Old 11-24-2007, 03:10 PM   #1
jacarape's Avatar
2006 25' Safari
orlando , New Mexico, Utah, Colorado
How does your TV react when the TT gets a flat?
Hi all,
Iv'e read with much interest on the technical aspects of tires, which has me asking how do you know you have a TT flat?
I'm new to streaming, and planning my first trip early next year. It will probably be around the country tour. My TV is a burb 2500HD, 4by and I'm pulling a Safari 25' SS.
I've not yet experienced the joys of a flat or a major failure, but from the cab of the TV, what alerts you to tire problems that require immediate attention?
Thanks in advance if you have a moment to share your experience.
BR-michael
I'm a true bum, working less and living longer.
WBCCI #3841
jacarape is offline   Reply With Quote
Old 11-24-2007, 04:30 PM   #2
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
To be honest, towing a 25' A/S with a 2500 Burb, you probably won't even know your TT has a flat. Since a tire blowout can really cause a lot of damage to the trailer, some folks like to arrange their mirrors such that you can keep an eye on the TT tires for that very reason. I'd suggest Mckesh mirrors with the convex add-ons.
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD • Hensley • DirecLink • McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 11-25-2007, 06:08 PM   #3
1984 31' Excella
Norfolk , Virginia
Images: 11
Flat Tire
I'd suggest a Tire Pressure Monitering System because by the time you notice the tire is flat its probally going to be comming apart and causing damage.
Beginner
Beginner is offline   Reply With Quote
Old 11-25-2007, 06:48 PM   #4
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
The only flat I've had on a trailer was a small single axle utility trailer. I was travelling at highway speed. My first clue was when I saw "mud" coming from behind the trailer - then I realized that the road had no mud on it. I was seeing rubber chunks flying.
The tow feel really never changed, but this was a very light trailer.
With a double axle, you may not know unless you see "mud" in your rear view mirror. Check your mirrors often, check your tires after each stop.
Dave
Fyrzowt is offline   Reply With Quote
Old 11-26-2007, 07:49 AM   #5
jacarape's Avatar
2006 25' Safari
I was afraid of this, not knowing that a tire failure has occured until a passing motorist franticly points back at the TT.
There are a few comments on other threads about the Pressure Pro, I think I may invest in a set of four. While not perfect, less expensive then repaired body work. Hopefully.
WBCCI #3841
Old 11-26-2007, 09:50 AM   #6
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I got a "flat" while towing last winter. I did not notice. Until the next day.... when I was looking at the tires after being parked overnight.
Michelle TAC MT-0
Sarah, Snowball
Old 11-26-2007, 10:20 AM   #7
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
One of the advantages of a dual axle...
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 11-26-2007, 10:28 AM   #8
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
I really don't know anything about the tire pressure monitors but I've read quite a few comments from folks "in the know" that basically said not to waste your money on them. Anyway, I'd be doing some serious research first.
Unfortunately, I don't think there's a sure fire way of knowing when you have a flat. The best advice is probably to make sure the tires are in good shape, maintain maximum pressure at all times and inspect them regularly.
Gary & Debbie
2001 Safari 25 SS
Set-up by Can-Am RV
Old 11-26-2007, 10:50 AM   #9
1984 31' Excella
Norfolk , Virginia
Images: 11
Flat tire
Don't waste your money?
To replace the side panel on an Airstream can run into the thousands of dollars.
To replace the plumbing connections at the dump point which usually gets ripped off when a tire starts flailing the trailer usually $200.00 or more plus the aggrivation of it all.
With a tire pressure monitering system usually you will be standing at the side or the road watching the tire finish going flat (absolutely no damage to the trailer).
The first 1/2 a trip (on the way home) I had mine, it paid for itself. The next time it alarmed was pure profit.
I guess it depends how close to the edge you like to live.
I have to wonder if those folks "in the know" disconnect their engine guages in the dash so they will have less to worry about.
Beginner
Old 11-26-2007, 11:03 AM   #10
Images: 59
I have the Pressure Pro sensors for use during daylight. I figure after nightfall the geyser of sparks from my skidplate will be visible from outer space.
Old 11-26-2007, 11:26 AM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
Sounds interesting... but it uses a cigarette lighter plug? Another piece of equipment visible for no-goodniks to spy in my truck.
5 meter Langford Nahanni
Old 11-26-2007, 03:18 PM   #12
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Pressure Pros
The PPs are great otherwise just hope for minimal damage or hope you hear a blowout (you will) and stop immediately. I agree that if it's merely a tire going down you'll have a difficult time immediately noticing anything from your TV.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 11-26-2007, 03:25 PM   #13
Images: 59
No, it uses a minicable. I ran the cable from my overhead console to the sun visor, and the Pressure Pro attaches to the hidden side of the visor with velcro. It's not visible from the outside.
I do worry about the pressure sending units. They're held on with a lock nut, but I'm worried some frustrated thief might just hit it with a hammer if he can't get it off.
Old 11-26-2007, 07:33 PM   #14
nilesrob's Avatar
Marietta , Georgia
Images: 12
like others, I have had a flat and not known it except for another traveler letting me know.
My thought on the sensors would be whether or not they would alarm fast enough before tire damage really gets underway. I have seen a truck tire almost literally explode next to me, and a tire monitor wouldn't have done that driver a bit of good because the tire shredded in seconds.
I'd be open to trying monitors, but I would be a bit skeptical none the less - at least for highway driving.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Flat tire tn2 Argosy Motorhomes 8 11-04-2007 08:00 AM
How did your family and friends react? janetb Off Topic Forum 30 12-15-2006 02:28 PM
Frame-Flat jcferguson Repairing/Replacing Floor &/or Frame 6 02-20-2005 09:00 AM
M52 fridge t-stat won't react Jabba Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-15-2003 06:57 AM
