well..
Back to your basic question concerning the ST225/75R..
IMHO,
I see no reason why that size couldn't do the job for you..Certainly better than "LT" which are not really recommended for trailer use~
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-08-2004, 06:42 AM   #3
Airstream 1975!'s Avatar
Baghdad , Iraq
Send a message via MSN to Airstream 1975!
I would go with the ST tires. They designed for trailers. Stiffer sidewall I guess. Use the LT tires for your tow vehicle if you can.Rob
Airstream 1975! is offline   Reply With Quote
Old 05-08-2004, 07:29 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The ST225/75R15C tire would be what you would want, unless you want to replace the wheels, too. There is a thread that discusses a catastrophic wheel seperation problem when going to load range D tires after having load range C tires on the wheels.
The ST225/75R15 is roughly the same size as the 7.00/15 tire, within a quarter of an inch or less.
Also, the ST stands for Special Trailer, they are built a little differently, as well as having a little more UV resistant compuonds so they don't weather check as quickly as standard tires.
As far as using the radial tires on rims that were not designed for radials, I have not had a problem, but there is always a first time for everything.
Old 05-08-2004, 08:46 AM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Also in that thread they talk about split rims, something you do not want to put D rated radials on. Check out the thread and Inland RV's comments/pictures on rim seperation and you will see what we mean.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-08-2004, 04:36 PM   #6
Rim width?
Do I have to be concerned with my original rim width when shopping for tires. I will opt for the BIAS PLY ST tire Load Range C. Are the original wheels non-standard? Thanks everyone!
Bryan
Old 05-08-2004, 07:25 PM   #7
Well Preserved
1993 21' Sovereign
Bryan
As long as your rims are OEM (original equipment) for your trailer, and they came with the 7.00/15's, you should be fine.
Old 05-08-2004, 07:40 PM   #8
Thanks Terry. I bet they are original. They have the original baby moon hub caps. Appreciate your reply.
Bryan
anyone: 10-ply "E" 7-15 Del-Net tire??? jmeredith Tires 13 07-09-2009 06:31 PM
Tire pressures Silvertwinkie Tires 28 09-10-2004 11:00 AM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
