Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 09-13-2016, 06:15 AM   #41
CapriRacer
CapriRacer's Avatar
I'm in the , US
And don't forget side to side and front to rear weight variation. The tires on a trailer do not carry the same amount of load.
CapriRacer is offline   Reply With Quote
Old 06-02-2018, 08:03 PM   #42
Rich and Kat
AIRHEDS's Avatar
Alexandria Alexandria , Virginia
I love this site! I just went to michelintruck.com and then navigated to Reference and then Load & Inflation Tables
My 16” LT225/75R16’s were right there ... confirmed that I’m good with running 65 lbs cold, which heat to ~70 lbs. Perfect. I set my TPMS to alarm at 60 (LOW) and 85 (HIGH). Perfect.
This is also a good time to point out that we are supposed to check our lug-nut torque before each trip ... according to my manual, is 110 ft-lbs (aluminum) or 100 ft-lbs (steel) rims. I haven’t been good about doing this as often as I should.
Good luck...
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF
Save
AIRHEDS is offline   Reply With Quote
Old 06-03-2018, 07:19 AM   #43
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by AIRHEDS View Post
...… My 16” LT225/75R16’s were right there ... confirmed that I’m good with running 65 lbs cold, which heat to ~70 lbs. Perfect. I set my TPMS to alarm at 60 (LOW) and 85 (HIGH). Perfect. …..
Rule of thumb says that you should avoid getting more than a 15% pressure buildup. That indicates the tire is running too hot. At 65 psi cold, 15% = 75 psi.
CapriRacer
Want to learn about tires? Please visit my website: Barry's Tire Tech New content every month!
Old 06-03-2018, 09:52 AM   #44
Rich and Kat
AIRHEDS's Avatar
Thank you sir
Rich
KB2ZMF
Save
Old 06-03-2018, 05:22 PM   #45
time2play's Avatar
2013 30' Classic
Kent , Washington
We tried to order these tires today and was told they are discontinued. How do I found out what replaced them?
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 06-03-2018, 06:05 PM   #46
Rich and Kat
AIRHEDS's Avatar
I just navigated to michelintruck.com,
Then to Tires and Retreads
Then to Tires
Then to Size
— scrolled all the way to the bottom and third from bottom:
Highlighted the LT225/75R16
Then click “Search”
Only one tire comes up: the “XPS RIB” ...
Once it comes up, click “Details”
I have no idea if this is the new tire or not, but it sure looks like it’s the only alternative... I then viewed the specs and they appear to be the same as my LT225/75R16. Compare the specs and let me know if you determine otherwise.
Also, I checked the news/press releases and didn’t see anything in there either. Let us know what you discover.
Regards,
Rich
KB2ZMF
Save
Old 06-03-2018, 06:22 PM   #47
Rich and Kat
AIRHEDS's Avatar
ALCOA Wheels
I did find one other post on the Michelin site that warrants sharing (it was under “Manuals, Bulletins and Warranties”)
https://www.michelinb2b.com/wps/b2bc...eel_Family.pdf
MICHELIN® TECHNICAL BULLETIN
May 21, 2015
This Technical Bulletin is being issued following the Alcoa Wheel Notification #2015-053, dated 05/21/2015, which is attached.
Can someone tell me which wheels are on the 2017 Classic? Thanks, Rich
Rich
KB2ZMF
Save
Old 06-03-2018, 06:25 PM   #48
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Good luck...
Same tires and numbers I use on my 25.
Richard
Old 06-04-2018, 06:06 AM   #49
CapriRacer
CapriRacer's Avatar
I'm in the , US
I just navigated to michelintruck.com, …...
There's your problem right there. Try Michelinman.com and you will find Defender LTX's in an LT225/75R16. The XPS is a commercial tire used mostly by fleets who are more concerned about cost per mile than anything else. (The XPS's can be retreaded!)
CapriRacer
Old 06-04-2018, 03:16 PM   #50
Rich and Kat
AIRHEDS's Avatar
Thanks again CapriRacer. Can you advise on time2play’s question about phase-out and replacement? Thanks, Rich
Rich
KB2ZMF
Save
Old 07-23-2018, 04:10 PM   #51
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
I’ve searched that site over and can’t find a chart for defenders, only ribs. Michelin online help says rib is the only chart they have???
sheriff1 is offline   Reply With Quote
Old 07-24-2018, 04:00 AM   #52
CapriRacer
CapriRacer's Avatar
I'm in the , US
It doesn't matter the make of the tire, the load chart is the same. I don't know why they specifically call out the XPS on their chart, but if you go to - say - Goodyear (page 44) and look for the LT225/75R16 chart, it's the same! You can look for other brands of tires as well - same answer.
Note: Another Michelin quirk - they did it by axle, so the values are doubled for singles and quadrupled for duals!
Short version: Tires are standardized
Long version: http://barrystiretech.com/loadtables.html
CapriRacer
Old 07-24-2018, 11:52 AM   #53
Senior Member
sheriff1's Avatar
Sparks , Nevada
Thanks!
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
4 Michelin LT225/75R16 Tires and Chrome Wheels warfieju Airstream Classifieds 1 02-24-2016 07:38 PM
Bridgestone BLIZZAK LT225/75R16 tires WheelnStones Tires 10 02-07-2016 08:02 AM
Michelin 15" LTX M/S2 cold inflation pressure Jmacd Tires 2 01-29-2016 11:27 AM
Michelin LTX M/S2 - Inflation Preferences BoldAdventure Tires 50 12-04-2015 05:23 PM
