Old 10-16-2010, 04:12 PM   #1
1970 23' Safari
Sacramento , California
How do you replace a tire?
Hard to believe but I cannot figure it out and my level of frustration is increasing.
I have a 1970 single axle. I took off some worn out 15/7.00 L tires, they were a bit tough to get off - the side wall was dragging on the wheel well.
Initially the shop gave me 225/75 tires but I couldn't get them in the wheel well so I went back and they put on 15/7.00 LT tires. I cannot get these back in the wheel well either What am I doing wrong? Is the problem that I have LT not L?
I feel a little better. I take the dog for a walk and maybe I'll feel much better.
M1970 is offline   Reply With Quote
Old 10-16-2010, 04:24 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The wheel wells are very tight on these. ( I have a 70 globetrotter) You will have to jack up the trailer fairly high to get a better angle.
It might also help to hold a piece of sheet metal between the tire and the wheel well to make it slide across the rivets that stick through.
It also may be that the arm the hub is on is not dropping down as far as it used to due to age.
Last resort is to deflate the tires and then reinflate them after installation
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 10-16-2010, 04:38 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Sounds like your axle is shot,not dropping down to give you good clearance,it may help to let the air out the tire until you get it mounted. Also have a helper pull out on the wheel well. Dave
easyride is offline   Reply With Quote
Old 10-16-2010, 05:21 PM   #4
1970 23' Safari
Thanks for the tips. At the moment the jacks are under the axle - would another location be better?
What does a shot axle mean (other than a repair bill) - can I still pull it?
Old 10-16-2010, 06:01 PM   #5
1972 Travelux Princess 25
Cobourg , Ontario
If the axle is bad there is no suspension. The hard ride can shake your trailer to pieces. Loose rivets, fatigue cracks in body and frame etc.
There are threads on this. Once you see pictures of a trailer with good axles, and one with worn out axles, the difference is obvious. When the axles are worn out the trailer sits much lower.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 10-16-2010, 06:19 PM   #6
NEVER, EVER, put jacks on the axle. You can ruin the axle or throw it out of alignment, by doing so.
All 1974 and prior axles will fail due to the incorrect composition of rubber that was used.
The other thing that kills the rubber rods, is to park the trailer for an extended time, with all the weight on the tires.
There is an axle article in the Airstream Central section of this Forums, that will teach you how to check it out yourself.
Old 10-16-2010, 07:25 PM   #7
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
By placing the jack on the axle, you are pushing the axle up into the wheel well to lift the trailer, making changing a tire much more difficult. Move the jack to go underneath the frame rail that runs front-to-rear just inside of the wheel well, so the trailer lifts and the axle droops.
The frame rail is above and inside the belly pan, thus hidden from view, so you will have to feel for it by hand when placing the jack underneath it. Sometimes a jacking point is marked on the belly pan by a small square of aluminum attached to the belly pan. The jack should be just forward or rear of the wheel well underneath the frame rail, to give you room to wiggle the tire and wheel assembly. Once the trailer is raised, ALSO put a jack stand under the frame rail at the other end of the wheel well, so you have the trailer raised at two points for redundant safety. Sometime I use large stacked timbers instead of a jack stand.
Finally, remove the round small (~2" diameter) grease cap from the outer end of the axle. That should get you a bit more clearance on the axle end to squeeze the tire and wheel up past the axle. Good luck!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 10-16-2010, 08:44 PM   #8
OO , OO
Send a message via Skype™ to cruiser54
I call up to my garage service..
cruiser54 is offline   Reply With Quote
Old 10-16-2010, 09:06 PM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I don't think jacking on the axle cross bar on a Duratorque axle will push it any further up into the wheel well. On a Leaf spring axle it will.
Regardless, it is not the best place to jack from as if it slips it will go through the belly pan at a minimum. A better place is jacking under the frame or the fish plate the axle is bolted to.
Old 10-16-2010, 10:06 PM   #10
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
1956 16' Bubble
Jamul , California
Images: 159
Had the same problem.
M1970
Pretty much saw this same movie on my own 70 Safari, rig.
Shot axle on and already tight wheel well. As covered in the previous threads, to at least get going, let the air out of the tire, jack up from the frame, look just aft of the axle on the under belly skin, look for the square lift points plate with the rivet at the center. lift there. I lifted as high as I safely could, then lifted the nose a bit , used cribbing for safety.
bolt up your rim and re-inflate to pressure.
A shot axle will not come down, nor up, virtually no movement and this expains your difficulty. I just replaced my axle with a new one from Inland, no more tire install problems and I added about 3 plush inches to hight.
Good luck with your rig, great size and layout...
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Old 10-17-2010, 05:55 AM   #11
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Axles are most likely shot. New tires and long trip in your trailer with no suspension will be bad on lots of things. Check the axles and replace if you find you have no suspension. Had the same issue on my Trade Wind with the original axles. They had exactly ZERO movement, torsion arms were frozen in place.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Blown tire-Discount Tire sold me Carlisle?? FLYNCLD Tires 15 08-22-2010 09:45 AM
help with measurments from tire to tire '67 Caravel Trophycare General Repair Forum 0 07-19-2010 11:17 AM
Tire protection, tire cover and airconditioning leong1 Tires 0 06-22-2009 04:02 PM
replace AC? roguebrun Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-29-2008 06:09 PM
What tire to replace Tow Masters HowieE Tires 10 06-26-2007 09:15 PM
