Old 04-11-2011, 11:23 AM   #15
1976 28' Argosy 28
Pinellas Park , Florida
The 7 year replacement recommendation comes from the DOT, not the tire manufacturers. Unfortunately, unlike Twinkies, tires do not have an unlimited shelf life. The moment the tire pops out of the mold, the tread compound starts to deteriorate. A tire sitting even in a dark, air-conditioned warehouse for 7 years is not safe to be mounted on a wheel. It has lost enough of its flexibility to be usefull only as a boat bumper or a tire swing.
Patrick Cody is offline   Reply With Quote
Old 04-11-2011, 11:39 AM   #16
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
My tires are approaching the time based replacement recommendation. I confess to some reluctance to do so, mainly because of the stories I have read about new tires failing. I want to have some confidence that new tires wouldn't paradoxically put me at greater risk of tire failure. To bad we do not have available data for tire failure. It would be awful to replace all the rubber because of fear of blow outs only to precipitate one by replacing tires that might have been OK to start with.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-11-2011, 12:23 PM   #17
Wise Elder
Jammer's Avatar
2010 30' Classic
Do you have a link or source for this recommendation?
Old 04-11-2011, 01:12 PM   #18
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Originally Posted by GCinSC2 View Post
tsupler,
As you work thru this question, please review the plethora of GYM threads, both good and bad GYM reviews.......... GYM's are now all gone.
Good luck.
Gary
What's a GYM?
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 04-11-2011, 01:51 PM   #19
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've replaced tires every 5 years for the past 30 years of trailering. In that course of time I've had one tire failure. That being a Marathon that threw a chunck of tread after it's 4th season of service. Luckily the tire held together and I didn't experience the deflation until I was backing the trailer into my driveway after a trip home from Branson. The pivot was enough to break the exposed belts from the missing tread area.
As noted by others the cost of repairing the damage caused by the steel belts shreading your wheel wells and surrounding aluminum sking is much greater than the cost of the tires along with the dangers and inconvenience of being on the side of a road with a bad tire.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-12-2011, 05:44 PM   #20
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by Michigander View Post
What's a GYM?
Michigander,
Rereading my post, I didn't do too well on this one.
GYM = GoodYear Marathon.
My statement about GYM's all gone refers to the GYM's (2 sets) that used to be on my trailer.
Sorry for the confusion.
Good luck.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 04-12-2011, 08:01 PM   #21
2005 19' Safari
Wausau , Wisconsin
What about the GYM? Is there anything better for a 2005 19' Safari?
Al Dinger is offline   Reply With Quote
Old 04-12-2011, 08:48 PM   #22
HCR
HCR's Avatar
Livingston , Full time traveler
my trailer is an 'o6 and I had no idea how the tires had been used, but inspection of the man. date revealed '05, so I just replaced all five tires with GYMs.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 04-13-2011, 06:45 PM   #23
AZ-JH's Avatar
Peoria , Arizona
If the trailer is garage kept when not in use, does that make a difference on when to replace tires? We've already replaced all of ours after a blowout last December (right at about five years), but just wondering for next time.
Janet & Leon
2007.5 Dodge 2500 5.9L Cummins 16+ mpg towing
4CU
AZ-JH is offline   Reply With Quote
Old 04-15-2011, 02:49 AM   #24
2005 19' Safari
GLENDALE , AZ
Our local Discount Tire and Costco both recently recommended 6 years max on tires (if I recall correctly), based on Michelin's recommendation (I don't think they honor warranty claims after 6 years).
Old 04-15-2011, 02:31 PM   #25
Air Mobile
2005 25' International CCD
Newport News , Virginia
Thanks for all the feedback
Again, thanks everyone for the very cogent feedback. I just got back from the tire store and put ST225/75R-15 Maxxix M8008 load rated E on all 5 wheels. Ended paying $128/tire, which included install, though I paid a bit extra to have all 5 tires balanced and dispose of the old tires. Happy to have it done locally and seemed to run a bit smoother on the way home... This board is great and I look forward to running into some of you all at Airstream events down the road. All the best.
Tim
Tim_S is offline   Reply With Quote
Old 04-15-2011, 05:55 PM   #26
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Originally Posted by tsupler View Post
I took all four tires to 60PSI before we pulled out of the driveway.
tsupler.... You noted that you filled your tires to 60PSI. The recommended pressure for the Goodyear ST225/75 R15 is 65 PSI. The ST225/75 R15 is rated for 2,540 lb load at 65 PSI. At 60 PSI the tire's load rating drops 160 lbs to 2,380 lbs. By dropping the pressure 5 PSI you have reduced the load capacity by 6.3% and reduced the total load capacity of four tires by 640 lb. I don't think the 5 PSI difference was the reason for your problem but you should keep in mind the reduction in load capacity by not running at the rated pressure. A copy of Goodyear's Tire Inflation Document is attached.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Hard To Replace Sony In '06 Bambi? jambie Audio, Video & TV 19 08-24-2012 12:18 PM
To replace the pump or not? MTsafari Water Heaters, Filters & Pumps 8 04-04-2011 07:20 AM
Time for another Maxbrake Jammer Brakes & Brake Controllers 0 03-30-2011 02:01 PM
Good Time to Buy Appliances? EricJohansen Dollars & Cents 0 02-27-2011 02:57 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
