Old 09-10-2016, 09:31 AM   #1
PSU1981
PSU1981's Avatar
2015 27' Flying Cloud
Spring , Texas
Inflation PSI - Michelin LT225/75R16/E LTX M/S2
I know the max inflation for this tire is 80 psi & with this it has a max load of 2,680 lbs.
AS owners that have this tire -- what P are you running at & why?
We are in Texas where it can get quite hot in the summer --- do you recommend a different ambient temp inflation in summer vs. winter?
We have a 2015 27FB FC that I am upgrading the 15" GYM's to this tire.
Glenn
PSU1981 is offline   Reply With Quote
Old 09-10-2016, 09:50 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have had two 25FB's, a 2005 and a 2015, over the last ten years. Both were upgraded to the 16" Michelin LT's. We have run these tires at 72 psi with excellent results.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 09-10-2016, 09:50 AM   #3
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
I generally go with 60psi cold but I don't have the weight maxed out. Higher psi i.e. 70 psi seem to have a harder ride as evidenced by the movement of cushions etc. while travelling. Airstream states 80 psi but that is way too high for me.
TRIPPPIN is online now   Reply With Quote
Old 09-10-2016, 05:58 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I run mine at 70. Seems like a fine compromise for my 25'....
wulfraat is offline   Reply With Quote
Old 09-10-2016, 06:17 PM   #5
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
On OEM 16" equipped trailers, inflation pressure is 80.
For 16" retrofitted trailers, inflation pressure is 70 for load range D replacements, and 55 for load range C replacements.
Old 09-10-2016, 06:39 PM   #6
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Michelin publishes (as most tire manufactures due) a tire pressure chart giving suggested tire pressure depending on weight carried.
Mine came with my tires - I use 50 lbs. with 15" rims per Michelin.
Silver Hawk is offline   Reply With Quote
Old 09-11-2016, 09:20 AM   #7
CapriRacer
CapriRacer's Avatar
I'm in the , US
Not exactly. The charts are the MINIMUM inflation pressure to carry the load - and it is always a good idea to use more.
- and if you are doing a trailer, you need to account for front to rear and side to side variation. The best way to do this is to actually weigh each position.
CapriRacer is offline   Reply With Quote
Old 09-11-2016, 12:24 PM   #8
80Ram's Avatar
2017 25' Flying Cloud
Scott City , Missouri
Vinnie of Vinnies Notth Bay Repair who specializes in AS recommend 65lb. on the Mitchelin 22575r16E tires.
80Ram is offline   Reply With Quote
Old 09-11-2016, 12:32 PM   #9
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
I start at 62 and warm up to 70.
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Old 09-11-2016, 12:40 PM   #10
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
We historically have run ours at 60 cold. Just last week I reduced it to 50 on a recommendation from Andrew Thompson at Can-Am. I went looking for his advise as we were getting more rivet shearing than normal and thought it might be the tire pressure. He felt that with our 28' trailer and a ready to camp weight of about 6500 - 6700 lbs, we were running the tires with a bit more pressure than needed.
I haven't run the trailer since but we will be heading out in the next couple weeks for an extended trip and will have a chance to see if it makes a difference.
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 09-11-2016, 12:51 PM   #11
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . my Pendleton with 16" & Michelin pkg came from dealer at 65 psi. . .seems to work for me. . .regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 09-11-2016, 12:56 PM   #12
2013 27' FB Eddie Bauer
Salado , Texas
Glenn
My answer is based on two valve failures in about a day on the 16" OEM tires and wheels on the Eddie Bauer. At the second failure at 11:00PM on a Saturday night, now with no spare, we, very fortunately, exited the Interstate right at a 24/7 tire repair business. We were served by a very grizzled and seasoned man who said he had been repairing tires for 40 years. After replacing the cracked synthetic value stem with a metal one he had previously salvaged, he asked us what pressure we had been using. I told him 70 pounds, and he replied, "If you want to avoid cracking the stems, use the full 80 pounds." He commented that he has replaced a lot of trailer and light truck valve stems from Michelin, and all were running at pressures below the sidewall recommendation.
When I asked about the vibration and ride issues on the very uneven roads in the area, he looked at me like I was mentally deficient and simply said, "Slow down." He went on to say that in his decades of dealing with tire issues, the underinflation to smooth the ride was one of the prime things he had noticed, only exceeded by worn-out tires.
Loden is offline   Reply With Quote
Old 09-11-2016, 12:57 PM   #13
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
I upgraded to the same tires last October. I went with 80 psi on my 2015 FB Serenity. After my first trip I opened my door to find the controls to my stove top laying on the floor. I am convinced that it was a result of an extremely rough ride. My dealer felt otherwise and said it was a problem AS had identified with the controls themselves. Although the control panel has been identified as a problem, I really felt that 80 was too high. Last week I was watching one of the new LOLOHO videos and Vinnie of Vinnie's North Bay recommended 65psi for these tires(as 80RAM states above). I am going to try 70 in a couple of weeks.
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 09-11-2016, 01:06 PM   #14
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
The dealer recommended 80. Ran that way for a year. Through this forum I learned that the shake/rattle/roll effects we were seeing after a day on the road may have been partly from the firmness of the tires. Now run at 70 and I'm happier with that. Tire wear on the 16" LT MS/2 is excellent and I see no difference at the lower pressure.
GammaDog is offline   Reply With Quote
Old 09-11-2016, 01:18 PM   #15
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
Tire Pressure
That's what I run in mine.
jimfa440 is offline   Reply With Quote
Old 09-11-2016, 01:31 PM   #16
Penokee , Kansas
Same tires on our 72 Overlander. I run 35 psi cold year round.. The tires just show a little radial bulge and ride nice and stable..and smooth..
One has to remember back when radials first made the streets, everyone felt they were flat..
Would much better like using that pint extra of gas per tank full then rattle my A$ apart..
Sodbust1 is offline   Reply With Quote
Old 09-11-2016, 02:10 PM   #17
interstateflyer's Avatar
2017 25' International
Los Osos , California
Tire dealers always seem to want to inflate tires to their sidewall max pressure, apparently wanting to avoid liability in the event of an accident where tire inflation is questioned.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-11-2016, 04:39 PM   #18
dames7's Avatar
GILBERT , Arizona
65lb is our number, a lot depends on what the roads your traveling on. Out here the interstate HWY on so bad in spot you just lose it sometime, at 65lb we don't have anything moving around inside.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 09-11-2016, 04:41 PM   #19
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
Since I got my 16" wheels from Vinnie for the Mitchelins, I go with Vinnie's recommendation of 65 pounds cold. The tires can handle it and the ride for the AS is sooooo much more smooth.
2001 Excella 30' (Beauty)
2014 Ram 2500 Diesel 4x4 (The Beast)
http://www.LivingInBeauty.net
JBBeaubeaux is offline   Reply With Quote
Old 09-11-2016, 07:21 PM   #20
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
Loden,
I like what that experienced tire repair person said. Keep those LT and P tires at sidewall max. Then go slow so you don't shake the trailer. Just wonder if you have to go slower than one would with ST tires!
TheCabin is offline   Reply With Quote
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 10:08 PM
4 Michelin LT225/75R16 Tires and Chrome Wheels warfieju Airstream Classifieds 1 02-24-2016 08:38 PM
Bridgestone BLIZZAK LT225/75R16 tires WheelnStones Tires 10 02-07-2016 09:02 AM
Michelin 15" LTX M/S2 cold inflation pressure Jmacd Tires 2 01-29-2016 12:27 PM
Michelin LTX M/S2 - Inflation Preferences BoldAdventure Tires 50 12-04-2015 06:23 PM
