Old 02-15-2016, 03:48 PM   #1
Barretta2's Avatar
2013 23' Flying Cloud
Naples , Florida
How to know when to buy new tires
I'm heading out late April/early May for a 6-week adventure: starting Naples, FL, up through New Hampshire, west across Wisconsin and continuing out to Idaho Falls, ID before doubling back and down to "Home" in the Colorado Rockies.
I took my 2012 23' FC to Midas a month ago and had the manager take a good look at my tires. No sign of rot, over 50% tread left. The tires are original and have fewer than 10 miles on them....probably closer to 8,000.
The safety and damage issues are preeminent of course, on such a long trip, but I'm also a woman traveling solo. I do have Good Sam travel assist, but still....
And the question: If you were me, would you replace these "good" tires now?
Barretta2 is offline   Reply With Quote
Old 02-15-2016, 04:41 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Hi, you post is timely as there are a few threads running about tire failure, especially Goodyear Marathon Tires (GMT).
In short you definitely need to replace those tires. From what I've been reading the GMT trouble begins around 8 to 10K mile mark. My AS is brand new & I'm replacing those tires with either Maxxis E rated ST tires or Michelin Defender 225/75R15 109t
tires coming out next month, I haven't decided which yet as I'm waiting for a few reports on the Michelins. If you replace stay away from GMT & Carlisle tires. If you were to decide on Michelin you need new rims also as your are 14" vs 15". Many forum members have gone that route on the 23' AS. Maxxis tires are the very best trailer tire on the market whereas Michelin are LTX meaning passenger (car, light truck) tires but are being used more & more on AS trailers.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 02-15-2016, 04:55 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The actual date code on the tire would be interesting to know. They are 4 or 5 years old probably and I would definitely replace them before the trip.
Old 02-15-2016, 05:08 PM   #4
2015 30' FB FC Bunk
Ayer , Massachusetts
If there's any doubt, change them out.
That's my motto. I lost a diver side rear on the TV last year in WI on I94 while on a long trip. It was nasty to say the least. Luckily we limped in to a tire dealer right of the next exit and got 4 new tires. At the time of the blowout, I fully expected a catastrophic wreck. We were really shook up.
Funny thing is, the tires came with the TV when I bought it used and my mechanic and a tire shop looked at the tires and said they would probably be fine because they look good.
Big mistake.
Ted S. is offline   Reply With Quote
Old 02-15-2016, 05:30 PM   #5
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Those tires are probably right on the edge of needing replacement. If you don't replace them this year, probably due next year. Check the date code, if they're over 5 years old they're due now.
The added piece of mind is probably worth it on a trip this long.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 02-15-2016, 06:08 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
The tires on my Safari look really good. No cracks, no bulges, wearing evenly, 75% of tread left, etc..... I plan on replacing them this spring before the summer travel season. My tires are in their 5th year beyond the manufactured date, so I'm replacing them due to age.
Your trailer model year (a 2012) could have been built in 2011. Your tires are older than your trailer (unless they have already been replaced), by as much as a year. At best the tires are 4+ years old, so they would be pushing 5 years at the end of your trip. They probably are already older.
I say replace those tires!
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 02-15-2016, 06:28 PM   #7
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
If I was in your shoes, I would replace those tires. Cheap insurance.
ďWhatís good for me may not be good for the weak minded.Ē
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 02-15-2016, 06:53 PM   #8
Mission , Texas
http://m.michelin.qa.publish.front-p...ist_tab_0.html
nrgtrakr is offline   Reply With Quote
Old 02-15-2016, 07:04 PM   #9
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
3.5 years on marathons with 22,000 miles are at 50 percent ,are now replaced with 16" michelins, no more china tires here, check where maxxis are made, ..
Old 02-15-2016, 11:11 PM   #10
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
In my opinion, Goodyear Marathons should be replaced after no more than 2 years service.
The Kumho ST tires are reported to be better - search for reviews.
The Maxxie ST tires are reported to be better - search for reviews.
The Michelin Extra Load passenger tire can be purchased in 15 in size if you are willing to upgrade the wheels to 15 in size. Research the tire threads on what is required. Note that the 15 and 16 in Michelins are not the same tire. Note that a 15 in tire will not fit in the spare tire rack without adding about an inch to the rear angle brackets. One solution is to use the 14 in spare for the run to get a replacement in the event of a 15 in Michelin failure.
Add a set of Centramatics to balance the hubs and brake drums. Research the Centramatic threads. There are several.
Good luck on your trip. We visited the NE last fall and enjoyed the area. Pat
Old 02-16-2016, 01:35 AM   #11
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepardstown , West Virginia
Images: 14
All tires made after 2002 have dates on the side which will help determining age. Both blowouts I experienced were not due to bald tires but rather cracked sidewalls. Tires will dry out when exposed to sun for extended periods and age is the next factor. Last April I bought a LY diesel pusher that sill had the original tires on rear and 2 front tires replaced in 2006. Within a month I noticed a large chunk missing from a rear tire. Had them replaced with Hancock's. Front tires were 9 years old and I got about 1500 miles out of them. On a trip west, the right front blew out on I-40. Needless to say I had new tires added to the front and never had another problem.
My advice......tires on RV's more than 5 years old need to be closely inspected and maybe replaced. New tires are cheaper than emergency roadside service and repairs from damage.
Mike1997 is offline   Reply With Quote
Old 02-16-2016, 02:17 AM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Because you are a woman?
No.
Hi, OMG, the sky is falling replace everything!
(1.) Five to seven years old
(2.) Dry rotted or cracking.
(3.) Wearing badly or un-evenly.
(4.) Worn to wear bars; Very rare on a travel trailer.
(5.) Signs of separation, bubbles, cuts, Etc.
I ran ten years on Marathons and only replaced them as needed. Two at 3 years due to small sidewall bubbles. Two at 7 years due to separation. I now run Carlisles with a 82 MPH rating. Miles? Just on my Alaska trip, it was for 50 days and over 10,000 miles. My new Carlisles went on my 2015 cross country trip of 3 1/2 months and over 13,000 miles.
Replacing trailer tires at 2 years and / or X amount of miles is ridiculous.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-16-2016, 07:10 AM   #13
Gainesville , Florida
Maxxis are not Chinese.
Old 02-16-2016, 07:54 AM   #14
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My gyms are now almost 4 years old with 22000 miles and at 50 per cent, nice even wear, looking good ,just installed new michelins,as I don't want to chance damaging the trailer, just because they look good on the outside!....
Old 02-16-2016, 09:10 AM   #15
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Your Maxxis Review?
I'm interested in hearing about peoples experiences with the Maxxis E rated tires. My current tires are 65 years old, and the tread is starting to look cupped in sections. Also they loose about 10 PSI in just a few days. Thus, I'm thinking about replacements.
So if you have Maxxis Tires Please sound off!
Silverflames is offline   Reply With Quote
Old 02-16-2016, 09:18 AM   #16
richw46's Avatar
Lexington , Kentucky
Everything I've read on the various tire manufacturer sites says mileage isn't a consideration. Normally, a trailer tire will not get the mileage that a car will have and will sit longer. They all say that age is the biggest factor and to replace at 6 years, regardless of how much tread is left.
My GYMs are 6 years old this year and I will be replacing them when we get back home. They look great and have lots of tread left. The original owner worked for Goodyear and put 4 new on before he sold it to the guy I bought it from. We've never had any problems in the 2 years we've had the AS.
I wrote to Goodyear, asking about the GYMs made in China. They replied that the materials and construction of the tire are exactly the same as it was when made in the USA. Tire industry sites say the off brand Chinese tires are not of the same quality as big name companies and should be avoided. The big name companies have tire manufacturing sites all over the world but design is done in their home country.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 02-16-2016, 09:43 AM   #17
aftermath's Avatar
Spokane , Washington
There was a time when Goodyear was making their tires in America. The moved them to China to make more money and yes, they were using the same processes they had here but their quality control wasn't doing the job. They had so many problems that they returned to the US. After a short while they went back to China with a better quality control system and I believe they are still there today.
Maxxis are not made in China and have not had the same issues of those that are made in China.
For all of those out there who have changed over to Michelins I am wondering if they will replace their tires after 5 years regardless of wear. What say you?
aftermath is offline   Reply With Quote
Old 02-16-2016, 09:53 AM   #18
2015 30' FB FC Bunk
Yes. I will change out at an interval of 5 years, probably max, even with Michelins.
I guess it depends on the person, some say it is not necessary, some do it just because it gives them a piece of mind.
I had a massive blowout last year and will do any thing and everything I can to avoid that again. Perhaps if that had not happened, I wouldn't feel the way I do.
Old 02-16-2016, 10:08 AM   #19
richw46's Avatar
The Goodyear site is interesting. They say they make tires across 6 continents including North America. There are lots of Goodyear plants in the US. The GYMs are made in China but the rest are made in different plants around the world. Like any manufacturer they can shift production from plant to plant.
They also own these companies, I wasn't aware of this:
" In addition to Goodyear brand tires, we produce several other well-respected international brand names including Dunlop, Kelly, Fulda, Lee, Sava and Debica"
https://corporate.goodyear.com/en-US/about/global.html
-Rich
Rich & Yvonne
2004 4Runner SE
Old 02-16-2016, 11:40 AM   #20
2015 27' FB International
mesquite , Texas
If you can. Wait it'll you get to montana. No sales tax!
moxie t. moto is offline   Reply With Quote
Tires...Tires...Tires Bob Thompson Tires 279 09-19-2019 04:17 PM
I know I should know this blucloud Towing, Tow Vehicles & Hitches 10 09-13-2015 08:47 AM
I know one of you will know how to... AIR-Quarius Cleaning, Stripping & Polishing 1 05-31-2014 11:45 PM
Know anywhere to buy a fridge for a '64 Globetrotter? Airstream76 Refrigerators 0 06-02-2009 01:43 PM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 08:54 PM
