05-21-2017, 05:05 PM
Ravenna
, Ohio
Important ST tire SPEED information
Special Trailer (“ST”) Tires
Trailer tires are widely used in a variety of towable trailer applications and are designed and marked as “ST” (Special Trailer) tires.
• Special Trailer tires, with the “ST” size designation, are speed rated at 65 MPH (105 km/h) under normal inflation and load conditions as shown in TRA table ST-M1. Prior to 2016 almost none of these tires had a Speed Symbol letter.
• This speed rating is based on Tire and Rim Association loads and inflation pressures for ST trailer tires without a Service Description for speeds up through 65 mph.
• If tires, with the ST designation and a Speed Symbol are used at speeds between 66 and 75 mph (106 km/h and 120 km/h), TRA directs the cold inflation pressure be increased by 10 psi (70 kPa) above the recommended pressure based on the trailer placard for normal inflation and load conditions.*
• If tires, with the ST designation, are used at speeds between 76 and 87 mph (122 km/h and 140 km/h), it is recommend the cold inflation pressure be increased by 10 psi (70 kPa) above the recommended pressure based on the trailer placard for normal inflation and load conditions and the load is to be decreased by 10%.*
You should also consult your trailer manufacturer’s Owner’s Manual for maximum operating speed recommendations for the trailer.
• No matter the inflation and load adjustments tires should never be operated at a speed higher than what is indicated by the speed symbol.
o Even if Inflation and Load adjustments have been made to a tire with a Speed Symbol, it is never appropriate to use an ST tire at a speed above 87 mph.
o Increasing the inflation pressure by 10 psi (70 kPa) does not provide any additional load carrying capacity.
o Do not exceed the maximum pressure for the wheel or the valve.
o If the maximum pressure for the wheel or valve prohibits the increase of inflation pressure, then the 65 mph rated speed must observed as the maximum speed.
o It may be necessary to dismount the tire from the wheel to determine the maximum rated inflation for the wheel and valve.*
o All the references to inflation here are about the "cold inflation pressure".
*Details about wheel and valve inspection:
a) If the rated (maximum allowable) inflation pressure is not visible on the wheel, consult the wheel or trailer manufacturer. Lacking documentation for a higher inflation the maximum allowable inflation pressure should be considered to be the maximum inflation on the OE tires.
b) Tubeless snap-in type valves, depending on the type valve, are rated for a maximum inflation pressure of 65 (TR413) or 80 (600HP) psi for nominal 0.453” diameter valve holes. If a higher cold inflation pressure is used, a clamp-in valve such as TR416S valve (200 psi maximum inflation) must be installed.
The above is a summary of my understanding and opinion as a tire engineer of steps that need to be taken for operating ST tires. Some will recognize that much of the above were covered in the Goodyear technical bulletin on ST tires
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
05-21-2017, 05:31 PM
2014 27' Flying Cloud
Rancho Cordova
Add 10 psi, ...check.
Keep it under 87mph...check.
Why don't they just write that on the side wall seems pretty simple.
05-21-2017, 07:37 PM
Ravenna
, Ohio
05-21-2017, 07:44 PM
Ravenna
, Ohio
Because you only need to add 10 psi if you will be traveling at 66 to 75 mph and the increased inflation does not increase load capacity.
Because some would miss, as you might have that if above 75 you ALSO need to decrease load.
Comments about max inflation for valves & wheels are safety related information and must be considered.
Not enough room on the tire sidewall
People can't seem to read and understand the tire "size" so IMO it is unlikely they would understand the above primarily because print size would be too small for some to read.
Also if you don't tow above 65 you do not have to make the above changes.
I have already read where some feel it is OK to run up to whatever speed in on the tire sidewall, even if it is above 87.
05-22-2017, 11:12 AM
Stowe
, Vermont
Question... I have read that GYM was developed years ago when most highway speeds were still posted at 55mph. The time has now come when GY has come to terms with the 21st century, and developed the GY Endurance. Reading the sidewall of these tires the change in information has changed significantly from the GYM. Have you checked these out?
05-22-2017, 11:14 AM
2012 30' Flying Cloud
San Antonio
Originally Posted by Tireman9
Thanks for this post Tireman9. I hope everyone reads until understanding. With E rated tires and in most cases, D rated tires the majority of our Airstreams can run the hiway at speeds in excess of 65 if trailer weight and tire air pressures follow the above guidelines. It's not that anyone should pump up the pressures and plan on driving 75 or even 85. But, if we use the above numbers as an extra edge for safety, we will be in good shape when and if we find ourselves in that higher speed range going down hills or the occasional passing.
05-22-2017, 12:28 PM
Sonoma Co.
The TRA recommendation comes across like consent or approval to exceed the posted speed limit. Nobody with any common sense should be towing their trailer at a steady speed of 65 or above, especially when pulling trailers that outweigh their tow vehicle. They are a danger to themselves and everyone else on the road, IMO. If common sense isn't enough, then perhaps a speeding tic of $100 for every MPH above the posted limit would get their attention.
05-22-2017, 12:38 PM
palm beach gardens
I'm in Montana right now, speed limit 80. My wife is driving 70. I have 16" Sendel wheels and Michelin LT tires. I'm playing on the forum and I'm a happy camper!
05-22-2017, 12:42 PM
Sag Harbor
, New York
Are there any special speed limits posted for trailers? I see some online sources saying 65 MPH is the Montana speed limit for trailers.
Happy Trails!
Peter
05-22-2017, 01:04 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Originally Posted by tireman9
important st tire speed information
special trailer (“st”) tires
trailer tires are widely used in a variety of towable trailer applications and are designed and marked as “st” (special trailer) tires.
• special trailer tires, with the “st” size designation, are speed rated at 65 mph (105 km/h) under normal inflation and load conditions as shown in tra table st-m1. Prior to 2016 almost none of these tires had a speed symbol letter.
• this speed rating is based on tire and rim association loads and inflation pressures for st trailer tires without a service description for speeds up through 65 mph.
• if tires, with the st designation and a speed symbol are used at speeds between 66 and 75 mph (106 km/h and 120 km/h), tra directs the cold inflation pressure be increased by 10 psi (70 kpa) above the recommended pressure based on the trailer placard for normal inflation and load conditions.*
• if tires, with the st designation, are used at speeds between 76 and 87 mph (122 km/h and 140 km/h), it is recommend the cold inflation pressure be increased by 10 psi (70 kpa) above the recommended pressure based on the trailer placard for normal inflation and load conditions and the load is to be decreased by 10%.*
you should also consult your trailer manufacturer’s owner’s manual for maximum operating speed recommendations for the trailer.
• no matter the inflation and load adjustments tires should never be operated at a speed higher than what is indicated by the speed symbol.
O even if inflation and load adjustments have been made to a tire with a speed symbol, it is never appropriate to use an st tire at a speed above 87 mph.
O increasing the inflation pressure by 10 psi (70 kpa) does not provide any additional load carrying capacity.
O do not exceed the maximum pressure for the wheel or the valve.
O if the maximum pressure for the wheel or valve prohibits the increase of inflation pressure, then the 65 mph rated speed must observed as the maximum speed.
O it may be necessary to dismount the tire from the wheel to determine the maximum rated inflation for the wheel and valve.*
o all the references to inflation here are about the "cold inflation pressure".
*details about wheel and valve inspection:
A) if the rated (maximum allowable) inflation pressure is not visible on the wheel, consult the wheel or trailer manufacturer. Lacking documentation for a higher inflation the maximum allowable inflation pressure should be considered to be the maximum inflation on the oe tires.
B) tubeless snap-in type valves, depending on the type valve, are rated for a maximum inflation pressure of 65 (tr413) or 80 (600hp) psi for nominal 0.453” diameter valve holes. If a higher cold inflation pressure is used, a clamp-in valve such as tr416s valve (200 psi maximum inflation) must be installed.
The above is a summary of my understanding and opinion as a tire engineer of steps that need to be taken for operating st tires. Some will recognize that much of the above were covered in the goodyear technical bulletin on st tires
excellant information: Thank you:d
05-22-2017, 01:26 PM
1967 26' Overlander
Spartanburg
, South Carolina
Thanks to all of you, especially Tireman....This is the most sensible thread I have seen on the subject of tires. I've run GYM's now for at least 15 years with no problems. I use the pressure/load chart on the GoodYear web site plus 10% and I never exceed 65mph. My average speed is 55. Like someone else said, there is no point in towing at a higher speed when common sense says a towed rig increases the chance of a mechanical failure and having twice the weight and more than twice the length makes avoidance of an accident more difficult should something go wrong.
05-22-2017, 01:39 PM
1999 25' Safari
Sparks
, Nevada
Thanks for Posting the update. Now if I can just keep from being rear ended doing 65 mph on Nevada 80 mph roads.
05-22-2017, 01:58 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
The new Goodyear Endurance ST tires carry a N speed rating.
05-22-2017, 02:28 PM
2003 31' Classic
Terra Alta
, West Virginia
So far really good for my Goodyear Endurance E rated 235-75x15 st's....2 months and 6500 miles. Try to do 65 or less but slip now and then. I think these will be fine but time will tell the story. These miles included terribly rough stretch of I 40 WB rt lane in Arizona.
Classic 31 and 07 Tundra
Dave in WV
05-22-2017, 04:26 PM
1990 29' Excella
Travelers Rest
, South Carolina
___________________________
My Maxxis 8008 225/75R E 15 BSW ST Radials are Speed Rated at R which is 106 mph. I can't imagine anyone using the tire for that speed with a trailer, but that is what the factory said. I have it in print as well as speaking at length with a factory rep to make sure I understood everything about the tire since I am on my second set of four. I run them at 75-80 psi with tire monitors and I routinely drive 65-70 mph. I've pulled trailers since summer of 1971 and have down through the years used old bias ply car tires, bia ply pickup tires, ST tires etc etc. and now the 8008 Maxxis. I pull with a 2500HD crewcab diesel that weighs more than my Excella. I visually check my tires every time we stop at a rest stop, and am satisfied with the tires and the safety of the speed we drive. If the speed is less than 70 we drive the speed limit, or less depending on circumstances. If the speed is more than 70 we still keep it at 65-70 as 65-70 is a zone I am comfortable towing at.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
05-22-2017, 05:01 PM
Ravenna
, Ohio
Glad things are working for you. Will be interested to hear if you get the same life from the ST tires on the TT as the LT tires on your P/U.
05-22-2017, 05:08 PM
Ravenna
, Ohio
No I have not read the sidewall of a GY M or of a GY E. I am basing my recommendations on a review of literature from GY and US TRA industry standards plus my 49 years experience as a tire design and quality engineer when I conducted thousands of failed tire cut tire autopsies to determine root cause for the failure not just observing the condition.
My reports were submitted for approval and acceptance to GM, BMW, Ford, Chrysler, Mazda, Fiat, Toyota, Honda, Subaru and DOT.
05-22-2017, 07:32 PM
2017 23' Flying Cloud
Parker
Tireman9,
I can't find your blogs on free wheel spin test and inspection, is it on the airforums, or in another blog spot?
Troutboy
05-23-2017, 07:22 AM
Ravenna
, Ohio
Originally Posted by Troutboy
Tireman9,
Sorry it's not here and I am not allowed to post or direct people to my blog per forum rules.
05-23-2017, 07:42 AM
2012 27' Flying Cloud
W
, New England
Are you allowed to send by private message of asked? If so, I'd welcome the link personally by PM if it doesn't violate the rules...
