04-16-2015, 10:05 AM
#101
Ravenna
, Ohio
Originally Posted by r carl
1. Many many people that went up a load range on ST tires had them fail for no reason.....
snip
Over my carreer I estimate I was involved in 20,000+ tire "autopsies" and for the last 10 years or so of my job my primary duty was failed tire inspection where I was the last person to get involved when others could not identify the Root Cause reason for a failure.
I had to issue written reports that were sent to engineers at GM, Ford, Chrysler, Honda, Toyota, BMW, Porsche etc so simply providing "customer satisfaction" and giving them a replacement tire was not an option. They wanted proof.
My inspections involved not just visual inspection but sometimes X-Ray, Holography, drum testing, chemistry and even Electron Microscope were tools involved.
I believe that in over 98% of the cases we were able to present physical evidence that supported the theory of why a given failure occurred so to me, "no reason" simply means that the person doing the inspection did not have the training or tools available to learn the real reason for a specific failure.
I am providing this information in an effort to demonstrate that failed tire analysis is not a simple task but takes decades of experience and access to numerous tools so a fact based conclusion can be reached.
I do not believe in Magic but in Science and physical evidence. The overwelming reason for tire failure is loss of proper inflation pressure with punctures, cuts, valve leaks and other forms of damage being the reason for the air loss.
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
04-17-2015, 04:24 PM
#102
Stoughton
, Wisconsin
I pulled the trigger on the Michelin 15" LTX today. I can't wait to test them out on the hwy.
04-17-2015, 04:30 PM
#103
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
I'm sure you'll love them.
Lance
04-17-2015, 10:42 PM
#104
z
, North Carolina
Indeed
That lil guy waving @ you on the side of the tire says it all. I gotta go shop on e-bay for a figurine of that guy. With as much $ as I have spent on them, and for as long as I have owned, and been buying them, they should be sending ME one!
Good looking tires mustang. You will truly be a happy camper. Congrats!
Sea ya down the road,
Gavin
04-30-2015, 12:27 PM
#105
2013 31' Classic
billings
, Montana
Want to see a set of tires do strange things? buy a set of tow masters
05-06-2015, 05:06 PM
#106
Ravenna
, Ohio
Originally Posted by 1965 mustang
I pulled the trigger on the Michelin 15" LTX today. I can't wait to test them out on the hwy. Attachment 236508
Don't forget that if these are "P" type you need to de-rate the load capacity by dividing by 1.1 as P type tires are not intended for trailer application.
05-06-2015, 05:33 PM
#107
2012 27' Flying Cloud
W
, New England
Congrats - but remember, these only work with the white letters facing out 😜
05-07-2015, 05:06 PM
#108
Stoughton
, Wisconsin
Attachment 237907
I'll turn the rims around, then they will be out!😏
05-07-2015, 05:12 PM
#109
Stoughton
, Wisconsin
All the math has been done. We have over 2,000 miles on this trip with no problems. We did see a 5er on the side of the road in SC with a shredded tire though.
05-07-2015, 10:33 PM
#110
1995 33' Land Yacht
Tempe
tires
Michelin tires are expensive but they are the best. I have used numerous brands. They have all worn out quickly. So Michelin. Oh, that is a $5,000 body repair. I have not had the body work done yet on mine 1995 because they told me $5000.00 and it is not as bad as your damage.
05-08-2015, 03:42 AM
#111
W
, New England
Now that's the way to do it! 😃
05-09-2015, 12:11 AM
#112
1992 29' Excella
Virginia Beach
, Virginia
FYI.
My AS body damage is fixed thanks to the fine workmanship at Out-Of-Doors Mart RV in NC. It's back home now and in the driveway awaiting my new tires and rims.
I've decided to switch to the Michelin Truck LTX M/S2 225/R75/16". Ordered the tires from Tirebuyer.com and Sendel T03 SM rims from Recstuff.com. Paid decent prices for both tires and rims and Michelin has a $70 rebate until May 10th.
The tires have already arrived. If all goes as planned the rims will be here Tuesday and I'll be getting them mounted and installed the middle to end of next week.
I want to especially thank Phoenix for all of his help and advice.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
05-17-2015, 07:46 PM
#113
1987 32' Excella
Nepean
, Ontario
abAs long as you're upgrading the rims & tires, consider adding Centramatics. They will dynamically balance your tire/rim/brakes/hub assembly. Absent proper balance, vibration can do all sorts of nasty stuff, such as loosen rivets, open drawers & cupboards.
Last summer I went whole hog - replaced and upgraded my axles, plus Sendel 16" rims and Michelin LTX225/75R16(E) tires (including the spare) & Centramatics. Have put on about 15,000 miles since - rides smoothly and tows like a dream.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
05-17-2015, 09:35 PM
#114
1992 29' Excella
Virginia Beach
, Virginia
I agree. Lucky for me, they were already on my AS when I bought it from the PO.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
05-18-2015, 07:10 AM
#115
1989 25' Excella
Albemarle
, North Carolina
Proper tire inflation for MAXXIS ST 225/75R15 Load Range E M8008 For Trailer use only on 25 Ft 1989 Excella Rear Twin (side bath.) Empty Black and water tanks Two propane tanks removed
05-18-2015, 04:14 PM
#116
1992 29' Excella
Virginia Beach
, Virginia
I meant to post these earlier. Here are a couple of pictures of the repair and the new rims and tires. I hadn't put my Tire Pressure Monitoring sensors back on the tires yet, in these pictures.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
05-19-2015, 11:35 AM
#117
2010 30' Flying Cloud
Mocksville
, North Carolina
Wow! Those look great on there. I am glad Out Of Doors mart was able to get everything repaired for you. We are on the fence about replacing our new 15" trailer tires with upgraded 16" gear. Every time I see these pictures of new wheels and tires I get the urge to upgrade.
05-23-2015, 08:21 AM
#118
1987 32' Excella
Nepean
, Ontario
Go for it! I did and the peace of mind knowing that you won't have ST-tire failure (with its associated costs) is worth every penny. Better towing, longer tire life and a lot safer with 16" LT-tires.
VE3JDZ
AIR 12148
WBCCI 8080
