Old 01-01-2016, 07:18 PM   #15
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by shineybullet View Post
Nothing is seized you just need to take the wheel and tire off first like overlander stated above , it's just common sense
>>>>"I'm trying to pull a tire for repair on my new-to-me 87 Excella. Having removed all the lug nuts, the tire won't budge." SNIP.....
S B....read the OP before offering blind observation. It's just common sense.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-02-2016, 06:13 AM   #16
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Use a large rubber mallet and hit the tire around the outer edge.If it does not release carefully hit the back of the tire out.If still no release lower the jack slowly putting weight on wheel and tire without lug nuts then raise trailer again.
Old 01-02-2016, 07:00 AM   #17
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I've had these wheels "stick" so badly, I've had to loosely install the lug nuts, put the trailer back on its wheels, and tow it around the yard, to break them loose. Just DON'T go out on the street that way.
Old 01-05-2016, 02:20 PM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
^^^^ That is a good technique. I have done this as well. Not in AZ when I lived in Michigan.
>>>>>>>>>>>>>Aciton
Bearing Buddy Bearing Protectors Ron A Wheels, Hubs & Bearings 23 05-19-2015 06:48 AM
Hub "cap" and bearing seal missing Landmammal Wheels, Hubs & Bearings 4 11-12-2011 06:54 PM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
Bearing Cap louie Brakes & Brake Controllers 5 06-12-2007 06:43 AM
1964 Bambi II bearing dust cap louie 1964 Bambi II 1 06-08-2007 11:18 PM
