09-13-2016, 06:15 AM
#41
CapriRacer
I'm in the
, US
And don't forget side to side and front to rear weight variation. The tires on a trailer do not carry the same amount of load.
06-02-2018, 08:03 PM
#42
Rich and Kat
Alexandria
Alexandria
, Virginia
I love this site! I just went to michelintruck.com and then navigated to Reference and then Load & Inflation Tables
My 16” LT225/75R16’s were right there ... confirmed that I’m good with running 65 lbs cold, which heat to ~70 lbs. Perfect. I set my TPMS to alarm at 60 (LOW) and 85 (HIGH). Perfect.
This is also a good time to point out that we are supposed to check our lug-nut torque before each trip ... according to my manual, is 110 ft-lbs (aluminum) or 100 ft-lbs (steel) rims. I haven’t been good about doing this as often as I should.
Good luck...
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF Save
06-03-2018, 07:19 AM
#43
CapriRacer
I'm in the
, US
Originally Posted by AIRHEDS
...… My 16” LT225/75R16’s were right there ... confirmed that I’m good with running 65 lbs cold, which heat to ~70 lbs. Perfect. I set my TPMS to alarm at 60 (LOW) and 85 (HIGH). Perfect. …..
Rule of thumb says that you should avoid getting more than a 15% pressure buildup. That indicates the tire is running too hot. At 65 psi cold, 15% = 75 psi.
CapriRacer
Want to learn about tires? Please visit my website: Barry's Tire Tech New content every month!
06-03-2018, 09:52 AM
#44
Rich and Kat
Alexandria
Alexandria
, Virginia
Thank you sir
Rich
KB2ZMF Save
06-03-2018, 05:22 PM
#45
2013 30' Classic
Kent
We tried to order these tires today and was told they are discontinued. How do I found out what replaced them?
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
06-03-2018, 06:05 PM
#46
Rich and Kat
Alexandria
Alexandria
, Virginia
I just navigated to michelintruck.com,
Then to Tires and Retreads
Then to Tires
Then to Size
— scrolled all the way to the bottom and third from bottom:
Highlighted the LT225/75R16
Then click “Search”
Only one tire comes up: the “XPS RIB” ...
Once it comes up, click “Details”
I have no idea if this is the new tire or not, but it sure looks like it’s the only alternative... I then viewed the specs and they appear to be the same as my LT225/75R16. Compare the specs and let me know if you determine otherwise.
Also, I checked the news/press releases and didn’t see anything in there either. Let us know what you discover.
Regards,
Rich
KB2ZMF Save
06-03-2018, 06:22 PM
#47
Rich and Kat
Alexandria
Alexandria
, Virginia
ALCOA Wheels
I did find one other post on the Michelin site that warrants sharing (it was under “Manuals, Bulletins and Warranties”)
https://www.michelinb2b.com/wps/b2bc...eel_Family.pdf
MICHELIN® TECHNICAL BULLETIN
May 21, 2015
This Technical Bulletin is being issued following the Alcoa Wheel Notification #2015-053, dated 05/21/2015, which is attached.
Can someone tell me which wheels are on the 2017 Classic? Thanks, Rich
Rich
KB2ZMF Save
06-03-2018, 06:25 PM
#48
2002 25' Safari
Dewey
Good luck...
Same tires and numbers I use on my 25.
Richard
06-04-2018, 06:06 AM
#49
CapriRacer
I'm in the
, US
I just navigated to michelintruck.com, …...
There's your problem right there. Try Michelinman.com and you will find Defender LTX's in an LT225/75R16. The XPS is a commercial tire used mostly by fleets who are more concerned about cost per mile than anything else. (The XPS's can be retreaded!)
CapriRacer
06-04-2018, 03:16 PM
#50
Rich and Kat
Alexandria
Alexandria
, Virginia
Thanks again CapriRacer. Can you advise on time2play’s question about phase-out and replacement? Thanks, Rich
Rich
KB2ZMF Save
07-23-2018, 04:10 PM
#51
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
I’ve searched that site over and can’t find a chart for defenders, only ribs. Michelin online help says rib is the only chart they have???
07-24-2018, 04:00 AM
#52
CapriRacer
I'm in the
, US
It doesn't matter the make of the tire, the load chart is the same. I don't know why they specifically call out the XPS on their chart, but if you go to - say - Goodyear (page 44) and look for the LT225/75R16 chart, it's the same! You can look for other brands of tires as well - same answer.
Note: Another Michelin quirk - they did it by axle, so the values are doubled for singles and quadrupled for duals!
Short version: Tires are standardized
Long version: http://barrystiretech.com/loadtables.html
CapriRacer
07-24-2018, 11:52 AM
#53
Senior Member
Sparks
, Nevada
Thanks!
