Old 07-10-2014, 01:02 PM   #1
1999 28' Excella
New Orleans , Louisiana
Inside tire wear on back axle
Both tires on back axle are wearing on the inside. Axles were good to go in January 2014 and tires seem to have enough tread. 4000 miles later need to replace these tires.
Any ideas..guess first one is it is the axle?
badkat is offline   Reply With Quote
Old 07-10-2014, 01:23 PM   #2
richw46's Avatar
Lexington , Kentucky
Sounds like wheel alignment to me. Have you taken it in for a wheel alignment? That's where I would start.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 07-10-2014, 01:47 PM   #3
1999 28' Excella
Getting 2 new tires in Salida, CO. No alignment place here..headed to Colorado Springs to get that done. Hoping that is what these guys will see it as the problem and not a bad axle.
Old 07-10-2014, 01:53 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have a straight edge like a 4 ft florescent light bulb lay it across the center of the hubs on the rear axle with the bulb extending forward across the front axle. The bulb should touch the tire just as it does the rear tire. If you see a gap, or if the bulb is lifted off the front edge of the rear tire, you have a bent axle.
Airstream axles have to be bent to aline the tires. If you need an alinement look or a truck axle shop as they are the only ones that will have the equipment to do the job. Do not take the trailer to Jackson Center unless you just like to waste money.
Gaumer's in Chambersberg Pa. is the shop I use.
2004 Excursion 4x4
Old 07-11-2014, 08:47 AM   #5
1999 28' Excella
Getting new back tires then taking it to MyTopTechAuto in CO Springs for alignment for $219..if they cannot do it they charge $25 per axle to say no can do. We are full-timers presently in CO.
Old 07-11-2014, 11:36 AM   #6
2017 25' International
Joliet , Illinois
Why?
bel73 is offline   Reply With Quote
Old 07-11-2014, 11:43 AM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
If inside wear on both tires left and right, my guess is bent or overloaded axle deflecting. I'm not a trailer expert and I didn't stay at a Holiday Inn Express last night but if it were alignment I'd think there would be inside wear on one side and outside wear on the other.
An alignment shop would be able to tell you, however, if camber was out of whack on the rear axle, which, I believe, is not adjustable and indicative of a bent axle.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-11-2014, 01:15 PM   #8
1981 31' Excella II
New Market , Alabama
You sure this is a recent problem. It sounds sorta like it was never aligned properly the first place. The axle is a square tube with the rubber inserts. Once the control arms are inserted in the axle tube, I believe the axle tube is then bent with a hydraulic bending machine to get the proper camber and heal and toe. If they forgot to bend the axle at the factory you would have wear on the inside edges. You could also rotate tires to prolong tire life till you get it fixed. One my my axles looks like a noodle but it tracks straight and true with no tire wear.
Perry
Old 07-11-2014, 01:23 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Loose/worn wheel bearings CAN cause wear on the inside edge.
I could also envision a trailer that rides quite a bit higher in the front than at the back could cause some deflection that might cause inside wear on the rear axle.
Old 07-11-2014, 03:15 PM   #10
1981 31' Excella II
That is a possibility. If he jacks up the trailer and wiggles the wheel he will find out if it is the bearings or not. If the axle rubber has completely deteriorated it would also cause the inside edge wear.
Perry
Old 07-11-2014, 04:11 PM   #11
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Was there a previous owner of the trailer? Has one axle been replaced before (or after) you've owned it? The front axle may have failed some time ago and replaced and now the rear axle is going bad, or the rear axle may have been replaced improperly. It would be strange for 2 wheel bearing assembles to fail at the same time and produce the same tire wear unless both were done at the same time and not done properly. Whatever service has been done on the wheels and axles in the past may give you a clue to solve the underlying problem.
You can detect abnormal tire wear with a tire tread depth gauge—around $10 at an aftermarket auto parts store. You can tell if the tire is wearing improperly with the gauge before you can easily see it with your eye.
A wheel bearing that isn't tight enough should wobble and not give a consistent wear pattern. I'd still check it first since that's easy to do. Jack up the wheel and hold the tire on each side and see what movement there is. The wheel should have a little play in it. It is counterintuitive that a wheel should be slightly loose, but it works that way. Too much either way (too tight or too loose) and the bearings will fail, maybe before the tires show abnormal wear.
From experience, I know you can drive thousands of miles on bearings that are too loose before they overheat and start coming apart (I'm not the one who adjusted it; the ones I've done have never failed). Eventually the wheel will come off. By that time the axle and brake drum may be damaged. Fixing it was a challenge deep in the northern Minnesota woods, but it got done temporarily. Eventually a new brake drum and bearings were necessary.
One other thing to check. Airstream wheels are supposed to have a 0˚ offset. That means, as I understand it, the center of the wheel is over the center of the axle spindle. The spindle is the end of the axle and what the drum fits on. If the read wheels are not 0˚ offset, the stresses on the wheel are not correct and I suppose the tire could ride at a slight angle in reference to the spindle. The offset degrees should be on the inside of the wheel.
Gene
Gene
Old 07-11-2014, 05:24 PM   #12
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
I had the same thing happen on mine. New axles 4 years ago. Tires new 5 years ago. Went to do brake service and discovered rear axle tires worn on the inside. I consulted with a local trailer shop about alignment and was advised that this is common on torsion axle trailers that are not run very equal on both axles when rolling. Running the nose a little high and not rotating tires I believe was the culprit. Time will tell.
WineStream is offline   Reply With Quote
Old 07-11-2014, 05:35 PM   #13
Master of Universe
Gene's Avatar
Jason, good information. It is easy to not bother rotating tires because they all usually wear the same, but I want to get full use of the spare by rotating it with the other tires. But I can see how having the trailer not level will shift more weight to one axle, but why would this wear on one side of the tire instead of wearing the entire tires more than the on the other axle? Does too much weight cause them to go out of alignment? Does this damage the axle or will it spring back once the trailer is leveled?
Gene
Gene
Old 07-11-2014, 05:42 PM   #14
WineStream's Avatar
2005 30' Safari
Images: 24
I won't dare profess to be a pro on this. I found the odd wearing and immediately thought alignment. I measured and as best I could and found 1/8" difference between the two sides of my rear axle. I called the local shop and tried to make an appointment. He asked how my trailer sat going down the road. I divulged that it sat a bit nose high due to needing a lower shank. He advised that I level it properly, put on new tires, and leave it for a while and observe the tires.
Uneven tire wear..Yikes!! daydreamer36535 Tires 18 07-09-2007 10:17 AM
Tire Wear on Tow Vehicle grannyred Tow Vehicles 5 02-08-2006 02:34 PM
Outrigger wear to tire contact Johndigbydog Tires 10 01-20-2006 10:03 PM
Dramatically different tire wear Nicksut Tires 5 10-21-2005 12:41 PM
Un-even tire wear Deputych Tires 5 05-15-2003 12:23 PM
