Old 09-11-2016, 01:18 PM   #15
2000 30' Excella
Greeneville , Tennessee
Tire Pressure
Originally Posted by 80Ram View Post
Vinnie of Vinnies Notth Bay Repair who specializes in AS recommend 65lb. on the Mitchelin 22575r16E tires.
That's what I run in mine.
jimfa440 is offline   Reply With Quote
Old 09-11-2016, 01:31 PM   #16
Penokee , Kansas
Same tires on our 72 Overlander. I run 35 psi cold year round.. The tires just show a little radial bulge and ride nice and stable..and smooth..
One has to remember back when radials first made the streets, everyone felt they were flat..
Would much better like using that pint extra of gas per tank full then rattle my A$ apart..
Sodbust1 is offline   Reply With Quote
Old 09-11-2016, 02:10 PM   #17
interstateflyer's Avatar
2017 25' International
Los Osos , California
Tire dealers always seem to want to inflate tires to their sidewall max pressure, apparently wanting to avoid liability in the event of an accident where tire inflation is questioned.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-11-2016, 04:39 PM   #18
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
65lb is our number, a lot depends on what the roads your traveling on. Out here the interstate HWY on so bad in spot you just lose it sometime, at 65lb we don't have anything moving around inside.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 09-11-2016, 04:41 PM   #19
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
Since I got my 16" wheels from Vinnie for the Mitchelins, I go with Vinnie's recommendation of 65 pounds cold. The tires can handle it and the ride for the AS is sooooo much more smooth.
2001 Excella 30' (Beauty)
2014 Ram 2500 Diesel 4x4 (The Beast)
http://www.LivingInBeauty.net
JBBeaubeaux is offline   Reply With Quote
Old 09-11-2016, 07:21 PM   #20
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
Loden,
I like what that experienced tire repair person said. Keep those LT and P tires at sidewall max. Then go slow so you don't shake the trailer. Just wonder if you have to go slower than one would with ST tires!
TheCabin is offline   Reply With Quote
Old 09-11-2016, 08:09 PM   #21
Anna Maria , Florida
Originally Posted by PSU1981 View Post
I know the max inflation for this tire is 80 psi & with this it has a max load of 2,680 lbs.
AS owners that have this tire -- what P are you running at & why?
We are in Texas where it can get quite hot in the summer --- do you recommend a different ambient temp inflation in summer vs. winter?
We have a 2015 27FB FC that I am upgrading the 15" GYM's to this tire.
Glenn
My educated guess would be 80 PSI for E rated load 65 PSI for D rated load. The 27' trailer weight would fall in the D range.
At 80 PSI under a light load it will feel like riding on solid wheels.
franklyfrank is offline   Reply With Quote
Old 09-11-2016, 09:33 PM   #22
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
We looked at the Michelin load charts and chose 67 PSI cold for our 16" tires. It seems to work great - Rocinante tows like a dream, and when we reach our destination, the cushions, etc., are still where we left them. We also use Centramatics, which likely help with that.
Rocinante is our 2014 International Signature 27FB
Old 09-12-2016, 07:21 AM   #23
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
65 PSI per the placard on the side of the trailer.
Generally heat up to 70 PSI while traveling.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-12-2016, 08:22 AM   #24
Adventure.AS's Avatar
Port Dover , ON Canada
Why Not To Inflate to Maximum Sidewall Pressure
Aside from the argument that you only need maximum tire pressure when fully loaded to the tires weight limit, I don't understand why so many people inflate their tires, cold, to the maximum indicated sidewall pressure.
Won't you be overinflated when travelling - approximately 1psi per 10 °F increase as the air temperature increases during the day and the tire temperature increases due to the rotation? Excessive pressure may lead to impact-breaks, decrease braking performance, and cause uneven wear.
Name:	Variation of Tire Pressure with Temperature.jpg
Why not inflate to a lower cold pressure by calculating how much the pressure will increase during your travels to ensure that you aren't over inflated.
Personally, I have weighed my trailer axle and plan on a travelling pressure, taking into account the forecast air temperature and the increase in pressure, from rolling. I am familiar with the pressure increases from my TPMS readings and the ideal pressure is indicated for that weight on the GYM inflation table. There must be a similar table for Michelin tires.
Ray B.
WBCCI #6497
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 09-12-2016, 08:58 AM   #25
dznf0g's Avatar
Oswego , Illinois
Attachment 271551
There has been much written here by tire experts relative to your questions. Search on forum member CapriRacer...he is a tire engineer.
Personally, I have tried 70, 75 and 80psi with my Michelin LTX M/S tires and have found NO difference in ride quality as judged by loose rivets, things shaking or moving around. I run 80 psi always now for the last 2 seasons. I have a 30' Classic with 7500 - 8000 pounds on the axles.
(BTW- pressure rise during the day has no bearing on how much to set your tires at relative to cold pressure setting. The sidewall cold max pressure accounts for a normal 10% or so rise due to tire flexing....it will be somewhat more than 10% when accounting for ambient temperature rise during the day as well as sun loads. I typically see about 12% rise...and a bit more on the sunny side. This rise is pretty much the same at 70, 75 or 80psi in my particular case)
-Rich-
Old 09-12-2016, 09:01 AM   #26
Moses Lake , Washington
I own a auto service / tire shop in Moses Lake Wa. What you have are pickup tires. I would check with your local tire shop and get prices on ST radial trailer tires. Pickup tires and trailer tires are not the same. We will not install LT tires on any trailer per liability issues and customer safety.
RichS25 is offline   Reply With Quote
Old 09-12-2016, 09:04 AM   #27
dznf0g's Avatar
Oswego , Illinois
This has also been discussed at great length. Perhaps you aren't aware that AS (and maybe others), are supplying LT tires as standard and optional equipment on many models from the factory?
-Rich-
Old 09-12-2016, 10:39 AM   #28
Rivet Slave
Rocinante's Avatar
I'm with you, but it's his shop and he can do what he likes there.
I will also say that after the scary experience we had setting our previous GYM ST tires to 65 cold and then running them thru the Mojave, we would never do that again.
As others have noted above, we use the Michelin-provided load tables for the tire featured in this thread to determine our optimal cold pressure. We'll trust Michelin's load tables over any opinions presented here, thanks.
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 10:08 PM
4 Michelin LT225/75R16 Tires and Chrome Wheels warfieju Airstream Classifieds 1 02-24-2016 08:38 PM
Bridgestone BLIZZAK LT225/75R16 tires WheelnStones Tires 10 02-07-2016 09:02 AM
Michelin 15" LTX M/S2 cold inflation pressure Jmacd Tires 2 01-29-2016 12:27 PM
Michelin LTX M/S2 - Inflation Preferences BoldAdventure Tires 50 12-04-2015 06:23 PM
