03-03-2013, 04:14 PM
2010 25' FB Flying Cloud
Fall City
Informed decision or, not re 15 vs 16 tires
I have been following all the dialogue I could regarding the subject of Airstream trailer tires.
I am convinced; (1) you cannot depend on Goodyear Marathons - seems too many people have experienced failures which may be disastrous. (2) even if you have marathons and have had no problems you are courting fate (3) the 16" sendel/michelin route is apparently a good cure even if the tire industry will not openly endorse it. (4)I have had a marathon failure on a previous brand of RV.
Having said all that I am however still not convinced that for my 2010 25' Flying Cloud with 7300 GVRW that the 15" Michelin LTX M/S2 isn't a sufficient fix using oem wheels.
How many folks have gone with the 15" Michelins, for how many miles and has it not worked out for any of you?
I discovered that my 2010 trailer has US manufactured Marathons built in March of 2009 thus are in their last year of life for me. I've towed it 16,000 miles, watch my pressure closely and try to take care of them but I would rather have a better tire.
I believe in the five year rule.
Been very interesting following all the posts to this subject.
Lou
03-03-2013, 04:55 PM
2021 25' Globetrotter
Jamestown
, Rhode Island
I know this flys in the face of "Internet lore" but there is nothing wrong with current production Marathon tires.
I understand that Goodyear had their issues with this line when they began production overseas but the issue has been corrected. The service department of the largest Airstream dealer in this country says that they have zero issues these days.
My Marathons have 8000 miles on them today and I am keeping them!
Bruce
03-03-2013, 06:42 PM
1978 28' Ambassador
Kenton
, Ohio
I put 15" Michelin's on my 1978 28 footer. Didn't see the need to spend more on wheels and I like my stock wheels. No problems. The axles (new) are rated at 3500 lbs I believe so with each tire rated over 2000 lbs I feel I am fine with 15" tires.
Tom
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
03-03-2013, 07:25 PM
2012 25' Flying Cloud
Battle Lake
As you are buying tires anyway and your plan is to keep the trailer for a long time, the Sendel/16" Michelin combo is a pretty small price to pay for assurance you have the most reliable setup, and something more likely to be readily available when you need replacement.
doug k
03-03-2013, 08:08 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
I had less than 500 miles on our new 25fb after bringing it home from the dealership. I switched to 15" Michelins after reading the negative press on the Marathons. It was only three weeks since the trailer was parked and I checked and the Marathons were down over 5psi.
Made three trips to the tire store to get all five tires switched putting the spare on each side as a safety while going to the tire store with two tires at a time. They are about 0.3" taller than the Marathons they replaced. The 16" Michelin tire is another 0.3" taller than the 15" Michelin and that extra height could be problematic for some installations.
After three months of storage, the Michelins were still the same pressure.
03-03-2013, 08:51 PM
Fall City
15 vs 16
When I originally posted this I neglected to say that while I have 16,000 mi on my marathons without a problem they do lose air pressure. During our towing year, which this year had no winter shut down to speak of, I add air at l east once monthly.
thanks for the input so far.
Lou
03-04-2013, 03:33 AM
2005 28' Safari
saline
, Michigan
If you do a little research on this forum you will find many good choices of 15" tires suitable for your needs. Of the several hundred Airstreams using 15" Michelins, I have yet to read of a failure. I have over 8000 miles on mine and I have had to adjust the air pressure only due to ambiant temperature changes.
03-04-2013, 04:24 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
You're going to find two rabid camps on this subject. Think that the deciding factor for you might be economics. I did dump my brand new 15" wheels/tires for 16" wheels/tires after reading every single post on AirForums. After 4,000 miles on my rig, I am very satisfied with the change. Could I have been fine with the original set-up? Probably. But, for me the major issue was safety and load/speed rating. NOT that I drive over 65, but I can (and have had to a couple of times). I do think there are enough questions on the overall quality rating of the GYM's to be unsettling.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
03-04-2013, 05:03 PM
Wise Elder
2010 30' Classic
South of the river
Lou
Your money, your trailer.
Just out of curiosity, do you spend that kind of money on other safety maintenance items -- brake controller, brake maintenance, hitch, etc.
03-05-2013, 02:35 PM
1996 28' Excella
Portland
, Oregon
This Goodyear Marathon ST (GYM) tire thing is an amazing study in modern sociology and also skewed statistics.
Do all Airstreams come with GYM ST tires?
You have to step back and think about how these forums work. I've seen it dozens of times on all sorts of forums. If 100% of all airstreams come with GYM tires a certain percent are going to fail. Let's imagine for a moment that number is the same for all tire manufacturers. But our sample here is probably 99% on GYM tires.
So, if you have a blowout, you're going to say something about it here. And if you never have a blowout, you're probably never going to visit the "tires" section.
I'm pretty sure if Airstreams all came with Maxxis M8008 ST tires, you'd hear the same "horror" stories over and over. Because most people don't say anything about them if they just sit on the trailer and go roundy round.
I'm also willing to guess that those who switch to a 16" LT tire have had a blowout. And they are naturally better equipped now on how to maintain and prevent a blowout. Sun, loading, storage, tow speeds, etc. So because of that experience, they naturally will have a lower future blowout rate than the inexperienced.
I just have a little skepticism with people claiming that a certain tire, that Airstream continues to put on our trailers, is a ticking time bomb.
If you enter "goodyear marathon blowout" in the search function here, guess what? you're going to find a whole list of horror stories about blowouts with GYM tires.
The OP is asking for "Informed Decision" and I read that as a request for "empirical data". Unfortunately, you're going to have to go outside an AS forum to find a good sampling of all tires compared. Not just all Airstreams with original equipment GYM tires.
-Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
03-05-2013, 03:21 PM
Alamo Heights
Outofcontrol: Your point is well-taken that anecdote != data (just distilling it down to its essence there.) However, a search outside AIRForums yields lots of sites with posts about GYM failures. Still not a controlled study, of course, but it takes it farther afield than the "Airstream site and Airstream uses GYM except for the Eddie Bauer" selection bias.
Then I searched for Maxxis M8008 failure and most of the entries I found were on the order of "My GYMs blew and I need a new tire, what does everyone think about the Maxxis M8008" and "Has anyone heard of the Maxxis M8008 failing like GYMs do?" Again, there are uncontrolled variables, such as the number of each type of tire in the field, the types of trailers those tires are installed on, etc. etc.
I wouldn't throw away brand new GYMs if they came on a trailer I bought... I have friends with lots of miles on GYMs and the only failure was a cut from something in the road, I don't believe they're evil demon tires, but given better alternatives I'll choose the alternatives just in case.
— David
03-05-2013, 03:26 PM
2005 25' International CCD
Lilburn
, Georgia
I agree with both sides of this issue. If you go with the 15" Michelin option you will have some trouble getting tire dealers to sell them and install them as they aren't rated for trailers. BUT, if you are one that travels at high speeds regularly, I really believe the GYM ST (or any ST) tire is not right for you. We went with the GYM as we don't put thousands of miles on ours (short weekend trips every couple of weeks), and we don't ever go more than 60 mph.
03-06-2013, 02:13 AM
hang up and drive
2010 30' Classic
Carlisle
, Pennsylvania
For the benefit of any who choose or need to notice, especially for the poster above not wanting to change wheels, another 15" tire with reasonable weight ratings (and a smaller hit on the wallet) is available. These tires are designed for heavier vehicles (vans). I have a set on my flatbed trailer after having a GYM blow out. I went to 16" Michelins from Jackson Center on my Airstream pre-blow out. No issues 10k miles later.
Continental*Vanco 2
Kyle
2023 Ford F350 Lariat 7.3/4.30 FX4 CCLB
2010 Classic Limited 30
ProPride P3-1400
03-06-2013, 02:53 AM
2005 19' Safari
GLENDALE
, AZ
Do your own research, then decide for yourself.
Goodyear Marathon
5 star: (0)
4 star: (0)
3 star: (0)
2 star: (0)
1 star: (0)
Note: Ratings removed from Tirerack.com's site at some time in the past due to very poor reviews.
Sample review: "Blew out 3 of 5 Goodyear Marathon trailer tires on my fifth-wheel enroute from Auburn, AL to Pensacola, FL Memorial Day weekend. These tires were properly inflated and cared for & less than 4 years old. Goodyear Marathons are DANGEROUS and should be taken off the market. Chinese made junk = DO NOT BUY!!"
More reviews: Goodyear Marathon Radial Trailer Utility Tire Reviews. Buying Guides & Consumer Product Reviews - Epinions.com
Michelin LTX M/S
5 star: (1539)
4 star: (467)
3 star: (84)
2 star: (16)
1 star: (4)
Sample review: "I'm not normally a fan of the Michelin value equation (expensive vs others with same or better performance) but the LTX is truly one of the most impressive tires I've ever owned - and I've bought a ton of different tires. Wear and all around performance (including snow and light off road use) have been simply outstanding...At 32,000 miles still have 7.5/32nds of tread and have worn perfectly even ... Worth the high price in this case as there seems to be little to no down side, even as they age."
Michelin LTX M/S2
5 star: (429)
4 star: (55)
3 star: (10)
2 star: (3)
1 star: (0)
Sample reviews:
"I cannot say enough good about these tires. If I were to buy a new truck today, I would replace whatever tires came on it with this tire before it ever left the dealership."
"After 43,000 mostly highway miles, these tires look almost new - at least 60%+ tread remains. I am a very discerning consumer and these tires are the best that I've ever purchased ... I highly recommend these tires. They are worth the price!"
Michelin XPS Rib
5 star: (21)
4 star: (4)
3 star: (1)
2 star: (0)
1 star: (0)
Sample reviews:
"Third set of XPS Rib, and still very pleased with the cost per mile. The XPS has to be the mileage champion, and toughest tire for commercial use. Mileage on truck is 757,000 miles. I have never had a flat, or any problems with the XPS. They are the energizer bunny of tires. 200,000 miles is very attainable, and managed 234,000 on one set. The XPS is not M/S rated, but can get thru light snow on a 4X4. Great stability when towing, and very even tire wear."
"These tires are used on a triple axle fifth wheel that weighs approx 17500 lbs. Don't have many miles yet but they show no wear at all. We stayed in one location for 6 mos and when we went to leave checked the tire pressure. Pressure dropped only 1 lb in each tire. Past tires would drop up to 10 lbs. You just can't go wrong with Michelin on any application!!"
03-06-2013, 05:02 AM
2000 30' Excella
Toledo
, Ohio
Bruce
I bought a GYM last July from the largest Goodyear dealer here in Toledo Ohio it has a 2012 date code on it and made in China they didn't know that was where they are made I bought it for a spare just before a trip . Les wbcci14183
03-06-2013, 05:48 AM
2008 31' Classic
Lake Charles
, Louisiana
I went to the Michelin tires after I had a GYM failure which caused a lot of skin damage. I stayed with the 15 inch only because we are making short trips and I did not have time to go with the 16 inch. I have a more comfort feeling with the Michelin's even though they are near the rated capacity but will not feel like I have done all I can until I put on the 16 inch wheels and Michelin tires. I say if you are in doubt do the 16 inch if you have the time and money and plan to do some serious pulling. Just my 2 cents.
03-06-2013, 06:05 AM
Jamestown
, Rhode Island
Phoenix,
What you are not allowing for is the fact that these reviews reflect upon an issue we all know happened. No one is denying that. Not even Goodyear! The question is (or should be) what date range and how many tires were affected? I am sure that there are Marathons out there from the "bad period" that are just fine. I am also sure that with current production this issue is now history.
Once again, the service manager for the largest Airstream dealership in the country says that he would put them on his own trailer. He can put on anything, he recommends that you stay with the Marathons! They sell lots of tires and He has to answer to customers if something goes wrong!
That is a statistical slice that none of us can match with our personal
knowledge, internet reviews or no.
Frankly if you want Michelins buy them, they are an excellent tire company and build a wonderful product. I really do not understand the difference in ST and LT ratings and hesitate to listen to any explanation I find on the Internet! I would happily listen to an engineer who's job is to design tires, explain the difference, but until then it is a mystery to me thus something to be wary of.
The other reason I am so dogmatic in my defense of the Marathons is that I install tires on autos as a part of my business. I see a lot! I see failures and I see success. I hear excuses, I hear praise and I hear complaints. I have seen great no-name tires I have seen brand new faulty Michelins, a tire I consider one of the best. I have seen enough to be cautious of what I read online.
My beloved trailer has Marathons and they are staying there.
Bruce
03-06-2013, 06:12 AM
Jamestown
, Rhode Island
Les,
Apparently, Goodyear began having problems with the Marathon when production first switched to China sometime 5 or 6 years ago. My understanding is that they then switched back to US production of the tire for a period of time while they investigated the cause of the failing tires coming from China. Once the problem was identified and corrected tire production was returned to China again. This is where they are all made now.
Bruce
03-06-2013, 07:01 AM
2008 30' Classic S/O
Dearborn
, Michigan
Lou
You can put me firmly in the 'marathon ST are crap' camp.
That said, there's only (2) reasons I wouldn't move up to 16" (as long as there was a comfortable margin on load cap):
- changes your trailer pitch, ever so slightly. Depending on your hitch equip, that may be an issue.
- I've noticed slightly increased vibration from the 16" 'E' load Michelins, over the 15" 'D' load Goodyear-- in the form of backed out nuts/screws, open drawers. I plan on installing centramatics to deal with that.
I never said Airstreaming was cheap... but it's a way better value than the alternative.
03-06-2013, 10:10 AM
Vintage Kin
Fort Worth
One can also find GY dealers who won't install any ST tire on a trailer, as I have. ST tires are a new thing. Years back LT tires were the only choice. In speculation by at least one tire engineer it would appear that ST tires are a way of providing yet more economic life from otherwise obsolete/worn-out tire-making machinery/molds.
ST tires may be fine for a flat-deck trailer used to haul construction materials six times yearly. But that's an entirely different proposition from a $60k travel trailer, IMO. The risk of loss-of-use is magnitudes different. And one can look at the repair bills provided by boondockdad of the damage done by an ST tire blowout (over $7k, IIRC).
