04-09-2016, 04:40 PM
#81
2008 27' Safari FB SE
2023 28' Pottery Barn
Delta
, BC
After reading all of this, I think I'll just stay home.......
04-09-2016, 05:27 PM
#82
2014 25' FB Flying Cloud
LaMarque
Your a smart man. Too funny. It's hard to know for sure. You would think the stock tires should last a few years but that's just not the case anymore. I have not replaced mine yet but I'm looking.
Sent from my iPhone using Airstream Forums silver bp
04-10-2016, 05:44 AM
#83
2015 25' FB International
So the placard on the side of the AS says to inflate tires to 65 PSI cold. Let's say the outside air temp (before sunrise, and as "cold" as it gets during the summer here) is 82 degrees. Then, I read the sidewall of my tires and it reads "max load at 65psi" and whatever the number is. My assumption is that I should never inflate past 65psi.
Now I go to my truck... my placard says to inflate to 35 psi cold. I look at my sidewall and it reads "max load at 45psi" X. It might even be higher than that honestly.
While I understand that the writing on the sidewall is a load rating at a given pressure, not necessarily an indicator of what the tires should be inflated to, I would also think that the higher the PSI, the higher the load it could handle and therefore the manufacturer would choose the highest safe PSI.
Now we go down the road at 65mph... At 3pm with an OAT of 100F. And of course nobody never goes past 65. I wonder what that PSI is in that tire at this point? For reference, my TPMS system in my truck says 41 PSI a 15% increase. If my AS tires went up proportionally, that leaves me at 75psi. Oh, by the way, my truck tires are nitrogen filled so they didn't go up as much as air filled tires will.
Looking at the Goodyear Load Inflation Charts, it doesn't even show a PSI past 65.
Two questions:
1) Is my assumption correct that the max PSI for the Marathon 15's is 65PSI?
2) Under these conditions, should I be surprised if a blow out a trailer tire? If yes, should I blame the manufacturer?
04-10-2016, 07:42 AM
#84
CapriRacer
I'm in the
, US
First, the maximum inflation pressure for a Goodyear Marathon isn't always 65 psi. For a Load Range C, it's 50 psi, and for a Load Range E it's 80 psi. It's 65 psi for a Load Range D.
Second, Rule of Thumb: For every 10°F rise in temperature, your inflation pressure will rise 3%. So for a 30 psi tire, that's ~ 1 psi for every 10°F (you will find that quoted elsewhere, usually without the qualification that it only applies to passenger car tires.)
For a 65 psi tire, going from 82°F to 100°F is 18°F =~ 3 1/2 psi.
Please note that the maximum pressure stated on the sidewall of a tire is a *COLD* pressure. The tire is designed to allow for pressure buildup due to the heat of operating beyond the maximum stated on the sidewall.
- BUT -
Another Rule of Thumb: You don't want to see any more than a 10% rise in operating pressure. That indicates the tire is being operated underinflated, overloaded or too fast. You need to take care of that - usually by going to a larger size tire or a higher load range.
But if you see 15% (or more) , you need to take care of that IMMEDIATELY!!!
And lastly, blowouts can occur for various reasons. The most obvious is debris on the road. Even small nails, can cause a tire to lose enough air to blowout - and unlike a car where you can hear or feel a tire going down, you won't know about your trailer tire until it has destroyed itself.
04-10-2016, 09:45 AM
#85
Anna Maria
Originally Posted by Barretta2
I'm heading out late April/early May for a 6-week adventure: starting Naples, FL, up through New Hampshire, west across Wisconsin and continuing out to Idaho Falls, ID before doubling back and down to "Home" in the Colorado Rockies.
I took my 2012 23' FC to Midas a month ago and had the manager take a good look at my tires. No sign of rot, over 50% tread left. The tires are original and have fewer than 10 miles on them....probably closer to 8,000.
The safety and damage issues are preeminent of course, on such a long trip, but I'm also a woman traveling solo. I do have Good Sam travel assist, but still....
And the question: If you were me, would you replace these "good" tires now?
Actually the best time to replace tires is by the dealer or seller before you pull away with your Trailer should it have Good Year Marathons on it period. Than you will never have to worry about it again.
04-10-2016, 02:42 PM
#86
Delta
, BC
I appreciate all of the problems a lot of people have had but I have Goodyear marathons on both my Airstream and my Wells Cargo 24' car hauler and I have yet to change tires on either. They all still look in good shape, no cracks and while not incredible mileage on them, both have gone up and down the west coast a few times. The car hauler is a 1998. I am sensible with my load, keep the speed at 60-65, watch tires pressures and check the heat of the tires at every stop. Maybe dumb luck in my case, but sure seems wasteful and not very green to change tires just in case unless of course they have lived their life.
04-11-2016, 10:13 AM
#87
Ravenna
, Ohio
- BUT -
X2
