Old 05-05-2016, 07:07 AM   #1
FCStreamer's Avatar
2014 30' Flying Cloud
How long before replacing tires?
I have been reading a lot of posts and opinions about tires. No, I do not have 16" wheels with Michelins.
I just got a used 2014 FC, and being two years old I am assuming the tires have some life left. I don't know exactly how much the previous owner used the trailer, but it looks like not much. And I will be keeping it parked in an RV lot 49 weeks out of the year. Sooo....
How long before I have to replace the tires?
Yes, I will inspect them and keep them properly inflated and all that. But with my use, I should expect to get at least 5 years out of them? Thoughts?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-05-2016, 07:15 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Check the actual date code on the tires. Tires are probably 3 years. 5 years or cracks for me on a trailer that gets pulled much.
Old 05-05-2016, 07:15 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
5 years or when they are worn out or blow out. Hopefully I will reach the 5 year goal before new tires are necessary. With proper care, inflation preasure and speed limitations there are few reasons to expect not to be able too inspite of what the brand haters say.
MICHAEL
Old 05-05-2016, 07:34 AM   #4
richw46's Avatar
Lexington , Kentucky
If the trailer is going to sit for 49 weeks, why not just take the tires off and let the AS rest on wooden supports? Then you can put the tires in storage where they aren't carrying the weight and exposed to the elements.
If it sits for 49 weeks, how far does it travel during the other 3 weeks? If you aren't going very far, I'd just put the old tires back on and move it elsewhere, then take them off again.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-05-2016, 07:39 AM   #5
FCStreamer's Avatar
That's a good thought, thanks!
The other three weeks would be relatively short trips. Two days one way at most, 4 hours each day on the road. Not sure I am up to the task of removing and reinstalling tires, but I appreciate the suggestion!
Old 05-05-2016, 07:40 AM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
They won't cause you any trouble in the RV lot, it's the other three weeks where you might look at the reliability history of the original Airstream tires.
At two years and in great condition they have some market value with their wheels if you decided to change to 16" Michelins, and you plan some long trips in hot weather. TPMS is another strategy to reduce odds of sudden failure, may or may not warn you of failure before damage to your Airstream happens.
Doug and Cheryl
Old 05-05-2016, 07:45 AM   #7
dkottum's Avatar
Okay, reading your last post I think you would be fine for at least five years keeping the pressure up and the tires covered to protect them from the sun. When towing 60 mph and full 65 psi air pressure (cold) is a safe bet, stay under 65 (limit for the tires).
Doug and Cheryl
Old 05-05-2016, 10:35 AM   #8
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
Also: I've read several posts on this Forum that tires should not be left sitting on concrete. If your are storing your AS on a concrete floor, I'd back the trailer's tires over plywood or OSB squares, to keep them off the concrete.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 05-05-2016, 10:43 AM   #9
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
The thing that happened to me was I had one tire out of balance and it caused cupping on the tread. I noticed it when I was backing into a park space and was glad I did. It was not obvious just looking at the tire. Even though the tires were about 3 years old and looked good I replaced them with new. You can have a tire off balance on the trailer and not notice it during towing. So - you can also increase the life of a tire by keeping them in balance + cover them when in storage with good quality tire covers so the sun doesn't damage them
kdickinson is offline   Reply With Quote
Old 05-05-2016, 10:52 AM   #10
FCStreamer's Avatar
My RV pad is concrete so I was going to put down a rubber parking mat under the tires. Wood will probably rot, won't it?
Old 05-05-2016, 10:59 AM   #11
2012 25' FB Flying Cloud
Grand Rapids , Michigan
I just replaced my tires after 4 years figuring that there was an extra year on them from sitting on the dealer lot. The trailer is a 2012 bought at the end of that year. The inside of all four tires showed serious wear and so after putting new ones on I took the trailer in for an alignment. Consensus seems to be 5 years and after seeing how they look, I'm glad I didn't go any longer.
Jwestman is offline   Reply With Quote
Old 05-05-2016, 11:29 AM   #12
TAC CA-420
'55 Airlight's Avatar
Santa Monica , California
Images: 104
ST (trailer) tires are rated for 3-5 years, after which they have "aged out" and become prone to failure, irrespective of visual inspections showing good tread remaining. I change my tired every three years with about 25k miles on them.
Michael
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,—the three sister Graces of our moral being.’
Sir Richard Francis Burton
'55 Airlight is offline   Reply With Quote
Old 05-05-2016, 11:38 AM   #13
1973 31' Sovereign
Middletown , California
Why not leave tires on concrete? I haven't heard that, I know some types of dirt can cause rot.
ijustlee is offline   Reply With Quote
Old 05-05-2016, 11:40 AM   #14
FCStreamer's Avatar
Rubber garage tiles are cheap and will give me peace of mind.
The Long long long trip Foiled Again Full-Timing, Winter Living & Workamping 39 03-24-2016 10:27 AM
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
How cold and for how long before worrying about freezing pipes? bonginator Plumbing - Systems & Fixtures 20 02-26-2011 06:31 PM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
